10th May 2008, 17:38 | #1841 | Link |
I just wanted to thank the creators of this software -- you've given my Athlon XP 2800+ and ATI Radeon HD2400 Pro the ability to play back 720p MKV files! To see the CPU usage go from 100% to 15% is just unreal -- thank you, thank you, thank you.
10th May 2008, 18:15 | #1842 | Link |
Wewkiee
Attn: All
Please be cordial to the coders working on this project. Working with GPU is no easy task (illustrated by the fact noone else has been brave enough to try w/mpc) Inflammatory statements against the coders can be possible violations of rules 4 and/or 9(caps). Using free beta/alpha software implies you are a guinea pig and if that is an issue dont install it. (yes, even if other beta software has worked more consistently for you.) Points can be made without being insulting and/or demanding.
...yeah...but...why on earth would I compare apples with apples? |
11th May 2008, 01:58 | #1844 | Link | |
http://www.tosei.ru/isoft/MPC_HC_508.7Z Compiled myself ... |
11th May 2008, 02:11 | #1845 | Link | |
speaking of the first page, r510 is posted!
HTPC: DFI LANPARTY ut nf4 ultra-d AMD Opteron 144 1.8Ghgz 2GB (2x1GB) Gskill 2.5-3-3-6-1T XFX 7600gt passive or Sapphire HD3450 can't decide yet Windows XP MCE Westinghouse 1080p LCD |
11th May 2008, 10:47 | #1847 | Link |
Just finished testing MPC-HC r510 (32bits) from the first page... Video seeking is completely fixed for both DXVA and the internal (Software) Video Decoder. Best build so far.
When using DXVA, I still have the blockiness problem on some x264 videos. |
11th May 2008, 10:52 | #1848 | Link | |
Solaris: burnt by the Sun
glad to see the seeking is fixed looks like its time for me update |
11th May 2008, 13:23 | #1849 | Link | |
Otaku
Anyway MPC HC just gets better and better! Thanks to the developers for their efforts and support!
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
11th May 2008, 13:39 | #1850 | Link |
Hi im using MPC-HC x64 v 1.1.0.0.
Most of x264 encodes are working just fine and w/ hw acceleration via dxva. But i have some encodes especially anime encodes that not only that i have no hw accelearation, but i have no video image although the audio and subtitles are displayed Here is a screenshot from mpc: http://i25.tinypic.com/4q1r0y.jpg And here is a sample from that encode: http://www.filebox.ro/download.php?k...eb8b4d2669b70e Some info about encode via Mediainfo Codec/Family : AVC Codec/Info : Advanced Video Codec Codec profile : High@L5.1 Codec settings, CABAC : Yes Codec_Settings_RefFrames : 10 PlayTime : 1mn 19s Bit rate : 2327 Kbps Width : 1280 pixels Height : 720 pixels Display Aspect ratio : 16/9 Frame rate : 23.976 fps Chroma : 4:2:0 Interlacement : Progressive The video works fine in mpc-hc x32 with coreavc / ffdshow Maybe in later builds of mpc-hc x64 the problem is fixed(meaning i can have video without hw acceleration) but I didnt managed to compile a new build. P.S. Great work with DXVA and on top of all things you offer it FREE (unlike other h264 decoders). One more question. For my curiosity mostly. Why on 64bit version i have 0-1% cpu load and on 32bit version with same video encode and settings in mpc, i have 5-10% cpu load.
Windows 7 x64 , C2D e8400 @ 4.2 GHz, Scythe SCMN-1100, Gigabyte GA-P35-DS3, Mushkin 4x 2GB XP2-6400, 2x500 GB WD, 1x160 WD, His ICEQ 4670, DELL 228WPF + Samsung 32 Inch,Xonar D1 Last edited by baadnewz; 11th May 2008 at 13:50. |
11th May 2008, 15:03 | #1851 | Link |
DXVA often doesn't work when the levvel of the file is 5.1. I think 4.1 (or 4.2 ?) is the highest allowed level for hardware acceleration. Also there are too many reference frames. With level 4.1 I think 7 (8 ?) is the maximum for 1280x720.
11th May 2008, 17:11 | #1852 | Link | |
http://forum.doom9.org/showthread.php?t=132924 it's L4.1 and 9 ref. frames for 1280x720 |
11th May 2008, 20:08 | #1853 | Link |
Little Bug with Anamorphic & SAR
recently i've discovered a little bug that happens using the Elecard MPEG2 Decoder. I have a 704*576 anamorphic MPEG2 with a SAR = 12/11 so it gets in the final as 768*576. Now, I use - Auto Zoom to 100% on Startup - Keep Aspect Ratio If i open with the internal Mpeg2 decoder, the video gets well proportioned as 768*576, but if i open with Elecard the video gets stretched to 704*528. So the SAR is applied on the Vertical axis instead of Horizontal. But the strange thing is that if i click at this point the "Zoom 100%" menu item, the video get stretched from 704*528 to the correct 768*576. So the wrong anamorphic resizing happens on startup. This issue can be fixed? Thanks Last edited by 3ngel; 11th May 2008 at 20:10. |
11th May 2008, 20:14 | #1854 | Link | |
ffdshow/AviSynth wrangler
np: The Coasters - Down In Mexico (Quentin Tarantino's Death Proof OST)
now playing: [artist] - [track] ([album]) |
11th May 2008, 20:24 | #1855 | Link |
But, if Elecard would not signal the AR, MPC would have to stick with an initial 704*576 window without SAR, instead it goes down on the correct SAR but applied on the wrong axis.
So it appears as a matter of mpc pheraps related with "Auto Zoom 100% on opening"? Last edited by 3ngel; 11th May 2008 at 20:26. |
12th May 2008, 01:09 | #1856 | Link |
Any fix yet for the DVD Highlighting regression ??
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote |
12th May 2008, 20:23 | #1858 | Link |
Hello, here is my current problem:
I see only the first frame of the file and then only black when viewing x264 mkv file in the XP Media Center app using the mpc-hc decoder. The file plays fine when using the mpc-hc app and I even get HWA with the HD3450! I really want to use the media center app. What do yall think could be the problem? Thanks
12th May 2008, 23:04 | #1859 | Link |
I haven't this problem on ma machine. It's happen with all renderers or just one in peticuliar ?
Tired of tearing? Try this Media Player Classic mod : http://mpc-hc.sourceforge.net |
13th May 2008, 06:00 | #1860 | Link |
r510 and r512, seeking doesn't work with my 8500gt in dxva too. Driver version 175.16 . Not only that, both revision also cannot run the files in dxva. Stuck at the beginning with black screen. Try to seek and click "play" and "pause", still the same.
