#241 | Link |
I have a problem
Settings_ENG.png file in 00001.jar. I extracted the png file with 7zip. I edited it with Photoshop. I replaced the original file with 7zip. End : https://prnt.sc/xpbdpj Original : https://prnt.sc/xpbtjc 7zip screnshoot Before : https://prnt.sc/xpbgvc After : https://prnt.sc/xpbl45 How to decompile jar files. Original Jar File : https://yadi.sk/d/u_IjNydoMt-DTg Png file I edited with Photoshop : https://yadi.sk/i/Xkmm9WSueoGsqg |
#242 | Link |
Hi whiskerry, fix java in META-INF folder with AnyDVD, read guide points f) and g):
https://forum.doom9.org/showthread.php?t=152952 |
#243 | Link | |
Unfortunately I couldn't do it. |
#244 | Link |
Banned
Hi everyone! I want to ask for some help. I have a BD menu that has an IG menu. The IG menu part is in a m2ts file, but there is also an audio and a video file next to it. I can't mux the edited IG PNGs to the m2ts file. Can someone help me? Thx!
https://prnt.sc/102qtdh |
#245 | Link |
Hi Atibacsi84, this is a IGS menu multiplexed Video+Audio+Interactive Graphics, they exist menu IGS multiplexed or non-multiplexed, look at this advice:
https://forum.doom9.org/showthread.p...13#post1755113 there was also a program but it is no longer downloadable, only the demo: http://www.defsoft.com/igfix.html Last edited by ocean; 22nd February 2021 at 07:58. |
#249 | Link |
Buttons On Video
Hi Everyone
I am new to BDedit and think its great but am having a problem I hope someone may be able to help with? I have been using DVD Architect for years but it compresses the video and I want it left as original. I originally only wanted to replace videos in a BD stucture for original versions and thanks to BDedit I can now do this! I have now discovered a problem I can't work out how to change. Using DVD Architect I have put a button on the video to take me back to the most recent menu, which works on the original BD. I have copied the new video and clipinf into the BD structure and using BDedit changed times/video/audio etc in the playlist as usual but the button on the video now dosent work? In the Playlist (Original) there is a IG input and on the Playlist (New). However in the CLIPINFO (Original) section ProgramInfo there is an IG stream and CLIPINFO (New) it isn't there. I guess that this is due to me replacing the clipinf file. The IG stream when double clicked takes me to Menu (Original). I cannot see how I might be able to edit/duplicate this information and anything else I might be missing onto my edited BD so the button will work. (please see attached). If it is possible to recreate the button on the new video I would greatly appreciate the help, thx Best Regards Richard |
#251 | Link |
Hello and greetings ..
I hope somebody still coming here .. I have a Disney bluray with the menu words being scattared in .png files in the 00001 folder like this .. Link to image: https://ibb.co/Jk7zv09 I would like to know if there is a way to view and edit them in a better organized manner .. or have I no altarnative but to edit them, like they are, in Photoshop? NB. In BDedit and in the CLIPINF tab, I didn't find any streams with the IG type. Thanks alot. Last edited by white1; 20th December 2021 at 18:51. Reason: Image deosn't show |
#253 | Link |
Mosaics are an easy way for a blu-ray player to load a lot of images quickly for Java programming. Rather than having each one of those images as a separate PNG, they create a mosaic like this and can just load one giant image.
There should also be a text file that describes what is in the mosaic, with coordinates of each graphic. The large image is basically sliced up in memory according to the coordinate doc. The easiest way to edit the images to fit what you want exactly in the same space as what is already there. But if you need to make a graphic larger, then you'd have to re-create the mosaic image. Are there available tools that can convert this image back to a bunch of small images, and then back into a mosaic? Obviously the studios have tools that do it, but I can see this being useful in other markets, so maybe someone knows of something that can help easily... malimuc- the movie is Luca. |
#255 | Link | |
Coordinates, that's exactly what I'm looking for .. and as I'm trying to add a language with a set of completely different characters (Arabic), I had a hard time modifying a much more simple .png than the previous one, this one .. The blue-colored words are for "normal" buttons, and the yellow ones are for the same buttons "highlighted" .. modifying a blue word is simple, but the issue comes with the yellow as it appears in a slightly shifted place when you move the cursor .. clearly that is because it's not in the right place in the .png, and you can see in the image, the two words aren't in an easy manner to coordinate precisely .. Although that's not a big issue in a simple menu like this, it becomes annoying in others, like the main menu where words are in a strip and need more precision (and I'm kind of obsessed with precision) .. So rik1138, any idea where that text file might be located? and is it a file with a normal .txt extension or in another format? Thank you .. again!
#256 | Link | |
I don't have Luca, but looking at another Disney/Pixar title I see the same thing- Just the composite PNGs and some JAR files. So the coordinate information is in the .JAR somewhere. I did a simple Zip extraction of all of the JARs, and didn't see any plain-text files with coordinate info, so it has to be in one of the obfuscated .CLASS files... That's gonna make it hard to track down further unless you are familiar with decompiling Java files, and then recompiling and re-signing the JARs. Disney seems to have made it as hard as possible to mess with their menu code... (Or Deluxe, whoever is responsible for writing it...) You might just have to deal with editing the mosaic files themselves, and just living with the graphics not looking perfect. Or maybe try something a little different with the normal and select states- like have the normal be smaller, and the select get larger (instead of changing color), and maybe it'll be easier to tweak them in the mosaic so they center over each other... Some studio's Java code is definitely easier to manipulate than others... |
#259 | Link |
Big Bit Savings Now !
The JAR folder contents will tell.
Path: <Root>\BDMV\JAR\ Empty: no Java present Filled with .jar files and accompanying asset folders: Java present
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 6th January 2022 at 11:15. |
#260 | Link | ||
Suppose I want to modify a German IGS menu with BDedit. This menu: https://imgbox.com/RJwxmaQR For example, I want to replace the button “KAPITEL" for “CHAPTERS” or “TON” for “SOUND”. Is it possible to do this, right? But what about erasing a button, is it possible? For example, could the "DEUTSCH" button or the "ENGLISCH" button be removed? Is it impossible to erase buttons with BDedit and should I use another software for this? |
| Display Modes | |
