Old 9th December 2019, 15:10   #41  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
You could use XYRemap, but I also already wrote Widen for this exact purpose, which works in all 8-bit colour spaces (but is 64-bit only).
If you're looking for a formula, it involves tan or inverse tan, can't remember which way round I did it.
You could also try messing around with Defish which may mitigate the ugliness of edge distortion on pans by introducing some vertical distortion as well.
wonkey_monkey is offline   Reply With Quote
Old 10th December 2019, 08:33   #42  |  Link
LigH
LigH's Avatar
I will prefer the specialist plugin, its precision is probably higher than an 8-bit LUT. And even better it's available for x86-64.
New German Gleitz board
Old 10th December 2019, 14:16   #43  |  Link
wonkey_monkey
Not sure what LUT you are referring to.
Old 10th December 2019, 16:04   #44  |  Link
LigH
LigH's Avatar
If I use an RGB24 image as distortion map (a.k.a. look-up table), the resolution of the distortion would be 8 bit at most. I guess it might be coarse enough to see some "motion banding" in panning scenes?!
Old 10th December 2019, 16:52   #45  |  Link
wonkey_monkey
That was a suggestion by someone that never got implemented. xyremap works purely on calculations of target coordinates to source coordinates. Widen doesn't use a LUT either.
Old 11th December 2019, 08:48   #46  |  Link
LigH
LigH's Avatar
Apparently I mixed that up with an earlier idea what I was looking for... one day I notice the UPN in the description, the other day I completely forget about it.
Old 18th August 2020, 15:01   #47  |  Link
Maybe of interest to some Wonkey_Dalek:
Doctor Who launching immersive theatre experience with Daleks and Time Lords
https://metro.co.uk/2020/08/18/docto...ords-13144487/
EDIT: Maybe one step closer to being a Cyberman:
Cyborg’ technology just took a step closer to reality
https://metro.co.uk/2020/08/18/cybor...lity-13142896/
Old 28th September 2024, 21:46   #48  |  Link
LigH
LigH's Avatar
@StainlessS: Your PMs are full, I wanted to ask you about plugin development...
But maybe @wonkey_monkey too. Not in this thread, of course. Just because you both may get notified when I mention it here.
