Old 1st January 2026, 18:58   #9901  |  Link
GeoffreyA
Donor
Makes sense. Its somewhat different tools and ranges yield different-looking artefacts as a side effect, and x265's implementation of these tools may not be the gold standard. qcomp was helping, but as you said, just shifting around or pumping up the bits.
SVT-AV1 can give a better picture at the frame level, but going in the temporal direction, particularly with grain, we're walking on shaky ground. The HDR fork does better, but changes the appearance of the grain, making it coarser.
GeoffreyA is offline   Reply With Quote
Old 5th January 2026, 17:45   #9902  |  Link
benwaggoner
And, as always, with a video codec, how it looks temporally is really the only thing that matters. Making still images look good in isolation is a much simpler problem than getting a coherent, consistent experience over time. And good psychovisually compression efficiency can involve doing things that can make individual frames paused look not great, but which are invisible during actual playback. Temporal masking is a powerful tool.
Ben Waggoner
My Compression Book
Old 6th January 2026, 16:27   #9903  |  Link
Z2697
I found that x265's SAO performs better or less bad in 12bit mode some time ago... maybe worth take a look.
But I cannot really understand that part of the code, and since AV1 has better filter(s) and better open source implementation(s), I'm not very motivated
Z2697 is offline   Reply With Quote
Old 6th January 2026, 20:14   #9904  |  Link
GeoffreyA
Donor
Yes, we tend to fixate on comparing single frames, but at the end of the day, it's the video. x264/5 seem mostly fine in this regard, the lesser-quality frames feeling consistent.
Well, 12-bit might be challenging to play on some hardware, and I've made peace parting with SAO for life!
Jokes aside, I've found some success with aq-mode 4 these past few days. So far, it's working well.
Old 7th January 2026, 14:22   #9905  |  Link
Z2697
The problem is it shouldn't perform distinctively worse in 8 and 10 bits mode, hence there may be some bug in the code.
I mean the SAO mode decision, not the fps perform, you know.
Old 7th January 2026, 15:28   #9906  |  Link
GeoffreyA
Donor
So, a precision sort of bug? Perhaps an overflow somewhere in the calculation?
Old 7th January 2026, 19:19   #9907  |  Link
rwill
Well you could give my gradient_with_noise sequence a try, with 10 and 12 bit, and check if its no longer blocking things up.
https://forum.doom9.net/showthread.p...76#post1949376
But I guess nothing did change. Last time I checked x265 had no real "mode decision" for SAO but only went by what it understands as "distortion". I remember debugging some large offenders and the numbers checked out, no bug there it seems.
My github...
Old 7th January 2026, 20:01   #9908  |  Link
GeoffreyA
Donor
Does x265's SAO use the same implementation as HM, the reference encoder?
Old 7th January 2026, 20:09   #9909  |  Link
rwill
Well I guess they did not come up with something novel on their own....
My github...
Old 7th January 2026, 21:42   #9910  |  Link
Z2697
Least "distortion" (and seems calculated in it's own way) is still some kind of mode decision... right?
I tested this same clip before, 12bit does not create same "blocky columns" as 10bit in the test, that's actually what I mean less bad.
But this kind of content should use "no operation" mode I think? 12bit still doesn't do that.
Old 8th January 2026, 06:42   #9911  |  Link
rwill
Yes, picking a mode based on least distortion is a mode decision. I meant something like a full RD one with normal SSD and PSY distortion, like the CU mode decision.
That the clip does not exhibit the blocking at 12bit is interesting and probably worth investigating. Its strange that 8 and 10 bit pick the 'offset' mode and 12 bit does not. As for the optimal mode, it would be better if it were selected by real RD costs, that is, recon against source distortion with the (PSY-)RD distortion metric used everywere else.
My github...
Old 10th January 2026, 00:41   #9912  |  Link
benwaggoner
That was my understanding back in the day, and I do not recall that ever changing.
Ben Waggoner
My Compression Book
Old 29th January 2026, 01:33   #9913  |  Link
hellgauss
hellgauss's Avatar
Perhaps related to RD, I found an unwanted behavior in rd-refine option. The following screen is from Vinland Saga Season 1 Episode 16, source is blu-ray @34MBps
https://imgur.com/iwfhscB
NOTE: the screen is taken via VirtualDub2 and the artifacts are present in software decoder, so probably it is not the same MV issue I described a few months ago in another thread.
The flickering fire leads to fast moving gradient in a dark background, which is somewhat a worst case scenario for video encoding. There are a lot of similar random macroblocks in the whole scene, each last for 1 frames.
Bat file used (Windows):
set bf=6
set subme=4
for %%i in (0,1) do (
for %%j in (10,12) do (
rem i=rd-refine j=bit
start /low ffmpeg -threads 1 -y -hide_banner -nostdin -stats_period 33 -bitexact -i "Vinland-Saga_S1E16.mkv" -map 0:v -ss 206.580 -t 17.977 -profile:v main%%j -vf "removegrain=1:2:2,removegrain=0:2:2,format=yuv420p%%jle" -sws_flags accurate_rnd -c:v libx265 -preset veryslow -crf 17.2 -x265-params "deblock=-1,-1:no-sao=1:no-strong-intra-smoothing=1:tu-intra-depth=4:tu-inter-depth=4:merange=58:ref=6:rc-lookahead=99:bframes=6:rd=6:rd-refine=%%i:subme=4:vbv-maxrate=20000:vbv-bufsize=24924:frame-threads=1ools=none:no-wpp=1:level-idc=51:high-tier=1:colorprim=1:colormatrix=1:transfer=1:range=limited" -bitexact "Vinland-Saga_S1E16_r%%i_b%%j.mp4"
Writing library : x265 4.1+211-9e551a994:[Windows][GCC 15.2.0][64 bit]
If rd-refine=1, artifacts appears both in 10 and 12 bit. With rd-refine=0 there are no wrong macroblocks. However rd-refine seems to give nice results in other scenarios.
hellgauss is offline   Reply With Quote
Old 29th January 2026, 02:03   #9914  |  Link
Z2697
That's a known issue, among some people.
https://github.com/Mr-Z-2697/x265-ex...2a4df2c730ad7a
However my test result didn't favor rd-refine even if it's supposed to be fixed (if I'm lucky).
However yet again I didn't test the ultimate single thread encoding like you do.
I'll port that branch into a latest x265 and compile a test build for anyone that might be interested.
https://pixeldrain.com/u/z9TjFxsh
or
https://workupload.com/file/kcWyHpU2rX3
Old 29th January 2026, 17:34   #9915  |  Link
hellgauss
hellgauss's Avatar
An update: it seems that the rd-refine problem is also related to the limit-tu option.
Test script used (all encodes with rd-refine=1, loop through limit-tu=%%j)
set rdr=1
set bf=5
set subme=3
for %%j in (0,1,2,3,4) do (
rem j=limit-tu
start /low ffmpeg -threads 1 -y -hide_banner -nostdin -stats_period 33 -bitexact -i "Vinland-Saga_S1E16-rdr-scene.mkv" -map 0:v -profile:v main10 -vf "removegrain=1:2:2,removegrain=0:2:2,format=yuv420p10le" -sws_flags accurate_rnd -c:v libx265 -preset slower -crf 17.2 -x265-params "limit-tu=%%j:deblock=-1,-1:no-sao=1:no-strong-intra-smoothing=1:rc-lookahead=99:bframes=%bf%:rd=6:rd-refine=%rdr%:subme=%subme%:vbv-maxrate=20000:vbv-bufsize=24924:frame-threads=1ools=none:no-wpp=1:level-idc=51:high-tier=1:colorprim=1:colormatrix=1:transfer=1:range=limited" -bitexact "Vinland-Saga_S1E16_[rdr_%rdr%][ltu_%%j].mp4"
Results:
Macroblocks are evident with limit-tu =0 and 1. Less evident with 2, absent with limit-tu=3 or 4. Replacing with rd-refine=0, all tests present no "macroblocks" artifacts.
EDIT: thanks Z2697 for your build, I'll give it a try as soon as I setup a proper framework (I'm used to ffmpeg and not familiar with x265.exe, but I guess it is not difficult)
Old 29th January 2026, 19:36   #9916  |  Link
jpsdr
@Z2697
I took a look on your experimental repo, and see in your experiments the remove of distorstion chroma only for 444. Did test/check and finaly found that it produces better results ?
My github.
Old 29th January 2026, 20:06   #9917  |  Link
Z2697
This bug is quite random, it may disappear here but can happen at other places.
Old 29th January 2026, 20:10   #9918  |  Link
Z2697
Originally Posted by jpsdr View Post
@Z2697
See more detail in https://forum.doom9.org/showthread.php?t=186790
In theory, and in the way I assess chroma quality, it's better.
Old 29th January 2026, 20:38   #9919  |  Link
GeoffreyA
Donor
It seems to be more in line with x264, undoing that commit.
Old 30th January 2026, 02:50   #9920  |  Link
benwaggoner
Gosh, I hadn't thought about --rd-refine in years. I never found any examples where it provided a material difference. Have people found it helpful in some situations?
Ben Waggoner
My Compression Book
