Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD burning
Old 19th April 2013, 07:32   #1  |  Link
Cheer Up
dvd burner?
I make videos by myself for about 2 years... and now I want to brun them into dvds to well record them.
I use Windows Movie Maker to make videos, what software you guys use to burn dvds? Or are there software that can do both editing and burning?
Cheer Up is offline   Reply With Quote
Old 26th April 2013, 02:45   #2  |  Link
setarip_old
setarip_old's Avatar
Hi!
Use (freeware) IMGBurn for burning...
setarip_old is offline   Reply With Quote
Old 26th April 2013, 09:55   #3  |  Link
Ghitulescu
Ghitulescu's Avatar
While burning is pretty much a straight concept (and got a direct answer from setarip_old), editing is a very complex one (let alone most people confound editing with a lot of other things ). I assume that most burning suites (like Nero, WinOnCD and similar) may help you.
Born in the USB (not USA)
Old 2nd May 2013, 09:21   #4  |  Link
Cheer Up
Thanks for the tip
Hey, thanks for the tip. well is there any video editing software that I can use to edit videos as well as burn them into dvd?
Thought it will be more convenient.
Old 2nd May 2013, 09:21   #5  |  Link
Cheer Up
thank you for the idea
Originally Posted by setarip_old View Post
Hi!
Thanks, got to have a try.
burn to dvd, video capture, video software
