#21 | Link |
Thanks for the info - sadly two of the documents linked in there don't exist anymore. I don't fully understand yet, but I hope I got the most important facts straight:
1.) Choosing 23.976, 29.97 (or 59.94) makes avs2bdnxml create the timecodes in the "drop"-way? 2.) Choosing 24 means it creates non-drop "23.976", choosing 30 means creating non-drop 29.97? 3.) There's currently no way to create 59.94 fps material the non-drop way? 4.) 25 and 50 are probably always created the non-drop way because of PAL? (Yet another reason why PAL is superior) More questions/requests: 5.) is choosing 24 really creating perfect non-drop 23.976 timecodes or will it go out of sync on long movies? (same question for 30) 6.) I find the usage of this really irritating and most programs seem to expect non-drop timecodes anyway so I suggest you add another switch for "drop" or "non-drop" and make non-drop the default. That's more user friendly as it does not let every new user of this program run into the same problem. |
#22 | Link | ||
2) Yes, for 30 the correct value of 29.97 is written to the XML too. 3) You should be able to give a frame rate of 60 and edit the XML. There is no error checking there, yet. 4) To my knowledge, this is correct. 5) The created timecodes should be correct. 6) It is quite irritating! I will definitely make the usage more clear in the next version (23.976, 29.97 and 59.94 will be non-drop by default, with 23.976d etc. for the drop version). I would have done so before, but I wasn't aware of the problem. That's the fun thing about A/V processing, there's always a surprise left.
#24 | Link |
I just finished the new version of avs2bdnxml. The overlapping timecode issue should be fixed. I optimized the code, too. Sadly, the optimization didn't help as much as I had hoped, since the majority of time (4/5 or so, in my 720p test) is spent in AviSynth/VSFilter. Non-drop timecodes are the default now, editing the XML file to correct the framerate should be no longer necessary.
#25 | Link |
Thx, seems to work just fine.
But I just noticed: Aren't you and I mixing non-drop and drop? As it is now, isn't "drop" the default, while "23.976d" is in fact "non-drop"?
#26 | Link |
No, I think everything is correct. In the non-drop time code thread the example given for a non-drop time code of a certain frame ("For example, 02:34:17:12 (non-drop-frame) is 277722 frames") matches the way it is now calculated in avs2bdnxml, and it seems to be correct from a theoretical point of view too.
#28 | Link | |
#29 | Link |
Thanks for reporting. Could you tell me how you checked that the subtitle is 1 frame off? Also, is shifted or is just the beginning or end wrong, and in which direction is it off? The time code in the XML looks correct, and I'm not sure I am looking at the SUP files in the correct way.
#30 | Link |
The easiest way is to use the following AviSynth-Script and skip through it frame by frame with VirtualDub:
BlankClip(240,1280,720,"YV12",fps=24000,fps_denominator=1001)
SupTitle("color_bdsup2sub.sup",false)
Crop(0,100,0,0)
AddBorders(0,0,0,100)
TextSub("color.ass")
Sometimes the subtitles appear 1 frame too late, sometimes they disappear 1 frame too late and sometimes both happens. In this specific sample it appears too late. I also created a .sup using PunkGraphicStream and the result was correct, so it's probably not an issue of SupTitle. Last edited by sneaker_ger; 19th August 2009 at 01:46. |
#31 | Link |
After thinking about it, it's probably an error in BDSup2Sub and BDSubEdit. The xml file clearly states that the subtitle should be displayed at "00:00:01:00", which is frame number 24 (or the 25th frame) and the resulting .sup is one frame too late. Please have a look at it anyway since I want to make sure it's really an error in both of the programs before contacting them.
Another thing - totally unrelated to my problem - I noticed is that even when using "23.976d" the "drop" parameter in the xml is "false". |
#32 | Link | |||
#33 | Link |
New version: I fixed the DropFrame bug and made detection of empty and different frames a bit more robust. Detection of SSE2 is now automatic.
#34 | Link |
Programmer (or just 教务长)
Thanks for this handy application! I wonder why I didn't see it earlier!
I have a small question. If for some reason the application executes exit() I get a crash window + : Code:
This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information. Code:
Progress: 100/100 - Lines: 0 - Done No events detected. Refusing to write XML file. Thank you once again! Dean |
#35 | Link | ||
#37 | Link | |
I did a lot of tests yesterday and I found it a bit slow and I remember you saying that most of the time is spent by avisynth, so here is what I did: Testing scenario: * video with resolution 1920x1080 @ 23.976fps * duration ~1hr 17mins (~110 000 frames) * SRT subtitles with 1000 lines * .styles file for VSFilter (no affect on speed) * .avs script, using full frame (1920, 1080 parameters) * avs2bdnxml.exe run time: 28 mins * bdsup2sub.jar run time: 8 mins * Total time for processing: 36 mins --------------------- Now, I decided that there is no need for avisynth to create a full frame 1920x1080, since subtitles usually use about 30% of the screen. Having this in mind and expecting quality input text subtitles (since I'm a translator and create subtitles), which won't have more than 2 or 3 lines of text I decided to reduce the frame sizes, processed by all applications involved (avisynth+avs2bdnxml+bdsup2sub): Before I start I am aware of font size, bottom offset and video resolution (of course), so I set a frame height to be not 1080 but 3.2*(font_type) mod 4. For example with 65pt font you get a frame of 1920x208 pixels. * video with resolution 1920x1080 @ 23.976fps * duration ~1hr 17mins (~110 000 frames) * SRT subtitles with 1000 lines * .styles file for VSFilter (using PlayResY: 208) * .avs script, using new frame (1920, 208 parameters) * avs2bdnxml.exe run time: 7 mins * bdsup2sub.jar run time: 2 mins * Total time for processing: 9 mins A small modification is needed in the .xml file before it is passed to bdsup2sub: All Y offsets (Y=0) are changed to Y= (original_frame_height - new_frame_height - bottom_offset), as in the example (using bottom offset of 32pixels), Y=1080 - 208 - 32 = 840. Also the "VideoFormat" option in the <Format/> section is set with the proper (original) resolution (i.e. "1080p") - I added the 'p' because I saw that bdsup2sub uses it, instead of using the plain numeric value. I guess "1080" is okay, too. I implemented these steps in multiAVCHD and now producing the .sup/PGS from SSA, ASS, SRT and microDVD sub text subtitles takes 5 to 10 times less, depending on the resolution. And thanks again for your contribution! Dean |
#38 | Link |
That's a nice speed up but you should probably make it optional since ASS is often used for translations of signs for example. (Or even simpler: translations of tv speakers in the background are often put at the top of the screen) That would destroy the subtitles.
If you want more speed you may want to try AssRender as a vsfilter alternative or PunkGraphicStream. They are not as powerful as vsfilter+avs2bdnxml and the latter has a serious problem with big subtitles at the moment but I expect them to get better. |
#40 | Link | |
Nice idea. Once I add real commandline argument parsing, I'll add a way to set X and Y offsets, so the XML can be generated correctly with smaller frame sizes. |
| Display Modes | |
