2nd September 2018, 18:28 | #123 | Link |
Run AvsMeter against your installation, and see what version, and what plugs you got.
Today, G2K4 got a nice shiney new version to play with.
2nd September 2018, 18:31 | #124 | Link |
More precisely - Run "avsmeter avsinfo -log" and post the log file ("avsinfo_x86.log" or "avsinfo_x64.log").
Groucho's Avisynth Stuff |
2nd September 2018, 18:31 | #125 | Link |
Avisynth 2.6, the one with SetMTmode.
Do masktools and mvtools have their own version() function? Such large plugin packs with lots of dependencies should have that so you don't have to check it manually in plugin directory every time to see which one got loaded. When I just call MMask(last) (mmask is among the offending functions in that line that FRC is complaining about) I get a strange "Access violation /syswow64/ntdll.dll". Here's log, compressed. Why does everything has to be so difficult here in 2018. Last edited by Seedmanc; 2nd September 2018 at 22:53. |
2nd September 2018, 19:47 | #126 | Link |
Seedmanc. dont think you log is likely to overflow Usage Forum post limit of 16KB (Dev forum=20KB).
Awaiting mods to approve.
3rd September 2018, 08:14 | #127 | Link |
The size of the log is not the issue, the time it takes for a moderator to approve your attachment is. You'd be better off posting it on pastebin or similar.
3rd September 2018, 09:18 | #128 | Link |
I tried it on a different OS with a fresh installation of AVS+, still getting errors. https://pastebin.com/5Kz7Wsft log
Depending on the masktools version the errors are different: MT a48 : mt_inpand unsupported colorspace, only planar YUV, etc, line 164 MT pinterf : mt_merge clips should have identical bit depths, line 189 Was this even tested? |
3rd September 2018, 10:06 | #129 | Link | |
3rd September 2018, 17:51 | #130 | Link |
That helped, thank you very much.
But it looks like this plugin just blends frames together most of the time. Is there a configuration example I can use to remove "safety locks" so it never resorts to blending and instead shows its best attempt at interpolation even if it's not passing some good metrics? |
3rd September 2018, 19:03 | #131 | Link |
You wann give those that use this script, some idea what you are trying to do, low framerate up to super duper framerate, perhaps ?
4th October 2018, 22:58 | #133 | Link |
If merely doubling to 48-60fps counts as super for this script then my point still stands.
I'd rather see all the artifacts the script produces instead of the ghosting doubleframes, it would at least allow to compare to the artifacting other scripts do, to see which gets closer to the original (assuming I can take 60 fps, halve the framerate and try to reconstruct dropped frames). The way it is now the only measurement I can do is about its speed. Here are the examples, one from the Sintel clip http://www.framecompare.com/image-co...rison/0J9MNNNU the other from idolmaster ingame footage http://www.framecompare.com/image-co...rison/WD7PNNNX for more 2D-ish kind of material. In both cases I had to use the "flow" output of FRC to get at least something similar to motion interpolation instead of pure doubling like ConvertFPS on auto. But even then the simple mvtools with recalculation did better. I tried setting various threshold params of FRC to 0 as the readme says but it didn't help. |
5th October 2018, 23:12 | #134 | Link | |
6th October 2018, 15:53 | #135 | Link |
zorr, as a matter of fact yes I was going to try your tool for a while already, been watching your topic closely, waiting till it 'stabilizes' more or less about parameters and software involved. Maybe it's about time I give it a try.
I've been extensively testing various framerate conversion plugins recently,trying to figure out the best settings, but for now I've ran out of options (seems the pinterf's 64x64 does the trick better than the rest, though I had my hopes high for SVP). Particularly I'm interested in figuring out the usable truemotion parameters for blocksizes 32 and above, as they seem to be incompatible. |
7th October 2018, 00:29 | #136 | Link | ||
TEST_FRAMES = 10 MIDDLE_FRAME = 25 # original framerate FPS_NUM = 18 FPS_DEN = 1 # source clip AVISource("d:\optimizer\bridge\bridge_cropped.avi") AssumeFPS(FPS_NUM, FPS_DEN) #return last # needed for some parameter combinations ConvertToYV24() orig = last # preprocessing - blur and/or degrain #searchClip = orig #searchClip = last.Blur(1.58).Blur(1.58) searchClip = RemoveGrain(orig, 22) # optimize RemoveGrain(orig, _n_) | -1..24 | rmgrain super_pel = 4 # optimize super_pel = _n_ | 2,4 | super_pel super_sharp = 2 # optimize super_sharp = _n_ | 0..2 | super_sharp super_rfilter = 2 # optimize super_rfilter = _n_ | 0..4 | super_rfilter super_search = MSuper(pel=super_pel, sharp=super_sharp, rfilter=super_rfilter, searchClip) super_render = MSuper(pel=super_pel, sharp=super_sharp, rfilter=super_rfilter, orig, levels=1) blockSize = 32 # optimize blockSize = _n_ | 4,6,8,12,16,24,32,48,64 ; min:divide 0 > 8 2 ? ; filter:overlap overlapv max 2 * x <= | blockSize searchAlgo = 5 # optimize searchAlgo = _n_ | 0..7 D | searchAlgo searchRange = 2 # optimize searchRange = _n_ | 1..30 | searchRange searchRangeFinest = 2 # optimize searchRangeFinest = _n_ | 1..60 | searchRangeFinest lambda = 1000*(blockSize*blockSize)/(8*8) # optimize lambda = _n_ | 0..20000 | lambda lsad=1200 # optimize lsad=_n_ | 8..20000 | LSAD pnew=0 # optimize pnew=_n_ | 0..256 | pnew plevel=1 # optimize plevel=_n_ | 0..2 | plevel overlap=0 # optimize overlap=_n_ | 0,2,4,6,8,10,12,14,16,18,20,22,24,26,28,30,32 ; max:blockSize 2 / ; filter:x divide 0 > 4 2 ? % 0 == | overlap overlapv=0 # optimize overlapv=_n_ | 0,2,4,6,8,10,12,14,16,18,20,22,24,26,28,30,32 ; max:blockSize 2 / | overlapv divide=0 # optimize divide=_n_ | 0..2 ; max:blockSize 8 >= 2 0 ? overlap 4 % 0 == 2 0 ? min | divide globalMotion = true # optimize globalMotion = _n_ | false,true | globalMotion badSAD = 10000 # optimize badSAD = _n_ | 4..10000 | badSAD badRange = 24 # optimize badRange = _n_ | 4..50 | badRange meander = true # optimize meander = _n_ | false,true | meander temporal = false # optimize temporal = _n_ | false,true | temporal trymany = false # optimize trymany = _n_ | false,true | trymany dct = 0 # optimize dct = _n_ | 0,2,3,4,5,6,7,8,9,10 | dct delta = 1 useChroma = true bv = MAnalyse(super_search, isb = true, blksize=blockSize, search=searchAlgo, searchparam=searchRange, pelsearch=searchRangeFinest, \ chroma=useChroma, delta=delta, lambda=lambda, lsad=lsad, pnew=pnew, plevel=plevel, global=globalMotion, overlap=overlap, overlapv=overlapv, \ divide=divide, badSAD=badSAD, badrange=badRange, meander=meander, temporal=temporal, trymany=trymany, dct=dct) fv = MAnalyse(super_search, isb = false, blksize=blockSize, search=searchAlgo, searchparam=searchRange, pelsearch=searchRangeFinest, \ chroma=useChroma, delta=delta, lambda=lambda, lsad=lsad, pnew=pnew, plevel=plevel, global=globalMotion, overlap=overlap, overlapv=overlapv, \ divide=divide, badSAD=badSAD, badrange=badRange, meander=meander, temporal=temporal, trymany=trymany, dct=dct) threshold = 10000 maskScale = 70 # optimize maskScale = _n_ | 1..300 | maskScale mask_fps = 3 # optimize mask_fps = _n_ | 0..2 | mask_fps inter = orig.MFlowFPS(super_render, bv, fv, num=FPS_NUM*2, den=FPS_DEN, mask=mask_fps, ml=maskScale, thSCD1=threshold, thSCD2=100) # return this to look at the clip with doubled framerate #return inter fps_only = inter.SelectOdd() # second pass super_search2 = MSuper(pel=super_pel, sharp=super_sharp, rfilter=super_rfilter, fps_only) super_render2 = MSuper(pel=super_pel, sharp=super_sharp, rfilter=super_rfilter, fps_only, levels=1) bv2 = MAnalyse(super_search2, isb = true, blksize=blockSize, search=searchAlgo, searchparam=searchRange, pelsearch=searchRangeFinest, \ chroma=useChroma, delta=delta, lambda=lambda, lsad=lsad, pnew=pnew, plevel=plevel, global=globalMotion, overlap=overlap, overlapv=overlapv, \ divide=divide, badSAD=badSAD, badrange=badRange, meander=meander, temporal=temporal, trymany=trymany) fv2 = MAnalyse(super_search2, isb = false, blksize=blockSize, search=searchAlgo, searchparam=searchRange, pelsearch=searchRangeFinest, \ chroma=useChroma, delta=delta, lambda=lambda, lsad=lsad, pnew=pnew, plevel=plevel, global=globalMotion, overlap=overlap, overlapv=overlapv, \ divide=divide, badSAD=badSAD, badrange=badRange, meander=meander, temporal=temporal, trymany=trymany) inter2 = fps_only.MFlowFPS(super_render2, bv2, fv2, num=FPS_NUM*2, den=FPS_DEN, mask=mask_fps, ml=maskScale, thSCD1=threshold, thSCD2=100) fps_only2 = inter2.SelectOdd() delimiter = "; " inter_yv12 = fps_only2.ConvertToYV12() orig_yv12 = orig.ConvertToYV12() # for comparison original must be forwarded one frame orig_yv12 = trim(orig_yv12,1,0) inter_yv12 = inter_yv12.Trim(MIDDLE_FRAME - TEST_FRAMES/2 + (TEST_FRAMES%2==0?1:0), MIDDLE_FRAME + TEST_FRAMES/2) orig_yv12 = orig_yv12.Trim(MIDDLE_FRAME - TEST_FRAMES/2 + (TEST_FRAMES%2==0?1:0), MIDDLE_FRAME + TEST_FRAMES/2) last = inter_yv12 global total = 0.0 global ssim_total = 0.0 global avstimer = 0.0 frame_count = FrameCount() FrameEvaluate(last, """ global ssim = SSIM_FRAME(orig_yv12, inter_yv12) global ssim_total = ssim_total + (ssim == 1.0 ? 0.0 : ssim) """, args="orig_yv12, inter_yv12, delta, frame_count") # NOTE: AvsTimer call should be before the WriteFile call AvsTimer(frames=1, type=0, total=false, name="Optimizer") # per frame logging (ssim, time) resultFile = "D:\optimizer\perFrameResults.txt" # output out1="ssim: MAX(float)" out2="time: MIN(time) ms" file="D:\optimizer\perFrameResults.txt" WriteFile(resultFile, "current_frame", "delimiter", "ssim", "delimiter", "avstimer") WriteFileIf(resultFile, "current_frame == frame_count-1", """ "stop " """, "ssim_total", append=true) return last If your video has a large resolution it might be a good idea to crop it to a smaller size, leaving just the interesting motion in the center. Make a cropped video and load it directly into this script to make the optimization faster. My approach at frame rate doubling is this: I double the rate of the original video, remove original frames, then double the rate again and compare against the original frames. That has been working well but I haven't done comparisons to other ways (like dropping every other frame and then doubling the rate). When you write out the optimized scripts take out the comment in front of "return inter" to see the frame-doubled version (ie without the second pass which recreates the original frames). This script has a lot of parameters and the ranges are mostly not restricted in any way (some parameters like lambda and lsad don't have an upper limit so I just used a very large number there). I did take out dct=1 because with some parameter combinations it takes *extremely* long time to calculate (like 8 minutes when normal time is 1,5 seconds). That's a shame because in my testing dct=1 is usually the best quality-wise. Instead of using truemotion true/false this script sets the parameters controlled by it (lambda, lsad, pnew, plevel, global) individually. If you already know for example which blockSize is good then just adjust the search ranges accordingly. This script doesn't have MRecalculate, I recommed that you first try to find optimal values without it and once you have them add MRecalculate and optimize only its parameters (I can give an example script of that as well). Actually you could stack as many recalculates as you want always using smaller and smaller blocksize... I think it could be a way to make a really robust script, starting with blocksize 64 and halving it with every recalculate. I haven't tried that yet so it's just a theory. Note that not all the parametes of MVTools2 are there, I haven't gotten around to trying everything yet... The script includes preprocessing the search clip with RemoveGrain, in my tests I have found it can help. Obviously we are searching an optimal value for that function as well. Oh and one more thing, I came up with a way to limit the ugly artifacts you often get with MFlowFPS when good motion vectors are not found. Basically you reconstruct the frame created with MFlowFPS using MCompensate and the original frames. You just need to find good parameters for that, which you can do with the optimizer. I will give an example of that later. |
26th December 2018, 22:28 | #137 | Link |
Confirming the same issue Sharc saw previously:
https://forum.doom9.org/showthread.php?p=1808322&highlight=access+violation#post1808322 FrameRateConverter runs into Access Violation whenever I set the speed to anything slower than "normal". The error seems to be occuring in line 143: Code:
bak = MAnalyse(superfilt, isb=true, blksize=BlkSize, blksizev=BlkSizeV, overlap = BlkSize>4?(BlkSize/4+1)/2*2:0, overlapv = BlkSizeV>4?(BlkSizeV/4+1)/2*2:0, search=3, dct=Dct) I've tested and found the same issue with current versions of Avisynth 32 bit and Avisynth+. Should I fiddle with BlkSize, or does someone else know of a fix? |
26th December 2018, 22:49 | #138 | Link |
Just found the issue - My apologies! I had a bad version of FFTW3.dll. And I'm not even sure where it was from. I grabbed the version from here and dropped it in syswow64. Everything runs properly now.
31st January 2019, 18:46 | #139 | Link |
Sorry for lack of technical terms but...
Tested this with many many different settings, and the best interpolation I can get is just a blend of the two different frames. Only very small movement will the frame look like its a new frame altogether, but with bigger movements you can see a faded version of the two original frames in the "interpolated" frame. At least with SVP it attempts to create an image that is somewhere between the two original frames. Last edited by attackworld; 31st January 2019 at 18:51. |
4th March 2019, 20:04 | #140 | Link |
I'm unable to run this at all at a reasonable speed. I'm in AVS+ x64, and using fftw338-x64-AVX2. It falls into sub 1fps. Either with or without mp_pipeline using slower preset. What fftw do you guys use? Is there a special MT mode I have to use for FrameRateConverter.dll?
