#2121 | Link | |
Unreasonable User
To clarify, there has never been (and still isn't) any DGDecodeNV dlls in my avisynth plugins directory. They're always explicitly invoked from the dgindexnv folder in my avisynth scripts. Last edited by Lyle_JP; 17th July 2010 at 13:50. |
#2123 | Link |
Unreasonable User
Okay, I reinstalled Forceware and now things appear stable (knock on wood). I remembered that earlier in the day Media Player Classic using DXVA gave me the only BSOD I've ever seen on Windows 7. I guess it done broke my Nvidia drivers!
#2125 | Link |
Mr. Sandman
@Lyle_JP: ensure your AVS script loads DGDecodeNV.dll and uses DGSource otherwise, edit it accordingly
im going to push a megui update along with dgindexnv update. that should address the issue but the AVS script should be re-created or edited as described here: http://forum.doom9.org/showthread.php?t=155702
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 17th July 2010 at 17:39. |
#2126 | Link | |
Learning Avisynth user
#2127 | Link |
Email me your license file, DGIndexNV INI file and machine ID. Tell me here what is the path where DGIndexNV.exe is and where license.txt is. Be sure to use 2021 if you are opening VOB or MPG.
You must be goofing up because you are the only person of thousands that can't make it work. |
#2128 | Link | |
C:\Video Related\DGIndexNV |
#2129 | Link | |
Just a friend
When I saved it as ANSI, it worked right away.
#2130 | Link | |
This is very frustrating.
#2131 | Link |
Correct. And if you have display of file extensions turned off you may inadvertently make a file named license.txt.txt.
I just returned from the pool and will look at the files you sent me, sumawo13. One thing to do is start DGIndexNV and look again at the machine ID. Make sure it matches what you put in the license generator. Sometimes you switch on or off a network card and it changes your machine ID. Last edited by Guest; 18th July 2010 at 01:26. |
#2132 | Link | |
Please check the reported machine ID in DGIndexNV Help dialog and make sure it matches the one you sent me. If it is correct I'll work with you by email using debug builds. |
#2133 | Link | |
#2138 | Link | |
I had also problems after I got new hardware, I forgot all steps required to get things working and needed some minutes to find out things. It seems if it fails to detect a license when trying to load a source file it just does nothing. A warning and instruction would be very helpful here, something like:
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 18th July 2010 at 10:31. |
#2139 | Link |
That's exactly what would make it very easy for crackers to find the entry point for the license check.
Edit: I suppose the license check could be done in a separate module/program which wouldn't expose the main application. However, when I load a file in DGIndexNV and I see the first frame I know that the license is working. Good enough for me. Last edited by Groucho2004; 18th July 2010 at 10:58. |
#2140 | Link |
I have some application to manage passwords and important things, I simple wrote a note there with all information needed like I do with other applications and tasks so I'm probably not gonna have problems again but when it just does nothing some might not expect a license issue, first I thought it might be a bad stream or something, later I found out I needed to regenerate my license for some reason.
| Display Modes | |
