#1661 | Link | |
#1662 | Link |
İ'm sorry guys, i've been away from this thread for some time.
Is there any way to apply Spline36 resizing with CUDA? Edit: Or is that the right recipe ? Code:
LoadPlugin("C:\DGNV\DGMultiDecodeNV.dll")
DGMultiSource("C:\DGNV\Test\test_out.dgi")
Spline36Resize(720,576)
#1664 | Link |
New generation security notice
I'm about to cut over to my new generation security:
* Asymmetric key encryption using RSA to kill serial gens. * Various anti exe-cracking strategems. When the cutover occurs, the license generator will generate only licenses for version 2013 and greater, which will be released at the same time. I will reset all license counts to 0 so that you can get licensed for versions going forward. The license generator will be disabled for a short period during the cutover. My previous "security" was laughably weak. Last edited by Guest; 16th June 2010 at 03:17. |
#1669 | Link |
Yes, bilinear is all there is. And it's due to being the only resizer available in the nvidia api.
I'm sure if nvidia adds more resizing methods to the api, neuron2 will implement them into dgdecnv.
http://www.7-zip.org/ |
#1674 | Link |
DGIndexNV x64 to handle DVR-MS / WTV?
I've got a Win7 64-bit system running OTA HD in Windows Media Center, and it would be really cool if DGIndexNV x64 could handle the DVR-MS and WTV HD files that Windows 7 Media Center (7MC) produces.
An old thread suggested there is/was a GraphEdit solution, and I know that VideoRedo handles one or both of these formats, but it would be so much more elegant if it were possible to make only one stop at DGIndexNV and be ready to process and encode. And neither existing workflow works as a 64-bit native process, does it? Neuron2, could you be convinced to revisit adding this functionality, now that a 64-bit decoding/indexing/serving app is needed for these formats? |
#1676 | Link | |
Acid fr0g
I buy about 3 BD per week (and usually sell them after a month if not good enough) and look most of them on laptop during train travels. There are a lot of BD that get resized to strange resolutions from autocrop, both DGIndex and other encoding GUI's. I forgot most of those, the next one I'll report you. They usually get some strange horizontal resolution as some lateral pixels are black or very dark grey.
@turment on Telegram |
#1680 | Link | |
It's all in place now. You can download 2013 and generate your license. Let me know if it works. ![]() The page is: http://neuron2.net/licensing.html |
| Display Modes | |
