Old 24th May 2010, 07:41   #361  |  Link
nibus
Telewhining
I'm having trouble when using MCTD on 1080p content. It works fine on everything else but errors out when using 1080p blu ray content:
LoadPlugin("C:\Apps\Multimedia\Video\MeGUI\tools\dgavcindex\DGAVCDecode.dll")
AVCSource("F:\Encode\BluRay\X2\BDMV\STREAM\X2.dga")
crop( 0, 140, 0, -140)
MCTemporalDenoise(settings="medium", edgeclean=true, deblock=true, enhance=true, chroma=true)
This is the error presented in MeGUI:
Error starting job
Exception message
Stacktrace:  at MeGUI.core.gui.JobWorker.startEncoding(TaggedJob job)
Inner Exception: null
nibus is offline   Reply With Quote
Old 24th May 2010, 07:51   #362  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Error starting job
Exception message
The script works outside of MeGUI?
LaTo is offline   Reply With Quote
Old 24th May 2010, 10:45   #363  |  Link
nibus
Telewhining
Never encoded outside of MeGUI... I like to be able to preview my filters first so I've steered away from the command line (with video anyway).
Old 24th May 2010, 11:08   #364  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Try opening the script for example in VirtualDub and see what happens.
Old 25th May 2010, 11:20   #365  |  Link
Assassinator
Assassinator's Avatar
AA still seems to be broken.
Used that test script I used last time here, pretty much exactly the same result.
Want me to upload a short sample + test script?
Assassinator is offline   Reply With Quote
Old 25th May 2010, 11:30   #366  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Yes it would be great!
Old 25th May 2010, 12:18   #367  |  Link
Assassinator
http://zingaburga.com/assassinator/S...CTD_AA_Test.7z
Old 25th May 2010, 13:58   #368  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Update 2010.05.25
v1.4.18 :
fixed anti-aliasing PP (was broken since v1.4.07)
updated MVTools-MaskTools-AddgrainC version
Old 25th May 2010, 14:56   #369  |  Link
kypec
User of free A/V tools
kypec's Avatar
Would be nice if you could include direct download links to required plugins in your first post.
It took me almost a day to locate appropriate version of this and that tool all over the net.
kypec is offline   Reply With Quote
Old 25th May 2010, 15:57   #370  |  Link
LaTo
LaTo INV.
LaTo's Avatar
I think it's a bad idea because it's not a mandatory to have exactly the same version as the documentation, it's just the version that I tested before releasing...
So newer versions should be better unless they introduce major changes in the syntax: if so, say here and I will update the script.
Old 26th May 2010, 09:23   #371  |  Link
kypec
kypec's Avatar
What I meant to say is: would be nice if there were direct links to sources, developer's pages, whatever else where the plugin's most recent/tested version is to be found. That's all. Searching for them via Doom9 forum or Google is quite tedious and time consuming. Why not to make life a bit easier for those who want to try your scripts? Thanks for your effort.
Old 27th May 2010, 19:54   #372  |  Link
sinz718
Thanks for this and all but seriously if scripts require other plugs/scripts why not supply them in a rar as well, or the whole thing in a rar?
Nevermind I guess this new plugins thread will help me, hopefully.
sinz718 is offline   Reply With Quote
Old 28th May 2010, 08:28   #373  |  Link
Die*wrek*show
DefaU1tABuser
After spending an entire afternoon searching for, and installing what seemed like every avisynth plugin known to man(I installed more than what I needed just to be sure), my hard work finally paid off.
I get the following error message-
"CAVIStream Synth: Unknown system exception - 0xc000001e at 0xcf23350"
I cannot get this working. So I am back to using plain old dfttest. Does anybody know what causes that error? I'm using
MCTemporalDenoise(Settings="very low",GPU=false)
all of my friends and loved ones are doomed...
Die*wrek*show is offline   Reply With Quote
Old 4th June 2010, 19:52   #374  |  Link
senseiam
Just a friend
Don't know if anyone else has seen this or not but I am getting "This CLIP is NOT MOD4" errors with mod4 resolutions. When I crop to mod16 script works, no problem.
I tried 1920x1080 (mod4) and I get "THIS CLIP IS NOT MOD4" error
I add Crop(0,4,-0,-4) for 1920x1072 (mod16) works like a charm.
Edit: Using latest version of script
senseiam is offline   Reply With Quote
Old 5th June 2010, 07:48   #375  |  Link
LaTo
LaTo INV.
LaTo's Avatar
I think it's a broken plugin, check one by one.
No problem with 1920x1080 in my side, provide the exact script used and a little sample clip please.
Old 6th June 2010, 15:45   #376  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Is is possible to make the MT function work with MCTemporalDenoise? I only get a garbled error message with MT("MCTemporalDenoise()"), also using triple quotes doesn't help.
Old 6th June 2010, 17:00   #377  |  Link
elguaxo
elguaxo's Avatar
It has always worked for me. Don't know if it makes a difference, but I'm still using AviSynth 2.5.7 + MT 0.7.
elguaxo is offline   Reply With Quote
Old 6th June 2010, 17:05   #378  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Strange, it seems to work on my computer but not on my dad's computer, from where I got the error message. The plugins and Avisynth versions should be pretty much equal, SEt's Avisynth 2.5.8MT installed. I've got to try emptying the plugins folder on his computer the next I visit my folks.
Old 6th June 2010, 17:09   #379  |  Link
LaTo
LaTo INV.
LaTo's Avatar
Sorry I never use MT version...
Old 11th June 2010, 15:58   #380  |  Link
darkelf5
I've tried it with AviSynth x64 build.
Everything works, except enabling GPU. I've tested it on a simple script
AVIsource("blablabla")
MCTemporalDenoise("GPU=true")
And this is what i get:
darkelf5 is offline   Reply With Quote
