10th June 2018, 20:53 | #702 | Link |
srestore v2.793
pastebin and attachment fix bug in 12bit thanks to StainlessS, maybe it will be the last edit by me since StainlessS work on update for srestore
See My Avisynth Stuff |
10th June 2018, 23:34 | #703 | Link | |
I am only reformatting and moving stuff around, I've never used high bit depth stuff at all and dont even know what functions / filters are available. Martin53 did a convert to an early form of the Multi-instance style developed by himself and Gavino, I am also converting to a later style of same. [EDIT: also making possible to run under either Avs Std with GScript, or Avs+ without GScript, the real reason for my mods] I look forward to many years of updates by the master himself, Real.Finder, All Hail Real.Finder
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th June 2018 at 00:19. |
11th June 2018, 16:57 | #704 | Link |
Further to above, Adding GScript functionality can make it possible speed stuff up a bit, consider,
current script Code:
### frame output calculation - resync - dup ### dbb = select(pos+2, Srestore_d43%%%, Srestore_d32%%%, Srestore_d21%%%, Srestore_d10%%%, Srestore_d01%%%) dbc = select(pos+2, Srestore_d32%%%, Srestore_d21%%%, Srestore_d10%%%, Srestore_d01%%%, Srestore_d12%%%) dcn = select(pos+2, Srestore_d21%%%, Srestore_d10%%%, Srestore_d01%%%, Srestore_d12%%%, Srestore_d23%%%) dnn = select(pos+2, Srestore_d10%%%, Srestore_d01%%%, Srestore_d12%%%, Srestore_d23%%%, Srestore_d34%%%) selections are evaluated before calling the Select() function to pick out the required one. Each of the above Srestore_xxx%%% style names are Global variables, and so each of them is slower than local variable access, and each select call accesses five such slow Globals. (The '%%%' bit is replaced by some unique name for Function Multiple Instancing, we also replace these in our mod to '@@@' as there is potential for problems with current '%%%'). With GSCript can use instead eg Code:
### frame output calculation - resync - dup ### if (pos+2==0) { dbb = Srestore_d43@@@ dbc = Srestore_d32@@@ dcn = Srestore_d21@@@ dnn = Srestore_d10@@@ } else if(pos+2==1) { dbb = Srestore_d32@@@ dbc = Srestore_d21@@@ dcn = Srestore_d10@@@ dnn = Srestore_d01@@@ } else if(pos+2==2) { dbb = Srestore_d21@@@ dbc = Srestore_d10@@@ dcn = Srestore_d01@@@ dnn = Srestore_d12@@@ } else if(pos+2==3) { dbb = Srestore_d10@@@ dbc = Srestore_d01@@@ dcn = Srestore_d12@@@ dnn = Srestore_d23@@@ } else { dbb = Srestore_d01@@@ dbc = Srestore_d12@@@ dcn = Srestore_d23@@@ dnn = Srestore_d34@@@ } NOTE for Real.Finder only, for eg 'Srestore_d43%%%', the 'Srestore_' is purely ornamental, d43%%% would uniquely identify the var even with multiple instances, so 'Srestore_' part is totally superfluous. Reading the values of Global variables is slower than local variable access (locals are scanned first before Globals list). AVS+, uses a hash table to access Local and Global variables, but Avs Std does not, and so for Avs Std the impact may be somewhat higher than avs+. See here thread on slow access to Global Variables Names, in particular those defined early in Avisynth system, eg False and True. Informational: Compare with Bool literal is SLOW!:- https://forum.doom9.org/showthread.p...52#post1650952 [EDIT: Above link really no more than an interesting read, not really related to the slower Global access in this case] I have not done any speed tests so far, comparing original prev version SRestore with my mod, but it should at least be a little faster I think, I'll post when more complete. There will likely be no mod to the algorithm used, only shuffling stuff about.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 12th June 2018 at 00:25. |
12th June 2018, 00:45 | #705 | Link | |
Sorry, Real.Finder, I added a second suspect bug via EDIT to my post in your other thread, seems you did not see the EDIT before posting the fix.
Here, https://forum.doom9.org/showthread.p...87#post1844187 Quote:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 12th June 2018 at 00:54. |
12th June 2018, 02:55 | #706 | Link |
yes, it's bug, it has relation with the previous one
srestore v2.794 pastebin and attachment fix another bug in 12bit thanks to StainlessS
12th June 2018, 06:09 | #707 | Link |
Just a quick question about using the latest version 2.794 on an ancient computer (WinXP, CPU without SSE2 capability).
Right now I still use srestore 2.7e because at the time when I installed it this was the last version which worked on my machine. Probably because I have to use masktools-v2.0a48, all later versions do not run on my computer. Now I just gave v. 2.794 a quick whirl (using the same old masktools version under AVS 2.6), and to my surprise it worked. I just used the frate param though. As you might guess I do not care for high bitdepth or high colors. So my question is if it is safe to switch to the current version of srestore, or am I playing with fire? Does the new version have any advantages over the old 2.7e on my ancient system? Cheers manolito |
12th June 2018, 06:51 | #708 | Link | |
12th July 2018, 02:17 | #710 | Link |
srestore v2.795 pastebin and attachment
srestore v2.796 (need SMDegrain.avsi (v3.1.2.101s or up)) pastebin and attachment
See My Avisynth Stuff Last edited by real.finder; 13th August 2019 at 04:56. |
30th August 2018, 01:51 | #711 | Link |
Should this be applied before bob-deinterlacing? After? Does it replace a bob-deinterlacer? Where in my workflow should I put this filter?
I ask unusual questions but always give proper thanks to those who give correct and useful answers. |
30th August 2018, 03:36 | #712 | Link | |
http://avisynth.nl/index.php/Srestore#Examples It shows one example where SRestore is placed after the bob deinterlacing. I don't think I've ever used it that way. My advice is to try it out and experiment a bit. |
30th August 2018, 04:09 | #713 | Link |
Pig on the wing
I'd say that if working with non-animation type of material, at least 95% of the time, SRestore is applied after bob-deinterlacing the source.
30th August 2018, 04:16 | #715 | Link |
Pig on the wing
I don't have any experience with that, but I think that there are better alternatives for processing those than SRestore. SRestore works wonders for standard screwed up PAL->NTSC/NTSC->PAL conversions but animation is a very different beast.
30th August 2018, 09:26 | #716 | Link | |
As Boulder mentioned, it's designed to fix field-blended videos resulting from bad standards conversions - PAL to NTSC or NTSC to PAL. If that's what you intend to do, you first bob the video followed by the use of SRestore. As usual, an untouched sample should be provided if you'd like more informed help. |
30th August 2018, 11:47 | #718 | Link |
Update your masktools plugin
30th August 2018, 20:47 | #720 | Link | |
mrestore, srestore |
