#161 | Link | |
Some studios are easier to modify than others because of this, if there's a certain title you want help with, mention that. Someone here may be able to help... Usually graphics can be found in folders in the JAR folder, and those can be directly edited if you want, and sometimes there's a few parameter files that might disable FBI warnings and startup trailers, but anything more complex than that will probably require a bit of effort. |
#165 | Link | |
e) OK f) OK g) AnyDVD (I use 6.7.9.0) don't fix the .jar files neither rewrites the .crt of the CERTIFICATE folder. In consequence, when I reproduce the blu-ray in my Panasonic BD-35, the movie works well but the menu and pop-up menu don't shows any text included in the modified file of the .jar. Curiously it works 100% on a Samsung or in the PC. But the Panasonic BD-35 needs to re-sign the .jar files or modify the CERTIFICATE. So, my questions are: Why AnyDVD (6.7.9.0) don't fix .jar files? It exist some alternative to do this matter? Thanks |
#167 | Link |
IGS menu problem
Hello Guys!
This tutorial is awesome! Using it for a while to turn movies more likeable to my taste. Pelican, Deank, crl2007 and the rest of you guys making an exceptional work. Keep up! The time has come to ask a little help. I have problem with IGS menus. I am trying to subtitute menutext on a bluray disc using this tutorial above on the first page, in one of the .m2ts file in my movie. When I load the .clpi file and click menu and wanna click mux and save (even if i do nothing I mean not to change any .png) I got the next error message: "Access violation at address 00404486 in module 'BDedit.exe'. Read of address 06FF1000. " I tried it several times, over and over following the tutorial. What could be the problem. Wrong .m2ts file? Maybe a bug? I tried to do the same thing with another movie, that went fine. I am struggling on it for weeks. I hope you can give me some clue. Thanks in advance! |
#168 | Link |
edit class file
I have problems,
1. When I try edit original language, if my string length more than original string length so bluray can't work. 2. How to edit text position in class file? (same as edit .prop file, because I see it same when I using java decompiler) Please help me, thank you in advance! |
#169 | Link |
I have problem with IGS MENUS.
Example Movie Menu is 0000.m2ts popup igs menu is 0001.m2ts ==> i can edit and mux it. no problem but main igs menu is in 0000.m2ts. Usually main igs menu will seperate from movie menu like popup igs menu. But This movie, main igs menu is in movie menu. I can edit but can't mux it. because it will make movie menu has problem. Please guide me. how should i do? Thank you Last edited by no-one; 28th January 2016 at 16:39. |
#170 | Link | |
Try to demux it with BD Demuxer Pro 3D. Then you will get the .ies file and the movie file. Edit the .ies with the IGEditor. Then remux it again in Scenarist. Good luck. |
#173 | Link |
I wonder if anyone knows how I can change the functionality of buttons within a bluray menu?
I have created a bluray menu in Encore, only to come up against the hurdle of being allowed 8 audio tracks maximum. I know I can add additional tracks after the bluray is compiled, which I can navigate to with the audio selection button on the remote, but they will have no means of selection from the menu. I want to be able to add buttons for the extra audio tracks to the menu, and link them to one of the 8 that I am allowed in Encore as a placeholder. Then add the additional audio tracks after the disc is compiled. After this, I want to redirect the buttons to the newly added audio tracks. Is this possible? I know how to alter the appearance of buttons with bdedit, but not what they do. If you can help, please chime in, I would really appreciate it. |
#174 | Link |
hello everyone i have a problem with this type of menu with coordinate and i cant find the file to edit the language pls help!
http://www.mediafire.com/file/05i00e...3/JAR.rar/file |
#175 | Link |
Hi mandeajupanu, for example, in the menu you loaded, you have to find the java class, use java decompiler jd-gui:
http://jd.benow.ca/ And edit with reJ: https://sourceforge.net/projects/rejava/ |
#176 | Link | |
#178 | Link |
Fix the java checksum after the change, read first post of the thread, create iso and use anydvd version 6.7.5.0:
http://www.oldversion.com/windows/anydvd-6-7-5-0 Last edited by ocean; 17th November 2018 at 23:41. |
#179 | Link | |
#180 | Link |
Follow the guide in the first post to the points: c, d, e, f, g, be careful to extract the single * .class file, work it with reJ, copy it to 00000.jar, create iso and use AnyDVD 6.7.5.0, check in settings / status / if the word fixed java appears.
| Display Modes | |
