#1742 | Link |
Acid fr0g
I bought it online here.
Don't know how to address you to the correct BD in your country. However I don't think that there is more than one BD remastered edition. Should an archive of the playlist directory be enough for your tests?
@turment on Telegram |
#1747 | Link |
@tormento
Here is a very beta MPLS-enabled version of 32-bit DGIndexNV. Please test it on your Star Trek stuff. http://neuron2.net/misc/DGIndexNV.rar User Guide: * Decrypted BDMV folder on your hard drive. * Open an MPLS file in the BDMV/PLAYLIST directory. If multiple angles are present you are prompted for the angle. You can use BDInfo to help you to determine the correct MPLS file to open. I may add a tool to perform the latter function. * The required M2TS files are automatically loaded in order. I have not implemented audio adjustment yet for joining multiple M2TS files. Last edited by Guest; 22nd June 2010 at 03:26. |
#1748 | Link |
Derek Prestegard IRL
![]() Join Date: Nov 2003
Hi neuron2,
When using the latest nVidia driver for my QuadroFX 2800M GPU (257.21) and DG NV 2013, I get strange behavior. I can open the DGIndexNV application (all 32 bit for now), but nothing happens when I drop a supported file into the window. When I use the more conventional file -> open, the file I selected is in the file list, but DGIndexNV doesn't display any video or statistics. How curious! Derek
These are all my personal statements, not those of my employer :) |
#1749 | Link | |
I had a typo and thought I had a new license, but I entered a wrong character in the machine ID. The symptom was exactly the same. |
#1750 | Link |
If DGIndexNV 2013 does not display your video then you have not got a proper license in place (which means either you didn't relicense as required, you mistyped the machine ID in the license generator, or you did not create the license file as instructed and put it in the right place). As stated at my web site and several times here, as well as in the release notes, you need to regenerate your license using the online license generator. If you do not have a login then email me for one. You should have received one when you donated, unless you were an early adopter.
Sorry for the inconvenience. Get used to the process, because if the crackers bust my encryption, I'll have to double the key size.
#1751 | Link |
Indeed, I did
![]() Sorry, I thought by "new license" you meant when you created the web system, which I've been through a few times already! I'll get my **** relicensed. Thanks! Derek
These are all my personal statements, not those of my employer :) Last edited by Guest; 22nd June 2010 at 04:21. Reason: rule 4 |
#1752 | Link | ||
Acid fr0g
![]() Quote:
What do you mean with "audio adjustment"?
#1753 | Link | ||
#1760 | Link | |
From the DGIndexNVManual:
| Display Modes | |
