#321 | Link | |
Try using the overlap parameter if you haven't yet. Last edited by osgZach; 26th March 2010 at 17:08. |
#322 | Link | |
Useless idea generator
I cannot find it either in x64 AVS 2.5.8 MT thread, either on Squid80 site.....
Vista64 Premium SP2 / C2D E4700 2.6GHz/ 6GB RAM/ Intel GMA 3100 / DTV Leadtek DONGLE GOLD USB2 / focused to DVB-T MPEG2 PS capture -> ProjectX -> M2V/MP2 -> MeGUI/AVS -> MP4[AVC/AAC] |
#323 | Link |
AFAIK, no .... DCTFilter hasn't been ported yet.
But if someone *would* port it, that would be a good occasion to eliminate the stripe-bug that DCTFilter has had ever since.
#324 | Link | |
LaTo INV.
#325 | Link |
I know
but even with Deblock=false my Vdub64 is crashing after few frames, and avs2avi64 after some dozens of frames.later I will try by cut away method to detect what plugin causes it. AVS64 itself seems to be fine. It is a pitty, because MCTD32 is nice and stable, but little speeding up would be handful.
Vista64 Premium SP2 / C2D E4700 2.6GHz/ 6GB RAM/ Intel GMA 3100 / DTV Leadtek DONGLE GOLD USB2 / focused to DVB-T MPEG2 PS capture -> ProjectX -> M2V/MP2 -> MeGUI/AVS -> MP4[AVC/AAC] Last edited by Poutnik; 31st March 2010 at 17:17. |
#326 | Link |
thanx brother .... I have ? here
LaTo this working with the mod 16 in this case i ca'nt edit the size for ex: I got with mod16 (1280 X 528 ) I got DAR 2.42.1 > but i want to fix it it must be in DAR 2.35.1 ( 1280 X 534 ) but the problem i can't because I will get the error : This is Not a MOD4 clop! >> in this case what I will do ??!! thanx alot LaTo ... Last edited by greatmagician; 5th April 2010 at 13:34. |
#327 | Link | |
LaTo INV.
or workaround: Addborders(0,2,0,0) MCTemporalDenoise(...) Crop(0,2,0,0) |
#328 | Link | |
but the DAR same ( 2.42:1 )this my script : Code:
crop( 0, 142, -2, -142) Spline36Resize(1280,528) Grainfactory3(1,1,1) GradFunkMirror() MCTemporalDenoise(settings="high") LaTo can u mke update for (MCTemporalDenoise) we want to make the control for The script not MCTemporalDenoise ... thnx
#329 | Link | |
LaTo INV.
Try: Code:
crop( 0, 142, -2, -142) Spline36Resize(1280,534) Addborders(0,0,0,2) MCTemporalDenoise(settings="high") crop(0,0,0,-2) Grainfactory3(1,1,1) GradFunkMirror() |
#330 | Link |
Hi guys,
what do you use to fast your encoding with MCTtemporalDenoise? This is my scrypt, where i'm trying to use MT : Code:
SetWorkingDir("d:\avs_plugins\AviSynthPlugins\")
LoadPlugin("MT.dll")
Loadplugin("d:\avs_plugins\warpsharp.dll")
LoadPlugin("SangNom.dll")
LoadPlugin("average.dll")
LoadPlugin("Degrainmedian.dll")
Loadplugin("removegrain.dll")
LoadPlugin("Repair.dll")
LoadPlugin("gradfun2db.dll")
LoadPlugin("DGAVCDecode.dll")
LoadPlugin("DGDecode.dll")
loadplugin("fft3dfilter.dll")
loadplugin("hqdn3d.dll")
LoadPlugin("convolution3d.dll")
LoadPlugin("undot.dll")
LoadPlugin("mvtools2.dll")
LoadPlugin("mt_masktools-26.dll")
LoadPlugin("TTempSmooth.dll")
import("d:\avs_plugins\denoisers\MCTemporalDenoise.v1.4.08.avsi")
import("d:\avs_plugins\denoisers\GradFun2DBmod.v1.5.avsi")
import("LSFmod.v1.9.avsi")
LoadPlugin("GradFun2DB")
LoadPlugin("D:\Program Files (x86)\StaxRip\Applications\AviSynth plugins\DGAVCDecode.dll")
AVCSource("L:\test_5d2\MVI_0135 temp files\MVI_0135.dga")
How could I set MT in the correct way to use all my i-920 cores in the script above? Or, if you could suggest me alternative paths to use my i7, i would be happy! Thanks in advance --------------- P.S. "settings high" is the extreme setting of MCTtemporalDenoise? because i want to test it on my video shooting at 12800 iso. ciao!
P6T| 12Gb DDR3| i7-920 D0@3.8Ghz@1.168v+NOCTUA NH-U12P| Liberty 620| Stacker|2xRAID0 (4x500gb) Seag.72k.11| Seag. 500gb 72k.12| Seag. 1.5Tb 72k.11| GTX470@668/1843| U2410 24"| Se7en x64 on VRapt 300gb |
#332 | Link |
thanks for your suggestion.
it starts and it gets 20% of cpu more or less...the encoding anyway takes me jurassic time. if u have any other suggestion i'm happy to test it! :-) ciao!
#333 | Link | ||
Actually in reserve
Hi there,
MCTemporalDenoise(settings="high") will your encoding time be paleolithic (even slower as it should be) ? ![]() If not slower something is wrong in your config and/or settings Be aware that MCTD is a slow (to very slow) filtering process! Quote:
If not 2.58 MT from SET (MT-avisynth+ MT dll) or 2.6 MT-avisynth from SET you may not have stability or performance accordingly... For an i7, you could try to change the number of threads from 4 to 6 to 8 or even more and see if any speed improvement. You did not state if you are encoding to xvid, x264 or other codec and what GUI you are using for that purpose; vfw xvid/divx and gui are known to be suboptimal compared to x264 and non vfw GUI for multicores ... Did
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first Want to exchange on AutoGK? try doom10.org In reserve (inactive) for an undefined period of time. |
#334 | Link |
i'm using avisynth dll and MT dll updated to 2010 jan.
tried to set 8 core but no speed improvement since my "raw" source is 45mbit avchd from 5d mark II, i usually recompress to h264. Since the direct conversion to h264 of the script above in megui is more tha paleolithic, i'm encoding (now) in lagarith loseless by vdub. (passed 5h30' and i encoded 1100 frames !!!). so you suggest to set MCTtempDen to "medium" settings? do i get an heavy denoise the same? because from some preview i've seen that setting "high" seems to be amazing. It really drops alla the noise produced by my camera at 12800 iso but i can see a really amount of detail that camera captured. thank you very much, ciao!!
#335 | Link | ||
Actually in reserve
This: is not SET build. Use it at your own risk ![]() Rather, see: http://forum.doom9.org/showthread.php?t=148117 Quote:
I also asked you to test with and without MT to be sure your avisynth+MT configuration is correct and you have a REAL speed gain with MT. From a quick and dirty test encode with my Q9400 @3200 (1pass-Cq3, Xvid-encode, SD): MCTemporalDenoise(settings="high")............ is +/- 5.5 fps MT("""MCTemporalDenoise(settings="high")""") is +/- 9.5fps Quote:
![]() Seriously, this is the MCTD thread, I answered on your MT problem only. For MCTD, review posts on differences between settings and tuning by LATO, very interesting. Did
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first Want to exchange on AutoGK? try doom10.org In reserve (inactive) for an undefined period of time. Last edited by BigDid; 10th April 2010 at 20:54. |
#336 | Link |
Sorry maybe i read in the not correct way what you wrote before!
FRom what you are sayng there is something wrong in my config, beacuse with my i7 i have to go at least at your speed...And i'm really far from 5 fps...since i don't reach 1fps !!! which MT and avisynth .dll do you use? Which problem do you think i could have in my config? many thanks in advance and have a nice weekend!! ciao!
#337 | Link | ||||
Actually in reserve
See basics: http://avisynth.org/mediawiki/MT_support_page and/or http://avisynth.org/mediawiki/MT This is still MCTD thread and if you need more tips for MT, you'd better continue in the SET MT thread or create one (I will not post in Jeremy's thread as I don't use it). Did
#338 | Link |
The AA portion of MCTD seems to have broken between 1.3.09 and 1.4.08... Or am I just doing something really wrong?
New behaviour ==> http://zingaburga.com/assassinator/I...MCTD1408AA.png Old behaviour ==> http://zingaburga.com/assassinator/I...MCTD1309AA.png MCTemporalDenoise(aa=true,useEEDI2=false,maxd=48,aathr=16,stabilize=true) Oh yeah, these images are produced for the sole purpose of explaining what I'm talking about in this post, so please don't tell me I should be using aa/maa/daa/whatever instead, or I shouldn't be using MCTD/denoise/whatever, since I'm not even going to be encoding this stuff. Last edited by Assassinator; 23rd April 2010 at 17:00. |
#339 | Link | |
LaTo INV.
I will look at this next month, study now
| Display Modes | |
