#202 | Link | |
the link for the Russian/English version does not work, maybe link is corrupted or file removed. |
#203 | Link |
Wow, I somehow missed that there are new posts in this thread. It's great to hear that it seems to be working well!
Too bad about the dead link for the GUI frontend. Last edited by ps auxw; 28th November 2013 at 00:34. |
#204 | Link |
okay, so I am trying this out but I am not the most adept at cli, so please advise what I am doing wrong.
I suspect it is something to do with -t I am not sure what we should be inputting for trackname. I simplified dir path and filenames for myself as much as I can for easy cli call, but still get an error. here is my cli and error Code:
C:\Users\jonathan>C:\Users\jonathan>""C:\avs2bdnxml\avs2bdnxml.exe" avs2bdnxml -t PYCAL -l eng -v 1080i -f 30 -a1 -p1 -b1 -u0 -m3 -o "C:\avs2bdnxml\PYCAL\PYCAL.xml" "C:\avs2bdnxml\PYCAL.avs" The filename, directory name, or volume label syntax is incorrect. Code:
C:\Users\jonathan>C:\Users\jonathan>""C:\avs2bdnxml\avs2bdnxml.exe" avs2bdnxml -l eng -v 1080i -f 30 -a1 -p1 -b1 -u0 -m3 -o "C:\avs2bdnxml\PYCAL\PYCAL.xml" "C:\avs2bdnxml\PYCAL.avs" The filename, directory name, or volume label syntax is incorrect. Code:
LoadPlugin("C:\MeGUI\tools\dgavcindex\DGAVCDecode.dll")
AVCSource("C:\LUPIN_RETURN_OF_PYCAL_CUSTOM\LUPIN_RETURN_OF_PYCAL\00002_1_01.dga")
LoadPlugin("C:\MeGUI\tools\avisynth_plugin\vsfilter.dll")
MaskSub("C:\avs2bdnxml\PYCAL_BD_SUBS.ass",1920,1080,29.970,85575)
#FlipVertical()
all the folders and paths do exist, as do the files I call (*.ass, *.avs) thanks for any help for a noob. Last edited by djmasturbeat; 20th January 2013 at 20:47. |
#205 | Link | |
As for the track name, it's just a string that is written to the XML file, like "Colored English subtitles" or whatever. For the rest, you apparently have the prompt "C:\Users\jonathan>" copied into your command line. You also have an extra quote (") at afterwards. Additionally, there shouldn't be an "avs2bdnxml" after you already specified the path to the executable. Try the following: Code:
"C:\avs2bdnxml\avs2bdnxml.exe" -t PYCAL -l eng -v 1080i -f 29.97 -a1 -p1 -b1 -u0 -m3 -o "C:\avs2bdnxml\PYCAL\PYCAL.xml" "C:\avs2bdnxml\PYCAL.avs" For your AVS, since you are directly specifying the frame size, number of frames etc. in the MaskSub call, you can throw out the parts about loading the video, since MaskSub doesn't use it anyway: Code:
#206 | Link |
thanks for the fast reply
I had entered 30 fps b/c in the first page it was mentioned it worked better to use that then to edit the xml output and put 29.97 back in. http://forum.doom9.org/showthread.php?p=1313944#post1313944 that said, when I use 30 I get an error Is all this no longer needed for input to Scenarist? Or if it is needed, do I need to change it somewhere else (like the avs script) to work? Then I would edit the XML back to 29.97 for scenarist? Other than that, thanks for the suggested cli call, it works with 29.97, I just need to be sure this won't botch input in scenarist, or go out of sync. thanks again. Code:
C:\Users\jonathan>"C:\avs2bdnxml\avs2bdnxml.exe" -t PYCAL -l eng -v 1080i -f 30 -a1 -p1 -b1 -u0 -m3 -o "C:\avs2bdnxml\PYCAL\PYCAL.xml" "C:\avs2bdnxml\PYCAL.avs" Error: Invalid framerate (30). Last edited by djmasturbeat; 20th January 2013 at 21:37. |
#210 | Link |
if scenarist parser rejected this xml, is this possibly because of my *.ass subtitle script, more than likely?
If it is in my script, is there a way I need to tell avs2bdnxml where to split an epoch for a screen with text in several places, or should this be automatic? If this isn't my issue, I will have to look in other places in the *.ass. also...okay, sorry for the ignorance here, am I supposed to have actual png files too? b/c I only have an xml output in the output folder. thanks again. Last edited by djmasturbeat; 20th January 2013 at 22:20. |
#211 | Link |
It won't work without the PNG files. Without them, Scenarist can't import, because there's nothing there. Check if they ended up in another folder, like the place you ran avs2bdnxml from or the avs2bdnxml folder. I should probably make it place the files in the same place as the XML file so this kind of thing doesn't happen...
#212 | Link |
ok, i found them.
since i ran cli from my username account (rather than cd first to C: or rather than using elevated command) it ended up in that main user directory terminal c:\users\myusername\*.png yeah, probably a good idea to force default to same dir as the xml and then add ability to change it if desired. thanks again. Last edited by djmasturbeat; 20th January 2013 at 23:28. |
#213 | Link |
avs2bdnxml works great. However I have been experiencing a strange issue with avs2bdnxml (2.05), which creates a flicker. It has happened really since my first project.
I am curious if anyone else has observed such a thing, or if anyone has suggestions what might be causing this on my end... or if this may be a bug, or what? I will try to make this as clear as I can. If need-be, ps auxw, I can send you copies of the files: ass, avs, cli, xml+png for a few projects. Any with an inline effect-hacked xml, will also contain the original output from avs2bdnxml (both have the same issue, detailed as follows). I will render my .ass files with the newest build of avs2bdnxml, and there is almost always one line that mysteriously is doubled/duplicated. It manifests itself in 2 forms: 1) 2 instances will appear in the same Epoch, with 2 Display Sets within that Epoch 2) It will show up as 2 consecutive Epochs In either case, the repeated instance of this single line will always have a small gap in the times between these 2 occurrences. I *can* fix it in ScenaristBD inside the PES editor (by removing the second instance, whether a new Epoch or new Display Set, and extending the ending time for the first instance to match the ending time of the second instance I remove). *But* in order to fix it, I have to first fully mux the Blu-ray (time and PC-intensive), then watch the full movie first, really scrutinizing every line. This is sort of a big deal. This could become a compounded bigger issue when I will be adding multiple subtitles (which I have planned), all requiring watching the movie in those sub language, paying close attention to every line. Usually the duplicated instance is happening near the start of a script, in the very first or second Epoch. But not always. The first time I noticed it, I thought at first it may have something to do with a preceding line (A Title) using a fade-in inline effect hacked into the xml. But whether I import in the original xml or the altered one, the result is the same. Then it happened on the very first subtitle in my most recent job, too. for example the first lines are as such: Code:
Dialogue: 0,0:01:24.64,0:01:26.73,Default,,0,0,0,,The year After Colony 195. Dialogue: 0,0:01:27.68,0:01:30.87,Default,,0,0,0,,A group of Colony citizens\Nhostile toward the Alliance... Dialogue: 0,0:01:30.95,0:01:34.64,Default,,0,0,0,,...sent young men to Earth\Non five Gundams. here is how this appears in Scenarist PES editor: here is another example from a different project, these screens I took a week, week and a half ago or so. These ones show in the same Epoch on 2 Display Sets, whereas the example above was 2 instances split across 2 Epochs: ![]() the xml file shows that this happens prior to importing to ScenaristBD: Code:
<Event Forced="False" InTC="00:01:24:14" OutTC="00:01:24:15"> <Graphic Width="671" Height="59" X="625" Y="978">00002030_0.png</Graphic> </Event> <Event Forced="False" InTC="00:01:24:17" OutTC="00:01:26:16"> <Graphic Width="671" Height="59" X="625" Y="978">00002033_0.png</Graphic> </Event> Code:
MaskSub("C:\avs2bdnxml\Waltz_v3.ass",1920,1080,23.976,129984)
#FlipVertical()
"C:\avs2bdnxml\avs2bdnxml.exe" -t Waltz -l eng -v 1080p -f 23.976 -a1 -p1 -b1 -u0 -m3 -o "C:\avs2bdnxml\Waltz_v3.xml" "C:\avs2bdnxml\Waltz_v3.avs" thanks for any input, and thanks again for this great software. Last edited by djmasturbeat; 3rd February 2013 at 15:32. Reason: stuffies |
#214 | Link |
This sounds like a really strange problem. I see nothing in your command line, or the quoted ASS or AVS that should lead to such a small pause, especially since line splitting isn't even abled. Could you frame step through the output of your AVS and make sure that the problem isn't on that side (e.g. the subtitle somehow doesn't get rendered for a frame during that line)? Do you have a way of testing whether it happens with SUP output? Either way, please send me one set of ASS+AVS+XML+PNG files for a project where this occurred and I'll look into it.
#215 | Link |
I have framestepped through the avs posted above, using avspmod, and noticed nothing like this on the .ass/.avs side.
In the Gundam example, the first sub line Dialogue: 0,0:01:24.64,0:01:26.73,Default,,0,0,0,,The year After Colony 195. in avspmod shows consistently from frame 2030 through 2079, with zero missing frames. No more subs till 2103, which is the next actual subtitle line proper: Dialogue: 0,0:01:27.68,0:01:30.87,Default,,0,0,0,,A group of Colony citizens\Nhostile toward the Alliance... Then all is okay after that. I will send a pm to you after I post this, with links to the examples above. The Lupin Pycal Ending scripts are really short, the Gundam Wing Endless Waltz is a full Movie, but only first line is affected. The main movie for Pycal was affected... but I forget which Epoch, so I left it out, but all 3 of the Pycal Endings were affected in the same way, which is where I first noticed this. edit: sup rendering... well, I would have to demux and remux the BD in other tools than Scenarist. But this will cause other issues. I have had someone confirm to me that tsmuxer will not support time conflicts (overlapping subs and different subs changing at different times) as well as split epochs, even if contained in sups output from your software (this is the fault of the authoring tools, not your software). I use all these "time conflicts" and split epochs regularly, and Scenarist handles it fine, and so does avs2bdnxml. But, for example these lines would not work in a sup imported to tsmuxer at all: Code:
Dialogue: 0,0:51:08.26,0:51:12.94,Endless Waltz SE ED Lyrics Bold - Romanji,,0,0,0,,itoshisa wo inori ni kaete
Dialogue: 0,0:51:08.26,0:51:12.94,Endless Waltz SE ED Lyrics Bold - English,,0,0,0,,{\c&&H8BDAFF&&}I change this longing to prayers for you
Dialogue: 0,0:51:12.84,0:51:13.48,Default,,0,0,0,,It's here.
Dialogue: 0,0:51:13.07,0:51:17.84,Endless Waltz SE ED Lyrics Bold - Romanji,,0,0,0,,kono kodou wo tsutaetai yo
Dialogue: 0,0:51:13.07,0:51:17.84,Endless Waltz SE ED Lyrics Bold - English,,0,0,0,,{\c&&H8BDAFF&&}If only you could hear this heartbeat of mine
I think the sup feature is nice for your software, but it appears that the shortcomings in some of the authoring tools will still require people to remove overlapping and time conflicting subs. I can't even begin to guess how tsmuxer and others handle fade effects and alpha and turning subs on x/y axis with frz*** inside the ass. I can do all this in .ass and avs2bdnxml handles it perfectly, and scenarist is okay with it, to a degree (too much and I will get buffer underruns in audio and video, even if the 4 MB buffer -- auto update ticked -- shows nowhere near capacity in PES editor). tl;dr, I don't think this would be an appropriate test for my subs, rendering to sup, since it would incur numerous other issues due to the authoring software needed to load a sup, rather than xml+png. It would not be a good litmus test, imo. Last edited by djmasturbeat; 3rd February 2013 at 16:34. |
#216 | Link | ||
This is very strange. I have tested all three of your lupin samples and could not reproduce the duplicate line stutter issue. The only reason that I could imagine is some weird heisenbug in the inline assembly parts (or some other, annoying memory corrupting bug). Could you please test whether this build without inline assembly works correctly for you? It is probably a bit slower though.
#217 | Link | ||
weird. I will try this other alt.build when I have time. I have no idea what a heisenbug is tho, btw :whistle: have to remember to google that later (going to bed now). from my understamding tsmuxer doesn't handle the overlapping subs and split epochs. I have not personally tested a sup or xml+png like this in tsmuxer, tbh. works great with scenarist and your tool, tho =) Quote:
if anyone knows a way for scenarist (BD or SD) to import a .sup, please tell me. i will try to report back soon. thanks for your sincere dedication. |
#219 | Link | |||
Specifically a heisenbug is one of those annoying bugs that disappear or change under observation. |
#220 | Link |
I've got a problem with avs2bdnxml in cmd line, following the tutorials and templates but whenever i try to run it i get "Only a Single input file is allowed."
my AVS script: AVCSource("C:\Users\Graham\Working Files\3 - BD SUBBING\3 - REAuthored\00002_1_01.dga") MaskSub("C:\Users\Graham\Working Files\3 - BD SUBBING\1 - Program Stuff\avs2bdnxml-2.05\avs2bdnxml-2.05\subs.ass",1920,1080,23.976,35160) My avs2bdnxml comand avs2bdnxml -t Undefined -l eng -v 1080p -f 23.976 -a1 -p1 –b1 –u0 -m3 -o ep1subs.xml ep1.avs not sure whats going on |
| Display Modes | |
