3rd September 2021, 16:42 | #802 | Link | ||
Acid fr0g
I love HEVC @ 10bit but my PC is getting old and encoding at 3-5 fps is a bit slow I do that only for masterpiece movies.
@turment on Telegram |
3rd September 2021, 18:11 | #804 | Link |
21 years and counting...
No problem. Nothing spectacular. I used this for the first clip:
ConvertBits(16) Original=last neo_fft3d(sigma=6, sigma2=1.50, sigma3=1.50, sigma4=1.50, bt=1, sharpen=0, Y=3, U=2, V=2) neo_fft3d(sigma=3, sigma2=0.75, sigma3=0.75, sigma4=0.75, bt=1, sharpen=0, Y=2, U=3, V=3) pre=RemoveGrain(mode=2, modeU=17, modeV=17, planar=false).sneo_dfttest(slocation="0.0:6 0.6:24 1.0:48", chrslocation="0.0:3 0.6:12 1.0:24", tbsize=1, Y=3, U=3, V=3).Blur(0.25) SMDegrain(tr=12, thSAD=500, contrasharp=true, CClip=Original, refinemotion=true, truemotion=false, Str=1.2, pel=1, subpixel=2, prefilter=pre) neo_f3kdb(range=30, Y=64, Cb=64, Cr=64, grainY=64, grainC=64, sample_mode=4) ConvertBits(8, dither=1) Prefetch(20,20) Return(Last) Code:
ConvertBits(16) Original=last neo_fft3d(sigma=6, sigma2=1.50, sigma3=1.50, sigma4=1.50, bt=1, sharpen=0, Y=3, U=2, V=2) neo_fft3d(sigma=3, sigma2=0.75, sigma3=0.75, sigma4=0.75, bt=1, sharpen=0, Y=2, U=3, V=3) pre=RemoveGrain(mode=2, modeU=17, modeV=17, planar=false).sneo_dfttest(slocation="0.0:6 0.6:24 1.0:48", chrslocation="0.0:3 0.6:12 1.0:24", tbsize=1, Y=3, U=3, V=3).Blur(0.25) SMDegrain(tr=6, thSAD=300, contrasharp=false, refinemotion=true, truemotion=false, Str=1.2, pel=1, subpixel=2, prefilter=pre, globals=2) SMDegrain(tr=6, thSAD=300, contrasharp=true, CClip=Original, refinemotion=true, truemotion=false, Str=1.2, pel=1, subpixel=2, prefilter=-1, globals=1) neo_f3kdb(range=30, Y=64, Cb=64, Cr=64, grainY=64, grainC=64, sample_mode=4) ConvertBits(8, dither=1) Prefetch(16,16) Return(Last) Code:
LoadPlugin("...\neo-dfttest_rf-fix\64\neo-dfttest.dll") #fixed version by real.finder from 05/29/21 LoadPlugin("...\neo-f3kdb_r6\clang-x64\neo-f3kdb.dll") LoadPlugin("...\NeoFFT3D_rf-fix\64\neo-fft3d.dll") #fixed version by real.finder from 05/29/21 # LoadPlugin("...\masktools2-v2.2.26\x64_clang\masktools2.dll") LoadPlugin("...\mvtools-2.7.44\x64\mvtools2.dll") LoadPlugin("...\RgTools-v1.1\x64_LLVM_build\RgTools.dll") LoadPlugin("...\MedianBlur2_v1.1\x64_Clang\MedianBlur2.dll") # Import("...\SMDegrain.avsi") #v3.1.2d Import("...\Zs_RF_Shared.avsi") #v1.147 Import("...\mtmodes.avsi") So, for speed improvement lower the temporal radius in SMDegrain from what I used. => tr=6 for that single-stage filtering and tr=4 for those two 2pass-stages in the other script. You could also try to disable contrasharp which will give you more speed and surely even more compressibility. But the picture may look too smooth in the end. Remove the blur for SMDegrains prefiltering if you don't use contrasharp. neo_fft3d is pretty quick so I would not touch that. It removes high pitched noise in all planes in the spatial domain. Otherwise you may get a "curtain-like" effect on camera pans as SMDegrain tends to leave 'static' pixels in the picture on higher settings. Prefiltering with a spatial denoiser helps to reduce that effect. I use my own dfttest-settings with higher sigma ramps for prefiltering in SMDegrain instead of the default values (prefilter=3). I prefer to filter chroma planes about half as much as the luma plane. I don't like the effect that too strong chroma filtering has on moving objects in the picture. Last edited by LeXXuz; 3rd September 2021 at 20:11. |
4th September 2021, 08:27 | #805 | Link |
tormento, you can try https://forum.doom9.org/showthread.p...67#post1910867
See My Avisynth Stuff |
11th September 2021, 13:26 | #807 | Link |
Sorry, if this may be a little OT.
I have a film here which got some very bad post processing.The studio really went over the hill with edge sharpening. So I was wondering, is there some kind of counterpart to LimitedSharpen? I mean a filter which does soften sharp edges/high contrasts way more than subtle textures/details? I know LSFmod has a built-in softener but that only affects the prior sharpening effect if I'm not mistaken. |
7th October 2021, 06:34 | #808 | Link |
in case someone need fmtconv/fmtcavs for winxp https://github.com/realfinder/Univer...us/fmtcavs.dll (Maybe once in the life, in the next UniversalPluginsFolders update it will be replaced with Official one but the link should be permanent)
13th October 2021, 17:24 | #809 | Link |
Pig on the wing
I'm trying to use sh_LimitChange, but it gives me an error for invalid arguments. I don't see anything wrong with them I'm using the Avisynth_3.7.1_20210911_test12 build, and just loading the source with DGSource prior to the call.
sh_limitchange(last, last.blur(0.15), limity=1)
13th October 2021, 18:14 | #810 | Link | |
13th October 2021, 18:47 | #811 | Link |
Pig on the wing
Thanks, that one works but now I got a second issue. Looks like limit 0.5 is the lowest one to set, anything below that gives an identical limit which seems to be close to zero.
Easy to test with ex_makediff(last, sh_limitchange(last, last.removegrain(17), 0.5), aug=true).
13th October 2021, 19:54 | #812 | Link | |
13th October 2021, 20:51 | #813 | Link |
Pig on the wing
I think I also had 16-bit video as I placed it inside my denoising function, but I can retest that in the morning.
14th October 2021, 05:02 | #814 | Link |
Pig on the wing
I've checked and the same happens for 16-bit video. By the way, is the limit scaled somehow for HBD values like in MDegrain's limit (i.e. range is fixed 0-255 and for HBD limit 0.1 = 0.1 * 255)?
14th October 2021, 06:21 | #815 | Link | |
and you can't see the real diff of 16 if you got 8bit display, even if you have more than 8bit display you still need the right tools/programs and settings to see the diff
2nd November 2021, 06:43 | #816 | Link |
I'm trying to use ASTDRmc() with AviSynth+ v2.6.0 x64. When I try to open the file I get an error saying "There is no function named 'vsTEdgeMask". According to the wiki that's the extra requirement for motion compensation if you're using avisynth 2.5.x and there is no x64 version of TEdgeMask that I could find. I have MVTools and TEMmod as per the wiki and regular ASTDR() works fine. Is this a bug or am I doing something wrong?
Regular ASTDR() is the best de-rainbow I've tried so far btw. Awesome work. Edit: the error is on line 60 of the script Last edited by sp4ce_c0wb0y; 2nd November 2021 at 06:52. Reason: extra info |
2nd November 2021, 07:37 | #817 | Link |
You need download here
https://github.com/Asd-g/AviSynth-vsTEdgeMask |
5th November 2021, 02:58 | #818 | Link | |
14th November 2021, 19:59 | #819 | Link |
I try to get the neo_dfttest version of DFTTESTMC to work. I have deleted the "dfttest.dll" and I have only "neo_dfttest.dll" to load.
Still with this: Code:
convertbits(16) dfttestmc() I use this version: https://github.com/realfinder/AVS-St...MC_things.avsi |
14th November 2021, 20:39 | #820 | Link | ||
ColorBars(width=640, height=480, pixel_type="yv12") convertbits(16) dfttestmc() Quote:
tl;dr: nstring and sstring are for luma (and chroma if you didn't use chrslocation), and didn't matter if you have dfttest or neo_dfttest
avisynth, avs script, avs+, banding, generator, hbd, mod |
