Old 22nd January 2025, 05:47   #401  |  Link
taurusus
If there were "Link points" in the playlist besides the "Entry mark", then they should be added to each episode, but tsMuxer does not save them, they can be added to BDedit.
taurusus is offline   Reply With Quote
Old 22nd January 2025, 05:54   #402  |  Link
terrorindeed
Originally Posted by terrorindeed View Post
I'm working with a 3D BluRay, so I have 2 playlists in question.
Should both Playlist Mark points be identical?
I will take a look shortly and post back.
Fixed it. It was in fact the markpoints, half of them were missing on 00800.mpls and 01707.mpls. I copied them from the english bluray and loaded them, all is working now. thank you
terrorindeed is offline   Reply With Quote
Old 22nd January 2025, 06:44   #403  |  Link
terrorindeed
How would I go about unlinking subtitles to an audio track?
I changed japanese audio for french audio, and changed the english text translation japanese subtitle for spanish.
Now that the french audio plays, the spanish subtitles are hardcoded to the audio track.
I also cannot select the spanish subtitle when playing the english atmos track.
Old 22nd January 2025, 07:00   #404  |  Link
taurusus
This can be in a class or in a bin file, if there is one, need to look at the entire Jar folder.
Old 22nd January 2025, 16:06   #405  |  Link
terrorindeed
Im combing through the 00000.jar and not seeing anything obvious to the pg stream.
If its in the .bin file, what can I do ?
Old 22nd January 2025, 16:12   #406  |  Link
taurusus
You need to search there by the playlist number, but considering that all the values are there in hexadecimal form. I edit in Hex Editor Neo, open the converter in it and convert it from decimal to hexadecimal.
Old 28th February 2025, 17:17   #407  |  Link
erick
How do I know which Java code increases the size of the letter spaces? Which number do I change there to increase the size?
https://ibb.co/HN6mt8b
erick is offline   Reply With Quote
Old 28th February 2025, 17:21   #408  |  Link
taurusus
The first two digits are the coordinates in the png file, the next two are the length and height of the button.
Old 28th February 2025, 17:27   #409  |  Link
erick
Bdj
and if it is the width of the button spaces what would it be?
Old 28th February 2025, 17:32   #410  |  Link
erick
in this case I wanted to put Portuguese instead of English in this png
https://ibb.co/0pvbLknc
Old 28th February 2025, 17:34   #411  |  Link
taurusus
This should be viewed in a different class, and there should be at least two more classes for each menu.
Old 28th February 2025, 17:39   #412  |  Link
erick
searching the png file I found this bo.class
https://ibb.co/JYSHNy4
Old 28th February 2025, 17:42   #413  |  Link
erick
can you see the jar folder for me ?
https://www.mediafire.com/file/264af...d/JAR.rar/file
Old 28th February 2025, 17:48   #414  |  Link
taurusus
Do you have multiple menu languages there? Have you decided which menu you will edit?
Old 28th February 2025, 18:02   #415  |  Link
erick
Yes, I would like to change Spanish to Portuguese.
Old 28th February 2025, 18:09   #416  |  Link
erick
If you can tell me how to do it, I would be grateful, which class the files are in and how you made the modification, and if you can modify this one, send it to me as an example, even more grateful.
Old 28th February 2025, 18:25   #417  |  Link
taurusus
Do you want to completely redo the menu or just replace the audio track?
Old 28th February 2025, 18:32   #418  |  Link
erick
only subtitles audio track
Old 28th February 2025, 18:37   #419  |  Link
erick
and this the subtitle of the opening
https://ibb.co/pr56fcst
Old 28th February 2025, 18:43   #420  |  Link
taurusus
Do you choose Espanol in this menu? Which subtitles do you want to replace, also Espanol?
