6th September 2011, 14:46 | #18141 | Link |
EVR-CP supports hardware deinterlacing, you just need to keep the flag checked.
6th September 2011, 14:48 | #18142 | Link |
Yes but why does it work on EVR normal without a flag then ? and the obvious cool thing about it that you can even push it wrong streams it will do them right (not with every Decoder though it seems) which EVR-CP fails because it needs the flag to deinterlace anything @ all and wrong flaged streams then go hi wire
If Intels Hardware should do the work here perfect why not leverage this and build the whole playback behaviour around it (not sure though how Nvidia does in the same scenario) And if they can decide where it works via the Driver we should push them to support also Custom Renderer like EVR-CP
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 6th September 2011 at 16:20. |
9th September 2011, 19:06 | #18143 | Link | |
Have you see example and find the problem?
10th September 2011, 00:39 | #18144 | Link |
Yes - i see. But - if open and play video, a see subtitle at 13 second, as and with ffdshow. Subtitle show on 1 second - with ffdshow too.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 10th September 2011 at 03:04. |
10th September 2011, 10:33 | #18146 | Link | |
Firefox User
I wonder if this VSFilter patch be applied to the tree?
http://direct264.svn.sourceforge.net...92&view=markup Quote:
10th September 2011, 15:22 | #18147 | Link | |
I try since two years with all version of mpc-hc and it has never function (I had ask to casimir 666 to add support of bluray sub. He began to work upon but he had arrested before correcting all the bugs. Casimir have seen the problem but he said that he hadn't the time to correct (he started to work upon the support of dxva)). With ffdshow it works since the support of hd subs by albain. example with mpc-hc sub renderer at 13seconds video here: http://www.zshare.net/video/944028910121c37b/ with fddshow sub renderer at 13 seconds video here: http://www.zshare.net/video/94402815ee4780d4/ bugtracker https://sourceforge.net/apps/trac/mp.../48#comment:22 If you want, I can upload anew 3gb example in bugtracker because between 7minutes and 9 minutes there are many other examples of this problem. edit: I succeed to give you 2 min showing many problems with sub renderer with mpc-hc. Video take 500mb and I will give you tomorrow. Last edited by ikarad; 10th September 2011 at 21:27. |
10th September 2011, 19:22 | #18148 | Link |
A 3 GB sample is probably illegal to share. To be on the safe side, and to have a much smaller sample, can you try to demux the subtitles with eac3to, for instance?
http://forum.doom9.org/showthread.php?t=125966 The command line syntax is: eac3to sample.m2ts 3:track3.sup 4:track4.sup I assume you want to use the same video as your previous sample? To select only one of the two subtitle tracks, you can also specify only "3:track3.sup" or "4:track4.sup". We can easily test these subtitles with any kind of dummy video.
development folder, containing MPC-HC experimental tester builds, pixel shaders and more: http://www.mediafire.com/?xwsoo403c53hv |
10th September 2011, 21:14 | #18149 | Link | |
Hi-Fi Fans
11th September 2011, 00:09 | #18150 | Link |
As i say - give a sample to test, no another way to detect problem.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
11th September 2011, 09:43 | #18151 | Link | ||
here an other example
http://www.zshare.net/info.html?9441...1d1b3443d2b222 for example at 11-12 seconds without ffdshow subrenderer "hold me gently" and "mechanical desing by......" are not displayed. With ffdshow "hold me gently" and "mechanical desing by......" are displayed. other example (there many examples in this sample) at nearly 1min47seconds lots of subs are not displayed with mpc-hc sub renderer like "training vaisseau spiegel", "no battleships, a such","but a vessel is.... the asteroids.","sub lightspeed booster", "you could use its external booster" etc... I add this sample also at bugtracker https://sourceforge.net/apps/trac/mp.../48#comment:23 Could you if you can correct this bug of subrenderer in mpc-hc? Quote:
11th September 2011, 11:25 | #18152 | Link | |
11th September 2011, 11:50 | #18153 | Link | |
1) at 1min48, all subs are displayed but when two subs must be displayed in the same time with your version the first is dsplayed and disappeared before the second sub. With ffdshow the both sub are displayed (it's like with power dvd for example) 2) There are other time where one sub stay not displayed I will give you video to show problem when I would upload them |
11th September 2011, 12:04 | #18154 | Link | |
11th September 2011, 12:10 | #18155 | Link | |
Will you correct bug with display 2 sub at one time? Last edited by ikarad; 11th September 2011 at 12:13. |
11th September 2011, 13:10 | #18156 | Link |
Probably not - or will it take a long time, sorry.
11th September 2011, 13:15 | #18157 | Link |
Cry.
Although it's the problem the most important for me with subrenderer in mpc-hc . With this problem subrenderer is useless with blu-ray because in anime bluray movie, there are lots of double sub. Moreover there is some subs not displayed even with your correction of bugs. here with mpc-hc "passing through the scorching sunshine" is not displayed http://www.zshare.net/video/94411609e03aad8c/ with ffdshow sub renderer "passing through the scorching sunshine" is displayed http://www.zshare.net/video/94411591e65c25ab/ Last edited by ikarad; 11th September 2011 at 13:19. |
11th September 2011, 23:38 | #18159 | Link | |
12th September 2011, 00:27 | #18160 | Link | |
http://www.mediafire.com/?r367kbp7p9but I'd like to mention that the BE mod is of course still requiring the hotkey fix discussed earlier. janwillem is there any chance you could pick up the BE mod and integrate it into MPC? |
