Old 18th June 2010, 10:30   #81  |  Link
*.mp4 guy
*.mp4 guy's Avatar
Actually all the talk of Deconvolution, helped me think of a name, "Reconvolution" since there isn't any reason to believe that its doing anything but making the picture look sharper by convolving it (albeit in a sneaky way). Also it works fine on stuff that isn't out of focus.
Settings for the posted examples were:
1 ReCon(str=8, rad=2, lmode=0)
2 ReCon(str=8, rad=2, lmode=1)
3 ReCon(str=8, rad=2, lmode=3)
Except from an older version, and therefore a bit worse overall. lmode 1 is now better, and lmode 2 pretty much replaces 3.
*.mp4 guy is offline   Reply With Quote
Old 18th June 2010, 17:35   #82  |  Link
rfmmars
Missing Tabs
I have only one tab and the screen doesn't look like on page one. Load Avisynth 2.58, and installed your program twice, what am I doing wrong? Have no problem with AVSp or AVSpMod.
Thanks
Uploaded with ImageShack.us
rfmmars is offline   Reply With Quote
Old 19th June 2010, 12:35   #83  |  Link
Archimedes
On Windows 7 i prefere to use the Windows Classic Style, that’s why the screenshots looks different. When you start the program, you will always see only one tab. After loading at least on image, you can click "Next" and then you will see the next tab and so on.
Archimedes is offline   Reply With Quote
Old 19th June 2010, 13:28   #84  |  Link
Archimedes
Added "ReCon" to the sharpening templates. May be someone would like to test it.
Old 19th June 2010, 16:56   #85  |  Link
markanini
Just played with the parameters of ReCon. Seems to work well!
markanini is offline   Reply With Quote
Old 19th June 2010, 16:59   #86  |  Link
rfmmars
Thanks
Thanks, that made it work for me, vert nice.
Richard
Old 21st June 2010, 15:10   #87  |  Link
Archimedes
Updated ReCon.
Old 26th June 2010, 10:43   #88  |  Link
markanini
Archimedes, how about a difference tab in addition to before-after? I think it would be very useful for denoising.
Old 28th June 2010, 08:38   #89  |  Link
Archimedes
This can be realized also with a simple script. I will think about it.
Old 28th June 2010, 13:45   #90  |  Link
Terka
good idea!
Terka is offline   Reply With Quote
Old 28th June 2010, 16:53   #91  |  Link
dlnm
Is there a script to remove some jpeg artifacts near the edges? or may be just use a deringing script such as HQDering?
dlnm is offline   Reply With Quote
Old 28th June 2010, 21:10   #92  |  Link
Archimedes
TNLMeans (maybe with Bx=By=0)?
Source (20 % JPG Quality)
TNLMeans
Old 29th June 2010, 08:42   #93  |  Link
Terka
look at fft3d:
http://www.aquilinestudios.org/avsfi...patiotemp.html
Old 29th June 2010, 17:56   #94  |  Link
dlnm
Thanks both Archimedes and Terka.
I have tried both TNLMeans and dfttest before but the results are not satisfied. It seems that fft3d did better in this case.
Old 29th June 2010, 18:53   #95  |  Link
Reuf Toc
Maybe you can try Deblock_QED in addition with FFT3D or TNLMeans (I didn't tested so I don't know if it works with Jpeg artifacts)
Reuf Toc is offline   Reply With Quote
Old 27th July 2010, 11:05   #96  |  Link
Archimedes
Updated the plugins NNEDI2 and EEDI3. The updates for NNEDI3 and the ImageMagick libraries already updated in the last "silent" update. Thanks to tritical and Wilbert.
For anti aliasing I added the script "SantiagMod" (could be improved with an edge mask, but this requires YV12 as input).
Source (PointResize from 3264x2448 to 1024x768) >>
SantiagMod(type="EEDI3", strh=1, strv=1) >>
SantiagMod(type="EEDI3", strh=2, strv=2) >>
SantiagMod(type="NNEDI3", strh=1, strv=1) >>
SantiagMod(type="NNEDI3", strh=2, strv=2) >>
Old 28th July 2010, 01:14   #97  |  Link
markanini
Awesome!
Old 8th September 2010, 10:58   #98  |  Link
Terka
Archimedes,
regarding my request for adding mo-compensation in Fritz Photo, please see:
http://forum.doom9.org/showthread.ph...20#post1160020
Old 28th September 2010, 18:51   #99  |  Link
Archimedes
Program didn't start in one case. So I've changed the windows message calls for registering and unregistering fonts.
Updated the plugins "FFmpegSource2", "Mask Tools 2" , "NNEDI3" and "SmoothAdjust".
Old 30th September 2010, 08:28   #100  |  Link
Revgen
Any chance you can add VCMohan's Seamer Resizer? http://forum.doom9.org/showthread.php?t=135735
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
