Old 18th June 2024, 18:31   #921  |  Link
Titounet1965
Hi there
little bug repport
the scrpits fails if the filename contains the letter &
Titounet1965 is offline   Reply With Quote
Old 22nd June 2024, 06:24   #922  |  Link
NeverExists
Hi, has this been abandoned? no new release for 5 months. seems like it is..
NeverExists is offline   Reply With Quote
Old 25th June 2024, 16:22   #923  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Nothing to change (no bugs kwown).
the letter "&" is a command in batch. you must rename this file.
-QfG- is offline   Reply With Quote
Old 30th June 2024, 05:33   #924  |  Link
NeverExists
How exactly can I set it to mux into an mkv stream? I usually take the Dolby Vision rpu from the web release and combine it with the video from the 4k Blu-ray, but now everything has changed. do I still use demuxer to get the rpu? do I still use the injector to make my mkv? or do I use hybrid? and where the hell is the mux into mkv option?
wow! Nobody can answer this??
Old 10th July 2024, 19:00   #925  |  Link
AgentXXL
Most of us now use the hybrid script with its drag'n'drop method. You can still do it manually via the demuxer. For the mux into mkv option, you need to edit the injector script and set the variable MUXINMKV to YES.
Explained here: https://forum.doom9.org/showthread.p...44#post1997844
AgentXXL is offline   Reply With Quote
Old 11th July 2024, 00:26   #926  |  Link
NeverExists
I still don't know where or how to edit the injector script. What is the script file called exactly? I looked and I don't see anything named injector.
Old 12th July 2024, 18:40   #927  |  Link
AgentXXL
The file you need to edit is called DDVT_INJECTOR.cmd which will reside wherever you extracted the DDVT rar file to. You can edit it in Notepad on Windows.
Old 15th July 2024, 20:19   #928  |  Link
thegrunge
John
Hello I'm not sure I understand how it works, when I run the cmd it doesn't find any files.
https://ibb.co/M6zWGY7
thegrunge is offline   Reply With Quote
Old 15th July 2024, 21:34   #929  |  Link
thegrunge
John
Ok I understood that you have to drag the file onto the cmd. but how to remove the hdr10 now? It's juste remove DV.
It's not that I don't like HDR10, but even with compatible devices the image remains darker than without HDR10 for tha same movie
Old 17th July 2024, 01:53   #930  |  Link
Atlantis
Sorry, I can't read every page. What is the situation with AV1? I just tried to inject RPU into an AV1 file and it didn't work. Gives a 0 size file.
Atlantis is offline   Reply With Quote
Old 17th July 2024, 10:37   #931  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Dovi_tool cannot be used with AV1, so you can inject the RPU only during the encoding phase (with svt-av1-psy).
Old 17th July 2024, 10:49   #932  |  Link
Atlantis
Thank you.
Old 18th July 2024, 16:56   #933  |  Link
AgentXXL
You can't remove HDR if you want to keep DV - DV is additional metadata that is applied to the base HDR10 layer. If you're seeing image issues, it's likely your display is not calibrated for DV content.
Old 11th August 2024, 11:30   #934  |  Link
Wolfy59
Hi, first of all I'd like to thank you for all the work you've done here, which makes our day-to-day work so much easier. I'd like to know if there's a reason why the P5 profile is no longer supported?
Thank you
Wolfy59 is offline   Reply With Quote
Old 12th August 2024, 19:48   #935  |  Link
ReciprocalUniverse
OUTSTANDING! Just Bravo!!! Thank you so much for these great tools!!
Tom Roper
ReciprocalUniverse is offline   Reply With Quote
Old 18th August 2024, 08:19   #936  |  Link
AngelGraves13
If I'm injecting a DV layer from a web-dl into a remux and the lengths don't match, do I apply a negative offset if the RPU is shorter by 22 frames? I also don't really have a way to verify the DV stream after as I can't actually play the DV layer, so how would I know if something is out of sync?
AngelGraves13 is offline   Reply With Quote
Old 18th August 2024, 21:58   #937  |  Link
GodzilaAvenger
GodzilaAvenger's Avatar
You have to compare the web-dl source video with the remux to figure out the frame sync. If the web-dl is e.g. 10 frames ahead then set the delay in DDVT to -10, if it's 10 frames behind set it to 10.
GodzilaAvenger is offline   Reply With Quote
Old 20th August 2024, 15:38   #938  |  Link
Arkana
why it happening? How to fix it?
Arkana is offline   Reply With Quote
Old 20th August 2024, 22:10   #939  |  Link
AngelGraves13
Is there anyway to know if the hybrid remux I made is incorrect? Like would the colors be off or something if I did it wrong?
Ok, so my UHD Remux of The Nun (2018) is 138932 frames and the Web-DL DV is 138910 so I would delay "+22" frames by my understanding and everything will line up correctly? Is that all there is to it? I wish the frame mismatch would be automatically adjusted if that's the case.
What about "matchL6 metadata"?? What's that for exactly and when would one need enable it?
Old 20th August 2024, 22:12   #940  |  Link
AngelGraves13
Looks like two different masterings if I'm not mistaken so you can't make a hybrid of the two.
