Old 31st January 2021, 19:42   #681  |  Link
tormento
Acid fr0g
tormento's Avatar
PHP Code:
SetMemoryMax()
SetFilterMTMode("DEFAULT_MT_MODE"2)
LoadPlugin("D:\eseguibili\media\DGDecNV\DGDecodeNV.dll")
DGSource("F:\In\1_50 colore venuto dallo spazio, Il\colore.dgi",ct=140,cb=140,cl=0,cr=0)
CompTest24(1)
SMDegrain (tr=4thSAD=500refinemotion=falsemode=0contrasharp=falsePreFilter=4truemotion=trueplane=4chroma=truen16_out=true)
Prefetch(6
x265 slow --input-depth 16 --dither 4.43 fps
Perhaps the best compromise yet.
@turment on Telegram
Old 31st January 2021, 21:27   #682  |  Link
real.finder
Originally Posted by tormento View Post
Please explain me why explicitely define prefilter is faster than implicitely use prefilter=4.
in the code I post it will be 8bit for prefilter, and it will be faster as Boulder told you
Doing it in 8 bits gives you a nice boost without actually sacrificing quality.
See My Avisynth Stuff
Old 1st February 2021, 08:05   #683  |  Link
tormento
Acid fr0g
tormento's Avatar
The bold part is the one I need clarification about:
ConvertBits(10).SMDegrain(tr=4, thSAD=500, refinemotion=false, mode=0, contrasharp=false, PreFilter=SMDegrain_prefilters(prefilter=4,a=1,d=1,h=7.0), truemotion=true, plane=4, chroma=true)
Old 1st February 2021, 09:43   #684  |  Link
tormento
Acid fr0g
tormento's Avatar
SMDegrain(tr=4, thSAD=500, refinemotion=false, mode=0, contrasharp=false, PreFilter=ConvertBits(8).SMDegrain_prefilters(prefilter=4,a=1,d=1,h=7.0), truemotion=true, plane=4, chroma=true)
SMDegrain (tr=4, thSAD=500, refinemotion=false, mode=0, contrasharp=false, PreFilter=ConvertBits(8).SMDegrain_prefilters(prefilter=4,a=1,d=1,h=7.0),, truemotion=true, plane=4, chroma=true, n16_out=true)
actually turned out to be slower than
SMDegrain (tr=4, thSAD=500, refinemotion=false, mode=0, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true, n16_out=true)
4.27 fps vs 4.43.
P.S: n16_out=true doesn't need to have ConvertBit(16) in front of SMDegrain, does it?
Old 1st February 2021, 18:49   #685  |  Link
real.finder
as the name said it's just prefilter function of SMDegrain
4.27 fps vs 4.43.
they should be the same in that case
edit: try add ,device_type="GPU" to SMDegrain_prefilters
anyway there are no point of using n16_out with external PreFilter like this
n16_out is like the lsb_out but a bit faster and only work with 8bit input
Old 1st February 2021, 19:39   #686  |  Link
tormento
Acid fr0g
tormento's Avatar
Ok, but why to use it instead of prefilter=4 in the 8 bit source case?
Ok, why? I thought n16_out is used to output 16 bit depth video. Am I wrong? What should I use to deliver a 16 bit video out from *ANY* input source?
So if I have a 10/12 bit input, have I to ConvertBits(16) before using SMDegrain?
Old 1st February 2021, 20:19   #687  |  Link
real.finder
who say use it in 8 bit source? you asked for speed optimization and I give you some, no more no less
it is but it only work for 8bit input, see here https://forum.doom9.org/showthread.p...16#post1837161
if you need 16bit from 10-14 bits then use ConvertBits(16) before SMDegrain
it's up to you, SMDegrain can work with those as they are (input depth = output depth)
Old 1st February 2021, 20:24   #688  |  Link
tormento
Acid fr0g
tormento's Avatar
What will happen if I feed 10 bit source without ConvertBits(16) but with n16_out?
Old 1st February 2021, 20:25   #689  |  Link
real.finder
you should get an error message
Old 2nd February 2021, 17:08   #690  |  Link
tormento
Acid fr0g
tormento's Avatar
Ok, the results. Bit long and tedious job but it will save me some encoding time.
Number of frames:                     4560
Length (hh:mm:ss.ms):         00:03:10.190
Frame width:                          1920
Frame height:                         1040
Framerate:                          23.976 (24000/1001)
Colorspace:                           YV12
Base script:
PHP Code:
SetMemoryMax()
DGSource("F:\In\2_37 padrino III coda, Il - La morte di Michael Corleone\coda.dgi",ct=20,cb=20,cl=0,cr=0)
Prefetch(6
where (*) are the differences that I will list below.
[1] SMDegrain (tr=6, thSAD=600, refinemotion=false, n16=true, mode=0, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true)
[2] ConvertBits(10).SMDegrain (tr=6, thSAD=600, refinemotion=false, mode=0, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true)
[3] ConvertBits(12).SMDegrain (tr=6, thSAD=600, refinemotion=false, mode=0, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true)
[4] ConvertBits(16).SMDegrain (tr=6, thSAD=600, refinemotion=false, mode=0, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true)
[5] SMDegrain (tr=6, thSAD=600, refinemotion=false, n16_out=true, mode=0, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true)
AVSMeter64 results:
FPS  min  |   max  | average
[1] 1.238 |  46512 | 10.96
[2] 1.222 |  256.8 |  7.679
[3] 1.174 |  46083 |  6.170
[4] 1.084 | 140845 |  6.210
[5] 1.272 |  35461 | 10.97
x265 encoding:
[1] x265_x64.exe -D 10 --crf 22.0 --preset slow --profile main10 --level 4.1 --keyint 240 --vbv-bufsize 78125 --vbv-maxrate 62500 --aq-mode 2 --sar 1:1
[2] same as [1]
[3] same as [1] --input-depth 12 --dither
[4] same as [1] --input-depth 16 --dither
[5] same as [1] --input-depth 16 --dither
x265 results:
[1] 3.51 fps, 1734.92 kb/s, Avg QP:25.95
[2] 3.23 fps, 1713.39 kb/s, Avg QP:25.92
[3] 2.86 fps, 1713.58 kb/s, Avg QP:25.91
[4] 2.75 fps, 1716.02 kb/s, Avg QP:25.91
[5] 3.55 fps, 1714.94 kb/s, Avg QP:25.91
Can't understand the speedup with out16.
Old 2nd February 2021, 17:33   #691  |  Link
real.finder
Frame width:                          1920
Frame height:                         1040
Colorspace:                           YV12
Base script:
PHP Code:
SetMemoryMax()
Prefetch(6
AVSMeter64 results:
x265 encoding:
[2] same as [1]
x265 results:
see here https://forum.doom9.org/showthread.p...16#post1835681
also you can speed 2-4 as Boulder told you and I post an example code to do that
Old 2nd February 2021, 17:35   #692  |  Link
tormento
Acid fr0g
tormento's Avatar
That is what I am doing, i.e. process everything in 16 bit and dither in x265.
He asked you:
Originally Posted by Boulder View Post
Is this utilized in the SMDegrain port?
Old 2nd February 2021, 17:47   #693  |  Link
real.finder
He asked you:
edit: I mean that part of his post
pinterf's MVTools has the possibility to use MAnalyse and MRecalculate at a lower bitdepth and do all the processing at a higher bitdepth. In this case it would mean creating the vectors at 8 bits and do all the denoising etc. at 16 bits which makes things quite a bit faster. Is this utilized in the SMDegrain port?
also
motion analysis tends to be the slowest part of the whole thing. Doing it in 8 bits gives you a nice boost without actually sacrificing quality.
and I answer
you can by using prefilter as clip
then I give how to do that for you
#8bit source input
ConvertBits(XX).SMDegrain(tr=4, thSAD=500, refinemotion=false, mode=0, contrasharp=false, PreFilter=SMDegrain_prefilters(prefilter=4,a=1,d=1,h=7.0,device_type="GPU"), truemotion=true, plane=4, chroma=true)
or if you have HBD source already
#HBD source input
SMDegrain(tr=4, thSAD=500, refinemotion=false, mode=0, contrasharp=false, PreFilter=ConvertBits(8).SMDegrain_prefilters(prefilter=4,a=1,d=1,h=7.0,device_type="GPU"), truemotion=true, plane=4, chroma=true)
(same old post but with small edit)
Old 2nd February 2021, 17:55   #694  |  Link
Boulder
Pig on the wing
Boulder's Avatar
For HDR sources, I recommend ConvertBits(10) instead of ConvertBits(8) for prefilter as the source has information in the whole 10-bit range. At least DGSource will output 16-bit video in such cases (it's what the card just does).
Old 2nd February 2021, 18:05   #695  |  Link
real.finder
prefilter it's just for Motion Analyse even if your source is 16bit you can use 8bit without loosing quality, but if you care that much about HBD and you have fast CPU and you don't care about time then you can Motion Analyse in HBD and maybe you will get some better Motion Analyse from that in the end
anyway, I don't know about DGSource, but I think LSMASHSource can do HW decode for 10bit without convert it to 16bit
Old 2nd February 2021, 18:27   #696  |  Link
tormento
Acid fr0g
tormento's Avatar
The code you are giving me does SMDegrain on 8 bit source giving out 8 bit video. I need 10 bit output (or higher) to feed 10 bit x265 with.
Old 2nd February 2021, 19:02   #697  |  Link
real.finder
Old 2nd February 2021, 19:06   #698  |  Link
tormento
Acid fr0g
tormento's Avatar
I lost the initial conversion
I tried some posts ago and it was slower than regular pre=4
Old 2nd February 2021, 20:57   #699  |  Link
real.finder
you tried vs n16 things, of course n16 and even n16_out are the fastest high bit method
edit: also it was without device_type="GPU"
I said for your case above
AVSMeter64 results:
for 2, 3 and 4 not for 1 and 5 which use n16 things
Old 9th March 2021, 12:08   #700  |  Link
tormento
Acid fr0g
tormento's Avatar
Launching AVSMeter_x64 -avsinfo, I am getting:
Function duplicates:
"undefined" : "[InternalFunction]"
"Undefined" : "D:\Programmi\Media\AviSynth+\plugins64\Zs_RF_Shared-1.143~realfinder.avsi"
Why?
avisynth, avs script, avs+, banding, generator, hbd, mod
