#181 | Link |
Broadcast Encoder
Thanks to you both! I'm gonna try it out and see whether it does what it's supposed to do with my source which definitely would have benefited from an hardware time base correction (but the tape is on another site 500 km away and it's not exactly the time to... uh... travel... you know...).
#183 | Link | |
Yep, Sendspace only keeps them for 30 days after latest download. [ what a silly billy
]RD, did you update this on Wiki: http://avisynth.nl/index.php/Filter_SDK/Env_SaveString Thats a pretty awful example of env->SaveString() use, eg Code:
Filter SDK/Env SaveString
env->SaveString is given to allow users to pass strings to AVSValue, and ensure that they are being deallocated on unload.
An Example:
fnpluginnew = new char[string_len];
strcpy(fnpluginnew, fnplugin.AsString());
strcat(fnpluginnew, " ");
strcat(fnpluginnew, name);
env->SetGlobalVar("$PluginFunctions$", AVSValue(env->SaveString(fnpluginnew, string_len)));
// Since fnpluginnew has now been saved it can safely be deleted.
delete[] fnpluginnew;
I think previous example was taken from one of my posts in dev forum, way better [but I'm probably biased a bit]. I'll find it if you want. EDIT: Here:- https://forum.doom9.org/showthread.p...36#post1633936 Quote:
Avisynth and your plugin both have their own heap memory [new/malloc] and when you return a string allocated on your plugin heap, you MUST hand over a string copy to avisynth, you must make a copy on avisynth heap (using avisynth's env->SaveString()) and give it the copy, this gives avisynth full control over the string memory and also the responsibility to delete the memory when avisynth closes down. After you make a string copy for avisynth, you can then delete/free your temp string memory buffer. It is not necessary to use SaveString() on a string literal, "String literals are read only and at constant address and so need not be saved". Set a Global var named MyGlobalString="Some GlobalVar Text" (actually does not need to use SaveString as "Some GlobalVar Text" is a String Literal). Code:
env->SetGlobalVar("MyGlobalString", AVSValue(env->SaveString("Some GlobalVar Text"))); // Set Global [SaveString will use strlen() to establish length of string]
env->SetVar("MyLocalString", AVSValue(env->SaveString("Some LocalVar Text"))); // Set Local [SaveString will use strlen() to establish length of string]
similarly have to use env->SaveString() to make copies of them, and give the copies as the names to SetGlobalVar() and SetVar() functions. Set Global variable MyPi=3.1415926 [again, below MyPiName is a pointer to "MyPi" string literal (text wrapped in double quotes) and does not need env->SaveString, is just for illustration purposes] Code:
char *MyPiName = "MyPi"; float pi=3.1415926f; env->SetGlobalVar(env->SaveString(MyPiName), AVSValue(pi)); ... env->SetGlobalVar(env->SaveString(MyPiName), pi); // Implicit type conversion of float pi to an AVSValue
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 16th August 2020 at 15:28. |
#184 | Link |
Thanks for finding my old plugins. I still don't know where a good place to post stuff is though. What site lasts 10 years these days?
I actually did work on an aspect of this recently. What I called the perfect TBC method was using a correlation to find horizontal line jitter. This used several samples so was able to be more robust to noise, besides changes in brightness and contrast. I was able to use ChatGPT to solve all the math behind it. I've learned much more since then. There's a bunch of approaches to my problem and they can be measured against something called the Rao bound. Math like this is used for many things such as photogrammatry and aligning audio from different sources, measuring echo, and other types of alignment problems. The baked in type of jitter could probably be trained with AI now. Good thing I turned into a data scientist ![]() Meanwhile we have vhsdecode which is improving all the time. https://www.videohelp.com/software/VHS-Decode You need to solder two wires to your direct head feed. You don't need an expensive Doomsday decoder, you can use a cheap TV USB stick as used in SDR or Software Defined Radio. https://www.rtl-sdr.com/buy-rtl-sdr-dvb-t-dongles/ Since VHS is an FM signal, the capture doesn't device doesn't have to be precise, it only needs to measure a frequency. |
#187 | Link | |
. But having something instead of nothing is better.If you don't want to host on GitHub as poisondeathray suggested, VideoHelp offers 512mb of storage. They have proven to be reliable and you can easily archive it also. I've done exactly that with a handful of plugins that are on the wiki. |
| Tags |
| tbc |
| Display Modes | |
