Old 7th May 2021, 18:17   #161  |  Link
Thankyou, but, I'm hittin' a dead end.
Loading DVD vob and pressing F5, wait about 20 seconds and then hit ESC, followed by closing DGIndex, I get this
Stream Type: MPEG2 Program
Profile: main@main
Frame Size: 720x576
Display Size: 720x576
Aspect Ratio: 4:3 [2]
Frame Rate: 25.000000 fps
Video Type: PAL
Frame Type: Interlaced
Coding Type: B
Colorimetry: BT.470-2 B,G
Frame Structure: Frame
Field Order: Top
Coded Number: 490
Playback Number: 490
Frame Repeats: 0
Field Repeats: 0
VOB ID: 1
Cell ID: 1
Bitrate: 4.236 Mbps
Bitrate (Avg): 4.359 Mbps
Bitrate (Max): 4.535 Mbps
Audio Stream: 80: AC3 2/0 224
Timestamp: 0:00:19
Elapsed: 0:00:19
Remain: FINISH
FPS: 24.96
Info:
which is nice.
But, Load VOB again into DGIndex, press F5, wait for about 20 seconds, hit ESC,
and then, F4 (save project), I get this
Profile: main@main
Frame Size: 720x576
Video Type: PAL
Coding Type: P
Field Order:
Coded Number: 44024
Playback Number: 480
Frame Repeats: 0
Field Repeats: 0
VOB ID: 1
Cell ID: 1
Bitrate:
Bitrate (Avg):
Bitrate (Max):
Timestamp: 0:29:19
Elapsed: 0:00:11
Remain: FINISH
FPS:
Info:
So full save project, loses the Field Order obtained from Preview.
EDIT: In 2nd code block, Coded Number seems to be full project length in frames,
and Playback Number seems to be number of frames Previewed.
EDIT: All above without the batcher thingy.
EDIT: But same results as above when doing same (with modded code) from within the batcher.
Old 7th May 2021, 20:09   #162  |  Link
videoh
Useful n00b
Hmm, save project may clear the info. Investigating...
Old 7th May 2021, 22:21   #163  |  Link
Danette
I ran into the same problem when developing the macro using Macro Express. The last "Information" window / log file created, before closing, overwrites any other such file upon closing. To get around it, I ran the "Save Project" first and the "Preview" last. Of course, I'm not doing any of the more complex things that DGIndex Batcher is doing.
Danette is offline   Reply With Quote
Old 8th May 2021, 02:05   #164  |  Link
videoh
Useful n00b
That's very creative, congratulations! Still and all, that should be fixed. I'll get to it after the DGDemux port to linux is completed. I have a linux bug up my you-know-what. Maybe it will make people hate me less, but maybe not.
Old 8th January 2022, 19:04   #165  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Hi StainlessS, a small wish: open file extension mask for .MTS
Batcher 1.22 can not see camera files with .MTS extension.
Old 8th January 2022, 19:27   #166  |  Link
OK, but on the back burner.
You could add it yourself, source is supplied and only have to (by memory) hit the F5 key to recompile.
[AutoIt compiler and the additional Scite editor for it]
Old 8th January 2022, 19:57   #167  |  Link
Emulgator,
Line 142,
Global Const $FILTER = 'MPG Files (*.vob;*.mpg;*.mpeg;*.m1v;*.m2v;*.mpv;*.tp;*.ts;*.trp;*.m2t;*.m2ts;*.pva;*.vro)'
Just add your new semi-colon separated extension to the list,
ie,
Global Const $FILTER = 'MPG Files (*.vob;*.mpg;*.mpeg;*.m1v;*.m2v;*.mpv;*.tp;*.ts;*.trp;*.m2t;*.m2ts;*.pva;*.vro;*.mts)'
Rebuild is actually F7.
Well, here is just the exe,
https://www.mediafire.com/file/gc97g...r%255D.7z/file
EDIT: Untested.
Old 14th January 2022, 00:28   #168  |  Link
Emulgator
Emulgator's Avatar
Deepest Thanks, StainlessS !
.mts are visible now.
batcher, dgindex
