#21 | Link |
Professional Code Monkey
I also call bullshit on this one. I have a calibrated ips screen and even after minutes of staring both pictures look identical.
#22 | Link |
For me to bottom one is bit darker/more saturated, specially in the top/left quarter (and on reds).
Funny enough I did load it to photoshop and thought that there is no difference, but difference mode shows difference, exatctly in places which I described ![]() I think it was more imaginary and due to LCD angels, even if I have very good monitor, but I'm also convince that I did see "real" difference
#23 | Link |
Posts: n/a
No, it's not. You are imaging a difference that does not exist. The pictures are basically identical beyond the value difference in the YUV planes being .01 between them. Here is the two images run through Histogram. If there was a brightness or saturation difference the graphs would not be almost exactly the same.
![]() ![]() To add further this is the output from changing them with only Tweak(sat=1.1,bright=.9). It's hardly a dramatic change yet you can see the YUV graphs are noticeably different.
#24 | Link |
Yes they are almost identical- basically identical, but funny enough difference is in areas which I did described, before I checked it in Photoshop. Probably simple coincidence.
I think it's due to monitor angles imperfection. |
#25 | Link |
Posts: n/a
Yes, as I said on the previous page you get basically a perfect gray image by subtracting them. So, in conclusion, while the doc did have a warning that there will potentially be mathematically different values between the C and SSE2 routines, it is hardly what is going to be perceptible.
#27 | Link |
If you're looking at them side by side, your conclusion means nothing because, as you said, the monitor's angle differences will be much larger anyway.
I also have a high quality screen, and I can't spot a difference even if I flip back and forth between them in different tabs. |
#29 | Link |
It'll likely be the viewing angle properties of his LCD screen affecting the contrast of the bottom image more as he's not doing a proper comparison in an image viewer and instead looking at them as they're presented on the forum.
#30 | Link |
unsigned int
Hello.
Could you share that ported assembly code, please? Or... nevermind now, I guess.
Buy me a "coffee" and/or hire me to write code! Last edited by jackoneill; 16th November 2012 at 15:38. |
| Display Modes | |
