#384 | Link |
Earlier I had some trouble with TemporalDegrain, as part of a scene would bleed into the next on certain scene changes. So I looking for a temporal denoiser that will denoise without these faults, and I'm hoping MCTemporalDenoise is it. :) So, is this program 'safe' for general use? Kinda hate spending enother hundred or so hours on encoding, only to find out the output is messed up again.
I got the impression, from the other thread, that temporal degraining is inherently hard to accomplish; so maybe a truly 'safe' filter in that regard does not exist. But I'm hoping people's experiences with MCTemporalDenoise are good. Thanks.
Gorgeous, delicious, deculture! |
#385 | Link | |
LaTo INV.
Yes, it's safe for general use... Especially with limit=-1 & limit2=-1
#388 | Link | |
The underlying problem with using FFT3DFilter as prefilter is that FFT3D is generally not safe on scenechanges. Is there any special SC-protection in MCTD to compensate for that?
#389 | Link | |
LaTo INV.
If FFT3D really miss a scene change, try to use limit=x / limit2=x (instead of -1). "x" should be a positive value but the lowest possible (it's a simple limiting threshold). If the clip isn't so grainy, bt=1 should fix the problem also. Maybe I will implement a SC-protection in MCTD with SCSelect if the problem persist, but I doubt. Truly I use FFT3D all the time without problem, so I want to see a sample/script (with appropriate sigma) where FFT3D miss a scene change... Someone please? I am curious
#390 | Link |
It doesn't miss "a" scenechange. It does miss *every* scenechange. To my knowledge, temporal processing of FFT3DFilter simply doesn't check or care for that.
Just set bt=5,sigma=16, and watch what happens. Of course it's mostly not a problem with lower sigmas. But that doesn't mean the issue isn't there. It's just that the problem becomes much harder to notice (and that's why people aren't complaining) ... but *present* it is all the time.
#391 | Link | |
LaTo INV.
#392 | Link | ||
Just a friend
Don't have a specific sample clip handy right now but I get this on multiple different sources so I have to crop after or crop to mod16. Script example: Import("\AviSynth 2.5\plugins\MCTemporalDenoise.avs") Import("\AviSynth 2.5\plugins\GradFun2DBmod.v1.5.avs") SetMemoryMax(2048) AVCSource("something.dga") Crop(0,20,-0,-20) MT(""" MCTemporalDenoise(settings="very low",sigma=6,chroma=true,stabilize=true,GPU=false,ncpu=8,enhance=true,sharp=false) """, threads=8, overlap=16) Even though it's 1920x1040, mod16, it doesn't want to work, reports this isn't mod4. |
#393 | Link | |
LaTo INV.
#395 | Link |
Pig on the wing
I wonder if anyone with some programming skills could add scenechange detection if Fizick doesn't want to do that. It should be quite simple since there are many filters to borrow code from (of course it depends on the case, but still..)
#397 | Link |
I second that motion. :) I'm not versed enough in the intricacies of motion estimation to even begin to think about doing it myself; but it would be great if someone would actually fix it.
#398 | Link |
LaTo, I may not be doing it entirely right yet. :) I'm using this avs script on a 1-minute clip:
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\FFMS2.dll")
Loadplugin("C:\Program Files\AviSynth 2.5\plugins\FFT3DFilter.dll")
Loadplugin("C:\Program Files\AviSynth 2.5\plugins\mt_masktools-25.dll")
Loadplugin("C:\Program Files\AviSynth 2.5\plugins\mvtools2.dll")
Loadplugin("C:\Program Files\AviSynth 2.5\plugins\RemoveGrainSSE3.dll")
Loadplugin("C:\Program Files\AviSynth 2.5\plugins\TTempSmooth.dll")
Loadplugin("C:\Program Files\AviSynth 2.5\plugins\RepairSSE3.dll")
Loadplugin("C:\Program Files\AviSynth 2.5\plugins\deblock.dll")
Loadplugin("C:\Program Files\AviSynth 2.5\plugins\DctFilter.dll")
Loadplugin("C:\Program Files\AviSynth 2.5\plugins\EEDI2.dll")
Loadplugin("C:\Program Files\AviSynth 2.5\plugins\SangNom.dll")
Loadplugin("C:\Program Files\AviSynth 2.5\plugins\gradfun2db.dll")
Loadplugin("C:\Program Files\AviSynth 2.5\plugins\AddGrainC.dll")
video=FFVideoSource("M:\jobs\2010test.mkv").ConvertToYV12()
video=MCTemporalDenoise(video, settings="very high")
video=Crop(video, 0, 142, 0, -142)
return video
x264 remains at ca. 25% CPU. So, I guess I'm doing something wrong. Any hints?
#400 | Link |
There already is one. (Without SC detection, of course.)
| Display Modes | |
