Old 20th June 2022, 11:19   #1  |  Link
tormento
Acid fr0g
tormento's Avatar
New challenge: Trigun modern restoration
Perhaps it's time to challenge again the community against one of the most abused DVD in history: Trigun.
It's told nobody could really fix it, since decades.
Is there any brave AVS user able to fix it and properly create a 23.976 good restoration?
Here a clip.
@turment on Telegram
Old 24th June 2022, 14:29   #2  |  Link
SaurusX
I've seen a pretty good AI upscale of Trigun. But what seems to be the general problem with it? You mention 23.976, so is there something off in regards to way pulldown is implemented?
SaurusX is offline   Reply With Quote
Old 24th June 2022, 16:49   #3  |  Link
ChaosKing
I think the biggest challenge are the halos.
My quick encode https://www.dropbox.com/s/ke7jgc9ent...rigun.mkv?dl=1
Encoded with x264 medium, so don't expect ultra quality.
I think some antialiasing should be applied too.
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
Old 25th June 2022, 07:53   #4  |  Link
Selur
Selur's Avatar
@ChoasKing: Vapoursynth VSGAN(2x_LD-Anime_Skr_v1.0)+DeHalo_Alpha, does a good job with the halos (but is horribly slow on my gpu old, 0.1-0.3fps): https://imgsli.com/MTE0MDU0
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 25th June 2022, 09:10   #5  |  Link
tormento
Acid fr0g
tormento's Avatar
Look at the clip.
Old 25th June 2022, 09:14   #6  |  Link
tormento
Acid fr0g
tormento's Avatar
Nothing available with AVS+?
You did a good job but I see lot of detail loss.
There is the deinterlace/pulldown issue to to be solved properly.
Old 25th June 2022, 09:15   #7  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by ChaosKing View Post
My quick encode
Please post script too.
Old 25th June 2022, 13:26   #8  |  Link
Selur
Selur's Avatar
If it's just about cleaning the lines, you could simply mask vsgan with an edgemask. (probably best apply DeHalo_Alpha also masked)
in Avisynth: DeHalo + LUTDeRainbow might be worth a try.
Old 25th June 2022, 15:39   #9  |  Link
ChaosKing
PHP Code:
import vapoursynth
as vs
import lvsfunc
core
vs.core
clip
core.lsmas.LWLibavSource(r'D:\Download\VTS_01_7.VOB')
clip clip.vivtc.VFM(0)
clip clip.vivtc.VDecimate()
o=clip
clip
core.fmtc.bitdepth(clipbits=16)
haf.SMDegrain(cliptr=3prefilter=2).avs.DGDenoise(strength=0.1blend=0.1)
clip core.fmtc.bitdepth(clipbits=32)
clip clip.bm3dcuda.BM3D(sigma=3radius=4ref=core.fmtc.bitdepth(rbits=32)).bm3d.VAggregate(radius=4)
clip lvsfunc.dehalo.masked_dha(clipref=Nonerx=1.77ry=1.77brightstr=1.0darkstr=0.0lowsens=50highsens=50rfactor=3.0maskpull=48maskpush=192show_mask=False)
clip lvsfunc.dehalo.fine_dehalo(cliprx=2.2ry=2.2
Nothing fine tuned, just quick and dirty test.
w2xncnnvk.Waifu2x() upscale looks also not bad.
@Selur looks good, will try it next. Have you also tried 2x_BIGOLDIES_415000_G.pth ? The sexample looks very good https://imgsli.com/MzI0MDc
Old 25th June 2022, 16:32   #10  |  Link
kedautinh12
Sample script 100% vapoursynth. Any relate avs+??
Old 25th June 2022, 17:25   #11  |  Link
ChaosKing
Same scripts exist for avs+ too. Use brain.exe to convert
Old 25th June 2022, 18:04   #12  |  Link
kedautinh12
I know but script from Selur need VSGAN(don't support avs+ too)
Old 25th June 2022, 18:30   #13  |  Link
ChaosKing
Time to learn something new 😀. Or simply use vapoursource...
Old 25th June 2022, 19:03   #14  |  Link
tormento
Acid fr0g
tormento's Avatar
As we are talking about... Waifu or GAN?
Any chance to see native portings?
Old 26th June 2022, 05:10   #15  |  Link
Selur
Selur's Avatar
Waifu2x is available for Avisynth (https://github.com/sunnyone/Waifu2xAvisynth), but probably a lot slower than the Vapoursynth version since from the looks of it it has not gpu support.
-> https://imgsli.com/MTE0MTgz has even more detail loss in the background but cleans it up nice
Old 26th June 2022, 09:01   #16  |  Link
tormento
Acid fr0g
tormento's Avatar
Can you post me some example scripts for VS and GAN + WAIFU?
I am totally newbie in that regard.
Old 26th June 2022, 10:59   #17  |  Link
Selur
Selur's Avatar
Here's an example where I load and apply 2x_AnimeClassics_UltraLite_510K with VSGAN and downscale to the original resolution afterwards:
PHP Code:
# Imports
import vapoursynth as vs
import os
import sys
# getting Vapoursynth core
core vs.core
# Import scripts folder
scriptPath 'i:/Hybrid/64bit/vsscripts'
sys.path.insert(0os.path.abspath(scriptPath))
# Loading Plugins
core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/Support/fmtconv.dll")
core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2.dll")
# Import scripts
import mvsfunc
# source: 'G:\TestClips&Co\files\test.avi'
# current color space: YUV420P8, bit depth: 8, resolution: 640x352, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: progressive
# Loading source using FFMS2
clip core.ffms2.Source(source="G:/TestClips&Co/files/test.avi",cachefile="E:/Temp/avi_6c441f37d9750b62d59f16ecdbd59393_853323747.ffindex",format=vs.YUV420P8,alpha=False)
# Setting color matrix to 470bg.
clip core.std.SetFrameProps(clip_Matrix=5)
clip clip if not core.text.FrameProps(clip,'_Transfer') else core.std.SetFrameProps(clip_Transfer=5)
clip clip if not core.text.FrameProps(clip,'_Primaries') else core.std.SetFrameProps(clip_Primaries=5)
# Setting color range to TV (limited) range.
clip core.std.SetFrameProp(clip=clipprop="_ColorRange"intval=1)
# making sure frame rate is set to 25
clip core.std.AssumeFPS(clip=clipfpsnum=25fpsden=1)
# changing range from limited to full range
clip core.resize.Bicubic(cliprange_in_s="limited"range_s="full")
# Setting color range to PC (full) range.
clip core.std.SetFrameProp(clip=clipprop="_ColorRange"intval=0)
# adjusting color space from YUV420P8 to RGB24 for vsVSGAN
clip core.resize.Bicubic(clip=clipformat=vs.RGB24matrix_in_s="470bg"range_s="full")
# resizing using VSGAN
from vsgan import ESRGAN
vsgan
ESRGAN(clip=clip,device="cuda")
model "I:/Hybrid/64bit/vsgan_models/2x_AnimeClassics_UltraLite_510K.pth"
vsgan.load(model)
vsgan.apply() # 1280x704
clip vsgan.clip
# resizing 1280x704 to 640x352
# changing range from full to limited range
clip core.resize.Bicubic(cliprange_in_s="full"range_s="limited")
# adjusting resizing
clip core.fmtc.resample(clip=clipw=640h=352kernel="lanczos"interlaced=Falseinterlacedd=False)
# adjusting output color from: RGB48 to YUV420P10 for x265Model
clip core.resize.Bicubic(clip=clipformat=vs.YUV420P10matrix_s="470bg"range_s="limited"dither_type="error_diffusion")
# set output frame rate to 25.000fps
# Output
clip.set_output()
Here I use Waifu through VSGAN:
PHP Code:
# Imports
import os
import sys
core vs.core
# Loading Plugins
# Import scripts
import mvsfunc
vsgan
model "I:/Hybrid/64bit/vsgan_models/4x_WaifuGAN_v3_30000.pth"
vsgan.load(model)
vsgan.apply() # 2560x1408
clip vsgan.clip
# resizing 2560x1408 to 640x352
# Output
clip.set_output()
Here's an example where I use Waifu2x nvk:
PHP Code:
# Imports
core vs.core
# Loading Plugins
core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/ResizeFilter/Waifu2x-cnn/waifu2x-ncnn-Vulkan.dll")
# adjusting color space from YUV420P8 to RGBS for vsWaifu2xNvk
clip core.resize.Bicubic(clip=clipformat=vs.RGBSmatrix_in_s="470bg"range_s="limited")
# resizing using Waifu2xNvk
# forcing model to 'cunet', upconv can not be used without upscaling
# no resizing only filtering using Waifu2X nvk
clip core.w2xncnnvk.Waifu2x(clip=clipscale=1model=2fp32=False)
# adjusting output color from: RGBS to YUV420P10 for x265Model
# Output
clip.set_output()
Cu Selur
Old 26th June 2022, 11:33   #18  |  Link
ChaosKing
You should format your code as php, it's much more readable this way bcs comments are highlighted differently.
Old 26th June 2022, 13:08   #19  |  Link
Selur
Selur's Avatar
adjusted post code -> php
Old 26th June 2022, 14:35   #20  |  Link
tormento
Acid fr0g
tormento's Avatar
Cu Selur
Thanks!
Can you please tell me the differences between the upscaling types and what can support CUDA? I have a 1660 SUPER with 6GB of memory. I don't even know if it's enough or I should limit VS threads in some way.
Why don't you apply any IVTC of pulldown or deinterlace of any sort? The DVD source is awful.
