31st May 2024, 07:54 | #83 | Link |
Big Bit Savings Now !
Thank you, Kurt.noise and Wilbert.
31st May 2024, 14:45 | #84 | Link | |
So it would appear the answer is, yes, it does. |
31st May 2024, 21:04 | #86 | Link |
This thread is about MeGUI 6666, only 64 bits.
Try here: MeGUI: General Questions and Troubleshooting Thread But I think than nobody is working on it. You can try update the tools by yourself.
1st June 2024, 03:40 | #88 | Link | |
sorry, my fault...should be ok now. |
1st June 2024, 08:20 | #91 | Link | |
nope...I just pushed some more recent tools. Nothing tested from my side on 32 bits and I wont be. |
1st June 2024, 17:36 | #93 | Link | |
If you really need use that MeGUI version download this package x265 and copy the x265.exe from the Win64 folder to your ...megui\tools\x265\x64 folder.
1st June 2024, 18:01 | #94 | Link |
@Kurt.noise
When I update my MeGUI_32 version I found than try reinstall also Mp4Box, the new package have the mp4fpsmod folder empty and the updater delete the previous content with nothing to replace it, and remain in reinstalling status. The same happen updating the old MeGUI 64
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 1st June 2024 at 18:21. Reason: add info |
1st June 2024, 22:35 | #96 | Link |
Sure, but with MeGUI-6666 I do not use the updater, I replaced myself all the new version to test them.
For that I say this to Kurt, to modify the packages in the server.
2nd June 2024, 09:07 | #97 | Link | |
I still use 32bit and I have this problem on that version. |
6th July 2024, 23:55 | #100 | Link |
No problem here, but this thread is about MeGUI 6666 (only 64 bits)
Tested also in MeGUI x86, where the last version in Update is 20231117 1156.0.0.0., without problems with L-SMASH-Works 20240408 v1194.0.0 For help about MeGUI x86 use MeGUI: bug reports and feature requests
