#61 | Link |
結城有紀
StvG: I don't have AVX512 and every time I test with AVX512 I have to rent a server. Can you confirm if the difference only appears on opt=4? What bit depth?
My Projects x265 - Yuuki-Asuna-mod TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median |
#62 | Link |
I made a test with prefetch(3) and (5) and got different results. Now I am wondering, if that's a normal behaviour (and has always been like that for all my scripts, but I did'nt realize) or if that's because of neo_fft3d.
script(s) for prefetch-test DGSource("test.dgi", crop_l=0, crop_r=0, crop_t=0, crop_b=0, deinterlace=0, use_top_field=true, use_pf=true) RequestLinear(rlim=100, clim=100) neo_fft3d(sigma=1.0, beta=1.0, bw=48, bh=48, sharpen=0.040, scutoff=0.01, y=3, u=2, v=2, bt=5, opt=3) avstp_set_threads(1) Prefetch(3) # Prefetch(5) return last x264 result for prefetch(3) [2020-05-03][18:59:26] y4m [info]: 1280x720p 1:1 @ 30000/1001 fps (cfr) [2020-05-03][18:59:26] x264 [info]: using SAR=1/1 [2020-05-03][18:59:26] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [2020-05-03][18:59:26] x264 [info]: profile High, level 4.0, 4:2:0, 8-bit [2020-05-03][19:06:29] x264 [info]: frame I:33 Avg QP:14.82 size:164557 [2020-05-03][19:06:29] x264 [info]: frame P:1785 Avg QP:18.28 size: 28082 [2020-05-03][19:06:29] x264 [info]: frame B:7078 Avg QP:26.95 size: 2907 [2020-05-03][19:06:29] x264 [info]: consecutive B-frames: 1.5% 1.5% 5.1% 6.4% 18.9% 66.6% [2020-05-03][19:06:29] x264 [info]: mb I I16..4: 3.6% 55.1% 41.3% [2020-05-03][19:06:29] x264 [info]: mb P I16..4: 0.5% 2.9% 2.3% P16..4: 44.1% 16.1% 16.4% 0.9% 0.4% skip:16.4% [2020-05-03][19:06:29] x264 [info]: mb B I16..4: 0.0% 0.1% 0.2% B16..8: 34.9% 2.9% 0.7% direct: 0.7% skip:60.5% L0:46.9% L1:44.0% BI: 9.1% [2020-05-03][19:06:29] x264 [info]: 8x8 transform intra:49.6% inter:31.3% [2020-05-03][19:06:29] x264 [info]: direct mvs spatial:99.9% temporal:0.1% [2020-05-03][19:06:29] x264 [info]: coded y,uvDC,uvAC intra: 86.8% 59.0% 33.7% inter: 7.2% 2.9% 0.3% [2020-05-03][19:06:29] x264 [info]: i16 v,h,dc,p: 7% 53% 12% 28% [2020-05-03][19:06:29] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 8% 33% 15% 5% 5% 4% 8% 6% 16% [2020-05-03][19:06:29] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 28% 8% 6% 9% 7% 11% 7% 14% [2020-05-03][19:06:29] x264 [info]: i8c dc,h,v,p: 40% 38% 14% 9% [2020-05-03][19:06:29] x264 [info]: Weighted P-Frames: Y:12.2% UV:0.8% [2020-05-03][19:06:29] x264 [info]: ref P L0: 62.4% 13.9% 18.1% 3.4% 1.9% 0.2% 0.0% [2020-05-03][19:06:29] x264 [info]: ref B L0: 86.7% 10.4% 2.5% 0.4% [2020-05-03][19:06:29] x264 [info]: ref B L1: 98.0% 2.0% [2020-05-03][19:06:29] x264 [info]: kb/s:2051.98 [2020-05-03][19:06:29] encoded 8896 frames, 20.88 fps, 2052.00 kb/s x264 result for prefetch(5) [2020-05-03][19:06:33] y4m [info]: 1280x720p 1:1 @ 30000/1001 fps (cfr) [2020-05-03][19:06:33] x264 [info]: using SAR=1/1 [2020-05-03][19:06:33] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [2020-05-03][19:06:33] x264 [info]: profile High, level 4.0, 4:2:0, 8-bit [2020-05-03][19:14:10] x264 [info]: frame I:33 Avg QP:14.82 size:164580 [2020-05-03][19:14:10] x264 [info]: frame P:1785 Avg QP:18.28 size: 28080 [2020-05-03][19:14:10] x264 [info]: frame B:7078 Avg QP:26.96 size: 2907 [2020-05-03][19:14:10] x264 [info]: consecutive B-frames: 1.5% 1.5% 5.1% 6.4% 18.9% 66.6% [2020-05-03][19:14:10] x264 [info]: mb I I16..4: 3.4% 55.2% 41.4% [2020-05-03][19:14:10] x264 [info]: mb P I16..4: 0.5% 2.9% 2.3% P16..4: 44.1% 16.2% 16.3% 0.9% 0.4% skip:16.4% [2020-05-03][19:14:10] x264 [info]: mb B I16..4: 0.0% 0.1% 0.2% B16..8: 34.9% 2.9% 0.7% direct: 0.7% skip:60.5% L0:46.9% L1:44.0% BI: 9.1% [2020-05-03][19:14:10] x264 [info]: 8x8 transform intra:49.8% inter:31.3% [2020-05-03][19:14:10] x264 [info]: direct mvs spatial:99.9% temporal:0.1% [2020-05-03][19:14:10] x264 [info]: coded y,uvDC,uvAC intra: 86.8% 59.0% 33.8% inter: 7.2% 2.9% 0.3% [2020-05-03][19:14:10] x264 [info]: i16 v,h,dc,p: 7% 53% 11% 29% [2020-05-03][19:14:10] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 7% 33% 15% 5% 5% 4% 8% 6% 16% [2020-05-03][19:14:10] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 29% 8% 6% 9% 7% 11% 7% 14% [2020-05-03][19:14:10] x264 [info]: i8c dc,h,v,p: 40% 38% 14% 9% [2020-05-03][19:14:10] x264 [info]: Weighted P-Frames: Y:12.2% UV:0.8% [2020-05-03][19:14:10] x264 [info]: ref P L0: 62.4% 13.9% 18.1% 3.4% 1.9% 0.2% 0.0% [2020-05-03][19:14:10] x264 [info]: ref B L0: 86.7% 10.4% 2.5% 0.4% [2020-05-03][19:14:10] x264 [info]: ref B L1: 98.0% 2.0% [2020-05-03][19:14:10] x264 [info]: kb/s:2051.85 [2020-05-03][19:14:10] encoded 8896 frames, 19.35 fps, 2051.87 kb/s compare-script after that v1 = DGSource("test pf 3.dgi", crop_l=0, crop_r=0, crop_t=0, crop_b=0, deinterlace=0, use_top_field=true, use_pf=true) v2 = DGSource("test pf 5.dgi", crop_l=0, crop_r=0, crop_t=0, crop_b=0, deinterlace=0, use_top_field=true, use_pf=true) Compare(v1, v2) return last ![]() - edit - Maybe my encoding-settings are relevant too: [2020-05-03][18:59:23] Creating encoder process: [2020-05-03][18:59:23] "...\Simple x264 Launcher\toolset\x64\x264_x64.exe" --output-depth 8 --crf 18.0 --preset medium --tune film --trellis 2 --direct auto --me umh --partitions all --vbv-maxrate 24000 --vbv-bufsize 30000 --b-adapt 2 --bframes 5 --merange 24 --ref 5 --keyint 300 --subme 10 --aq-mode 1 --sar 1:1 --rc-lookahead 40 --output "...\test pf 3.mkv" --frames 8896 --demuxer y4m --stdin y4m - - edit - And another question: Should I use opt=0 or opt=3 with my CPU. Is neo_fft3d switching between different settings/routines while one job is running (opt=0) or is it using the same code for the whole job, once the decision is set at the beginning?
#63 | Link |
結城有紀
This. opt is only for debugging purpose. Normal users should never need to set this. > got different results Spent a few hours on comparing the results. First thing first, it's not multi-threading related. It's multi-run related, which means it was caused by multiple runs of the script, not because multiple runs have different thread count. Secondly, I can't figure out the fundamental reason. It seems to me like floating point computing error. For example, Code:
out[lfp.w][0] = incur[lfp.w][0]; out[lfp.w][1] = incur[lfp.w][1]; Code:
out[lfp.w][0] = incur[lfp.w][0] * 0.98f; out[lfp.w][1] = incur[lfp.w][1] * 0.98f; I have no clue what this is. I tried both /fp:precise and /fp:strict if that matters.
#64 | Link |
Do you even know what that does? Are you aware that there's nothing in your script that uses avstp?
Groucho's Avisynth Stuff |
#65 | Link |
@MeteorRain
Okay, I have dropped the parameter "opt" from my call for neo_fft3d. Do you know that fftw itself is internally multithreaded too? Maybe this is causing it? @Groucho Are you 100% sure about that? avstp is made by the author of dither tools. It handles the internal single-/multi-threading-functionality of the dither tools. Since I regularly use GradFun3, avstp is important to my scripts. If I only use GradFun3, then I turn off multithreading of my script (#prefetch) and don't use "avstp_set_threads" at all (#), so that GradFun3 can work multithreaded internal. If I use some filters which work faster multithreaded in my scripts, then I turn on "my" multithreading (prefetch) and turn off the internal mt of the dither tools (avstp_set_threads(1)), so that they do not interfere each other. "avstp_set_threads" has to be written at the very end of a script. Therefore I put it straight before the two very last commands of my scripts (prefetch and return) and handle it manually, by myself, to be absolutely in control of "my" mt and the avstp mt - and not within the mtmodes.avsi (I deleted the function within there). Nobody knows which routine is using avstp.dll for sure, right? Whether dither.avsi nor mt_xxpand_multi.avsi is including "avstp_set_threads" or "avstp". So this setting must be made from the dither.dll - or could; so any other .dll can do this too and make use of avstp.dll. I can check the thread-count with AVSMeter, but do I know 100% if a .dll is working mt or st at everytime? Maybe sometimes the thread-count changes during a job - I simply don't know, how routines are written internally; I can't look inside. Therefore, setting "avstp_set_threads(1)" is a safety measure everytime I turn on "my" mt with prefetch(). Last edited by almosely; 4th May 2020 at 00:31. |
#66 | Link |
I was referring to the script you posted in post #62. There's no plugin in that script that uses avstp. A far as I'm aware, only Dither.dll and mvtools2.dll use avstp.
In some cases, such as QTGMC, avstp can be beneficial in combination with Avisynth+'s internal MT, you have to experiment yourself. avstp initializes a thread pool in its constructor (IIRC) which could make things slower even if there's no plugin using avstp. The statement avstp_set_threads(1) does not disable avstp. I did some experiments with it some time ago and its sheer presence in the plugin directory influences the number of threads and the rendering speed, albeit slightly. Just some food for thought.
Groucho's Avisynth Stuff Last edited by Groucho2004; 4th May 2020 at 00:43. |
#67 | Link |
"could make things slower even if there's no plugin using avstp. The statement avstp_set_threads(1) does not disable avstp. I did some experiments with it some time ago and its sheer presence in the plugin directory influences the number of threads and the rendering speed"
Oha! Thank you for that advice :-) Then I will figure out a new routine of doing my scripting, probably with "LoadPlugin("xyz.dll")" calls, I don't know. - edit - @MeteorRain I am sorry, I am not a programmer (anymore); I used to be one, but that's 22 years ago. Since then I reorganized my brain to function in other ways, less rational (at least different from that time), more emotional, less mathematic, more optical etc. (studied design, now I am going to make some music again, after about 26 years ago, etc.). So I can't help you with C or something related, sadly. Last edited by almosely; 4th May 2020 at 01:04. |
#68 | Link | |
#69 | Link |
So, meanwhile I benched AviSynth+ 3.4.0 vs 3.5.1. The difference was negligibly if not accidental. Perhaps my memory is fooling me or it has something to do with the latest MSVC++ 2015-2019 Update - or my recent RAM upgrade from 2x4 GB to 4x4 GB. I don't know and I don't care anymore. AVS+ 3.5.1 will stay installed.
And I made a little test regarding avstp.dll. At first, I put avstp.dll out of the avs-plugins64+ folder into another folder. From there I can sideload it as necessary. I used the following scripts ... ST DGSource("test 1080p.dgi", crop_l=0, crop_r=0, crop_t=0, crop_b=0, deinterlace=0, use_top_field=true, use_pf=true) Trim(0, 1000) RequestLinear(rlim=100, clim=100) GradFun3(thr=0.35) return last ST mit avstp.dll LoadPlugin("...\AviSynth+ sideload\plugins64+\avstp.dll") DGSource("test 1080p.dgi", crop_l=0, crop_r=0, crop_t=0, crop_b=0, deinterlace=0, use_top_field=true, use_pf=true) Trim(0, 1000) RequestLinear(rlim=100, clim=100) GradFun3(thr=0.35) return last MT (pf 4) DGSource("test 1080p.dgi", crop_l=0, crop_r=0, crop_t=0, crop_b=0, deinterlace=0, use_top_field=true, use_pf=true) Trim(0, 1000) RequestLinear(rlim=100, clim=100) GradFun3(thr=0.35) Prefetch(4) return last MT (pf 4) mit avstp.dll LoadPlugin("...\AviSynth+ sideload\plugins64+\avstp.dll") DGSource("test 1080p.dgi", crop_l=0, crop_r=0, crop_t=0, crop_b=0, deinterlace=0, use_top_field=true, use_pf=true) Trim(0, 1000) RequestLinear(rlim=100, clim=100) GradFun3(thr=0.35) Prefetch(4) return last MT (pf 4) mit avstp.dll mit avstp_set_threads(1) LoadPlugin("...\AviSynth+ sideload\plugins64+\avstp.dll") DGSource("test 1080p.dgi", crop_l=0, crop_r=0, crop_t=0, crop_b=0, deinterlace=0, use_top_field=true, use_pf=true) Trim(0, 1000) RequestLinear(rlim=100, clim=100) GradFun3(thr=0.35) avstp_set_threads(1) Prefetch(4) return last ![]() In that specific case I don't need avstp.dll neither single- nor multi-threaded (it only hurts). So, thanks for the hint again, Groucho ;-) - edit - ... sorry for the german language (some words) sneaking in ;-)) Last edited by almosely; 4th May 2020 at 04:47. |
#70 | Link |
結城有紀
Seems like bw=48 was the problem. Can you try some different numbers like 32/40/56/64/96/128?
I still haven't figured out what went wrong, but this might be the right approach to the problem.
#71 | Link | |||
Hm, I just realized, that the original author set bw=32 as default, after he has set it to 48 at some time. Oddly I remembered that bw=48 would still be the default. I will try some other sizes.
Maybe it has something to do with his statement? Quote:
Now I know why I remember bw=48 as default, grml ... Quote:
#72 | Link | |
"%~dp0/sde" -- cmd.exe @rem "%~dp0/sde" -- cmd.exe @rem "c:\sde\sde" -mrm -- cmd.exe @rem "c:\sde\sde" -wsm -- cmd.exe @rem "c:\sde\sde" -skx -- c:\virtualdub\VirtualDub64.exe "c:\sde\sde" -skx -- cmd.exe @rem "c:\sde\sde" -wsm -- s1.bat @rem -mrm Set chip-check and CPUID for Merom @rem -pnr Set chip-check and CPUID for Penryn @rem -nhm Set chip-check and CPUID for Nehalem @rem -hsw Set chip-check and CPUID for Haswell @rem -wsm Set chip-check and CPUID for Westmere, no AVX @rem -skx Set chip-check and CPUID for SkyLakeX. AVX512F and AVX512BW but for visual tests this tool was good enough and I could even debug from Visual Studio by setting project properties|debugging to sde
#73 | Link |
結城有紀
SDE causes BSOD on my computer 100% time so I gave up after 2 hard CPU reset in 5 minutes.
#75 | Link |
Test-Script (avstp.dll not loaded anymore)
DGSource("test.dgi", crop_l=0, crop_r=0, crop_t=0, crop_b=0, deinterlace=0, use_top_field=true, use_pf=true) RequestLinear(rlim=50, clim=50) neo_fft3d(sigma=1.0, beta=1.0, bw=32, bh=32, sharpen=0.040, scutoff=0.01, y=3, u=2, v=2, bt=5) Prefetch(3) return last 32 + 3 [2020-05-04][08:09:02] y4m [info]: 1280x720p 1:1 @ 30000/1001 fps (cfr) [2020-05-04][08:09:02] x264 [info]: using SAR=1/1 [2020-05-04][08:09:02] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [2020-05-04][08:09:02] x264 [info]: profile High, level 4.0, 4:2:0, 8-bit [2020-05-04][08:16:36] x264 [info]: frame I:33 Avg QP:14.81 size:164393 [2020-05-04][08:16:36] x264 [info]: frame P:1781 Avg QP:18.28 size: 28087 [2020-05-04][08:16:36] x264 [info]: frame B:7082 Avg QP:26.96 size: 2921 [2020-05-04][08:16:36] x264 [info]: consecutive B-frames: 1.5% 1.4% 5.0% 6.5% 18.4% 67.2% [2020-05-04][08:16:36] x264 [info]: mb I I16..4: 3.6% 55.0% 41.4% [2020-05-04][08:16:36] x264 [info]: mb P I16..4: 0.5% 3.0% 2.4% P16..4: 44.0% 16.2% 16.3% 0.9% 0.4% skip:16.4% [2020-05-04][08:16:36] x264 [info]: mb B I16..4: 0.0% 0.1% 0.2% B16..8: 35.1% 2.9% 0.7% direct: 0.7% skip:60.3% L0:47.0% L1:44.0% BI: 9.0% [2020-05-04][08:16:36] x264 [info]: 8x8 transform intra:49.6% inter:31.2% [2020-05-04][08:16:36] x264 [info]: direct mvs spatial:99.9% temporal:0.1% [2020-05-04][08:16:36] x264 [info]: coded y,uvDC,uvAC intra: 86.4% 59.0% 33.8% inter: 7.1% 2.9% 0.3% [2020-05-04][08:16:36] x264 [info]: i16 v,h,dc,p: 7% 52% 12% 29% [2020-05-04][08:16:36] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 8% 33% 16% 5% 5% 4% 8% 6% 15% [2020-05-04][08:16:36] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 29% 8% 6% 9% 7% 11% 7% 14% [2020-05-04][08:16:36] x264 [info]: i8c dc,h,v,p: 40% 38% 14% 9% [2020-05-04][08:16:36] x264 [info]: Weighted P-Frames: Y:12.0% UV:0.7% [2020-05-04][08:16:36] x264 [info]: ref P L0: 62.3% 13.9% 18.2% 3.4% 1.9% 0.2% 0.0% [2020-05-04][08:16:36] x264 [info]: ref B L0: 86.6% 10.5% 2.5% 0.4% [2020-05-04][08:16:36] x264 [info]: ref B L1: 98.0% 2.0% [2020-05-04][08:16:36] x264 [info]: kb/s:2052.01 [2020-05-04][08:16:36] encoded 8896 frames, 19.47 fps, 2052.03 kb/s 32 + 5 [2020-05-04][08:16:41] y4m [info]: 1280x720p 1:1 @ 30000/1001 fps (cfr) [2020-05-04][08:16:41] x264 [info]: using SAR=1/1 [2020-05-04][08:16:41] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [2020-05-04][08:16:41] x264 [info]: profile High, level 4.0, 4:2:0, 8-bit [2020-05-04][08:24:11] x264 [info]: frame I:33 Avg QP:14.81 size:164393 [2020-05-04][08:24:11] x264 [info]: frame P:1781 Avg QP:18.28 size: 28087 [2020-05-04][08:24:11] x264 [info]: frame B:7082 Avg QP:26.96 size: 2921 [2020-05-04][08:24:11] x264 [info]: consecutive B-frames: 1.5% 1.4% 5.0% 6.5% 18.4% 67.2% [2020-05-04][08:24:11] x264 [info]: mb I I16..4: 3.6% 55.0% 41.4% [2020-05-04][08:24:11] x264 [info]: mb P I16..4: 0.5% 3.0% 2.4% P16..4: 44.0% 16.2% 16.3% 0.9% 0.4% skip:16.4% [2020-05-04][08:24:11] x264 [info]: mb B I16..4: 0.0% 0.1% 0.2% B16..8: 35.1% 2.9% 0.7% direct: 0.7% skip:60.3% L0:47.0% L1:44.0% BI: 9.0% [2020-05-04][08:24:11] x264 [info]: 8x8 transform intra:49.6% inter:31.2% [2020-05-04][08:24:11] x264 [info]: direct mvs spatial:99.9% temporal:0.1% [2020-05-04][08:24:11] x264 [info]: coded y,uvDC,uvAC intra: 86.4% 59.0% 33.8% inter: 7.1% 2.9% 0.3% [2020-05-04][08:24:11] x264 [info]: i16 v,h,dc,p: 7% 52% 12% 29% [2020-05-04][08:24:11] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 8% 33% 16% 5% 5% 4% 8% 6% 15% [2020-05-04][08:24:11] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 29% 8% 6% 9% 7% 11% 7% 14% [2020-05-04][08:24:11] x264 [info]: i8c dc,h,v,p: 40% 38% 14% 9% [2020-05-04][08:24:11] x264 [info]: Weighted P-Frames: Y:12.0% UV:0.7% [2020-05-04][08:24:11] x264 [info]: ref P L0: 62.3% 13.9% 18.2% 3.4% 1.9% 0.2% 0.0% [2020-05-04][08:24:11] x264 [info]: ref B L0: 86.6% 10.5% 2.5% 0.4% [2020-05-04][08:24:11] x264 [info]: ref B L1: 98.0% 2.0% [2020-05-04][08:24:11] x264 [info]: kb/s:2052.01 [2020-05-04][08:24:11] encoded 8896 frames, 19.63 fps, 2052.03 kb/s 40 + 3 [2020-05-04][08:24:14] y4m [info]: 1280x720p 1:1 @ 30000/1001 fps (cfr) [2020-05-04][08:24:14] x264 [info]: using SAR=1/1 [2020-05-04][08:24:14] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [2020-05-04][08:24:14] x264 [info]: profile High, level 4.0, 4:2:0, 8-bit [2020-05-04][08:31:26] x264 [info]: frame I:33 Avg QP:14.82 size:164351 [2020-05-04][08:31:26] x264 [info]: frame P:1781 Avg QP:18.27 size: 28114 [2020-05-04][08:31:26] x264 [info]: frame B:7082 Avg QP:26.98 size: 2912 [2020-05-04][08:31:26] x264 [info]: consecutive B-frames: 1.5% 1.5% 5.0% 6.4% 18.9% 66.7% [2020-05-04][08:31:26] x264 [info]: mb I I16..4: 3.8% 55.4% 40.8% [2020-05-04][08:31:26] x264 [info]: mb P I16..4: 0.5% 3.0% 2.3% P16..4: 44.1% 16.1% 16.4% 0.9% 0.4% skip:16.3% [2020-05-04][08:31:26] x264 [info]: mb B I16..4: 0.0% 0.1% 0.2% B16..8: 35.0% 2.9% 0.7% direct: 0.7% skip:60.4% L0:46.9% L1:44.1% BI: 9.0% [2020-05-04][08:31:26] x264 [info]: 8x8 transform intra:49.8% inter:31.3% [2020-05-04][08:31:26] x264 [info]: direct mvs spatial:99.9% temporal:0.1% [2020-05-04][08:31:26] x264 [info]: coded y,uvDC,uvAC intra: 86.6% 59.1% 33.9% inter: 7.2% 2.9% 0.3% [2020-05-04][08:31:26] x264 [info]: i16 v,h,dc,p: 7% 53% 12% 28% [2020-05-04][08:31:26] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 8% 33% 15% 5% 5% 4% 8% 6% 16% [2020-05-04][08:31:26] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 29% 8% 6% 9% 7% 11% 7% 14% [2020-05-04][08:31:26] x264 [info]: i8c dc,h,v,p: 40% 38% 14% 9% [2020-05-04][08:31:26] x264 [info]: Weighted P-Frames: Y:12.2% UV:0.7% [2020-05-04][08:31:26] x264 [info]: ref P L0: 62.2% 14.0% 18.2% 3.4% 2.0% 0.2% 0.0% [2020-05-04][08:31:26] x264 [info]: ref B L0: 86.6% 10.6% 2.5% 0.4% [2020-05-04][08:31:26] x264 [info]: ref B L1: 98.0% 2.0% [2020-05-04][08:31:26] x264 [info]: kb/s:2051.38 [2020-05-04][08:31:26] encoded 8896 frames, 20.52 fps, 2051.41 kb/s 40 + 5 [2020-05-04][08:31:29] y4m [info]: 1280x720p 1:1 @ 30000/1001 fps (cfr) [2020-05-04][08:31:29] x264 [info]: using SAR=1/1 [2020-05-04][08:31:29] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [2020-05-04][08:31:29] x264 [info]: profile High, level 4.0, 4:2:0, 8-bit [2020-05-04][08:38:40] x264 [info]: frame I:33 Avg QP:14.82 size:164351 [2020-05-04][08:38:40] x264 [info]: frame P:1781 Avg QP:18.27 size: 28114 [2020-05-04][08:38:40] x264 [info]: frame B:7082 Avg QP:26.98 size: 2912 [2020-05-04][08:38:40] x264 [info]: consecutive B-frames: 1.5% 1.5% 5.0% 6.4% 18.9% 66.7% [2020-05-04][08:38:40] x264 [info]: mb I I16..4: 3.8% 55.4% 40.8% [2020-05-04][08:38:40] x264 [info]: mb P I16..4: 0.5% 3.0% 2.3% P16..4: 44.1% 16.1% 16.4% 0.9% 0.4% skip:16.3% [2020-05-04][08:38:40] x264 [info]: mb B I16..4: 0.0% 0.1% 0.2% B16..8: 35.0% 2.9% 0.7% direct: 0.7% skip:60.4% L0:46.9% L1:44.1% BI: 9.0% [2020-05-04][08:38:40] x264 [info]: 8x8 transform intra:49.8% inter:31.3% [2020-05-04][08:38:40] x264 [info]: direct mvs spatial:99.9% temporal:0.1% [2020-05-04][08:38:40] x264 [info]: coded y,uvDC,uvAC intra: 86.6% 59.1% 33.9% inter: 7.2% 2.9% 0.3% [2020-05-04][08:38:40] x264 [info]: i16 v,h,dc,p: 7% 53% 12% 28% [2020-05-04][08:38:40] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 8% 33% 15% 5% 5% 4% 8% 6% 16% [2020-05-04][08:38:40] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 29% 8% 6% 9% 7% 11% 7% 14% [2020-05-04][08:38:40] x264 [info]: i8c dc,h,v,p: 40% 38% 14% 9% [2020-05-04][08:38:40] x264 [info]: Weighted P-Frames: Y:12.2% UV:0.7% [2020-05-04][08:38:40] x264 [info]: ref P L0: 62.2% 14.0% 18.2% 3.4% 2.0% 0.2% 0.0% [2020-05-04][08:38:40] x264 [info]: ref B L0: 86.6% 10.6% 2.5% 0.4% [2020-05-04][08:38:40] x264 [info]: ref B L1: 98.0% 2.0% [2020-05-04][08:38:40] x264 [info]: kb/s:2051.38 [2020-05-04][08:38:40] encoded 8896 frames, 20.51 fps, 2051.41 kb/s 56 + 3 [2020-05-04][08:38:44] y4m [info]: 1280x720p 1:1 @ 30000/1001 fps (cfr) [2020-05-04][08:38:44] x264 [info]: using SAR=1/1 [2020-05-04][08:38:44] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [2020-05-04][08:38:44] x264 [info]: profile High, level 4.0, 4:2:0, 8-bit [2020-05-04][08:45:29] x264 [info]: frame I:33 Avg QP:14.81 size:165176 [2020-05-04][08:45:29] x264 [info]: frame P:1780 Avg QP:18.27 size: 28208 [2020-05-04][08:45:29] x264 [info]: frame B:7083 Avg QP:26.94 size: 2909 [2020-05-04][08:45:29] x264 [info]: consecutive B-frames: 1.5% 1.6% 4.9% 6.2% 18.6% 67.2% [2020-05-04][08:45:29] x264 [info]: mb I I16..4: 3.9% 55.1% 41.1% [2020-05-04][08:45:29] x264 [info]: mb P I16..4: 0.5% 2.9% 2.3% P16..4: 44.2% 16.1% 16.4% 0.9% 0.4% skip:16.3% [2020-05-04][08:45:29] x264 [info]: mb B I16..4: 0.0% 0.1% 0.2% B16..8: 34.9% 2.8% 0.7% direct: 0.7% skip:60.5% L0:46.9% L1:44.0% BI: 9.1% [2020-05-04][08:45:29] x264 [info]: 8x8 transform intra:49.7% inter:31.4% [2020-05-04][08:45:29] x264 [info]: direct mvs spatial:99.9% temporal:0.1% [2020-05-04][08:45:29] x264 [info]: coded y,uvDC,uvAC intra: 86.9% 59.0% 33.7% inter: 7.2% 2.9% 0.3% [2020-05-04][08:45:29] x264 [info]: i16 v,h,dc,p: 7% 52% 12% 29% [2020-05-04][08:45:29] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 8% 33% 15% 5% 5% 4% 8% 6% 16% [2020-05-04][08:45:29] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 9% 28% 7% 6% 9% 7% 11% 7% 14% [2020-05-04][08:45:29] x264 [info]: i8c dc,h,v,p: 40% 38% 14% 9% [2020-05-04][08:45:29] x264 [info]: Weighted P-Frames: Y:12.1% UV:0.7% [2020-05-04][08:45:29] x264 [info]: ref P L0: 62.4% 14.0% 18.1% 3.4% 1.9% 0.2% 0.0% [2020-05-04][08:45:29] x264 [info]: ref B L0: 86.6% 10.5% 2.5% 0.3% [2020-05-04][08:45:29] x264 [info]: ref B L1: 98.0% 2.0% [2020-05-04][08:45:29] x264 [info]: kb/s:2055.54 [2020-05-04][08:45:29] encoded 8896 frames, 21.85 fps, 2055.56 kb/s 56 + 5 [2020-05-04][08:45:32] y4m [info]: 1280x720p 1:1 @ 30000/1001 fps (cfr) [2020-05-04][08:45:32] x264 [info]: using SAR=1/1 [2020-05-04][08:45:32] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [2020-05-04][08:45:32] x264 [info]: profile High, level 4.0, 4:2:0, 8-bit [2020-05-04][08:52:17] x264 [info]: frame I:33 Avg QP:14.81 size:165176 [2020-05-04][08:52:17] x264 [info]: frame P:1780 Avg QP:18.27 size: 28208 [2020-05-04][08:52:17] x264 [info]: frame B:7083 Avg QP:26.93 size: 2909 [2020-05-04][08:52:17] x264 [info]: consecutive B-frames: 1.5% 1.6% 4.9% 6.2% 18.6% 67.2% [2020-05-04][08:52:17] x264 [info]: mb I I16..4: 3.9% 55.1% 41.1% [2020-05-04][08:52:17] x264 [info]: mb P I16..4: 0.5% 2.9% 2.3% P16..4: 44.2% 16.1% 16.4% 0.9% 0.4% skip:16.3% [2020-05-04][08:52:17] x264 [info]: mb B I16..4: 0.0% 0.1% 0.2% B16..8: 34.9% 2.8% 0.7% direct: 0.7% skip:60.5% L0:46.9% L1:44.0% BI: 9.1% [2020-05-04][08:52:17] x264 [info]: 8x8 transform intra:49.7% inter:31.4% [2020-05-04][08:52:17] x264 [info]: direct mvs spatial:99.9% temporal:0.1% [2020-05-04][08:52:17] x264 [info]: coded y,uvDC,uvAC intra: 86.9% 59.0% 33.7% inter: 7.2% 2.9% 0.3% [2020-05-04][08:52:17] x264 [info]: i16 v,h,dc,p: 7% 52% 12% 29% [2020-05-04][08:52:17] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 8% 33% 15% 5% 5% 4% 8% 6% 16% [2020-05-04][08:52:17] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 9% 28% 7% 6% 9% 7% 11% 7% 14% [2020-05-04][08:52:17] x264 [info]: i8c dc,h,v,p: 40% 38% 14% 9% [2020-05-04][08:52:17] x264 [info]: Weighted P-Frames: Y:12.1% UV:0.7% [2020-05-04][08:52:17] x264 [info]: ref P L0: 62.4% 14.0% 18.1% 3.4% 1.9% 0.2% 0.0% [2020-05-04][08:52:17] x264 [info]: ref B L0: 86.6% 10.5% 2.5% 0.3% [2020-05-04][08:52:17] x264 [info]: ref B L1: 98.0% 2.0% [2020-05-04][08:52:17] x264 [info]: kb/s:2055.56 [2020-05-04][08:52:17] encoded 8896 frames, 21.83 fps, 2055.58 kb/s 64 + 3 [2020-05-04][08:52:21] y4m [info]: 1280x720p 1:1 @ 30000/1001 fps (cfr) [2020-05-04][08:52:21] x264 [info]: using SAR=1/1 [2020-05-04][08:52:21] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [2020-05-04][08:52:21] x264 [info]: profile High, level 4.0, 4:2:0, 8-bit [2020-05-04][08:59:29] x264 [info]: frame I:33 Avg QP:14.81 size:165277 [2020-05-04][08:59:29] x264 [info]: frame P:1778 Avg QP:18.28 size: 28214 [2020-05-04][08:59:29] x264 [info]: frame B:7085 Avg QP:26.92 size: 2904 [2020-05-04][08:59:29] x264 [info]: consecutive B-frames: 1.4% 1.6% 5.0% 6.4% 18.2% 67.4% [2020-05-04][08:59:29] x264 [info]: mb I I16..4: 3.8% 55.2% 41.0% [2020-05-04][08:59:29] x264 [info]: mb P I16..4: 0.5% 2.9% 2.3% P16..4: 44.2% 16.1% 16.3% 0.9% 0.4% skip:16.3% [2020-05-04][08:59:29] x264 [info]: mb B I16..4: 0.0% 0.1% 0.2% B16..8: 34.9% 2.8% 0.7% direct: 0.7% skip:60.6% L0:46.8% L1:44.2% BI: 9.0% [2020-05-04][08:59:29] x264 [info]: 8x8 transform intra:49.8% inter:31.5% [2020-05-04][08:59:29] x264 [info]: direct mvs spatial:99.9% temporal:0.1% [2020-05-04][08:59:29] x264 [info]: coded y,uvDC,uvAC intra: 87.0% 59.1% 33.8% inter: 7.2% 2.9% 0.3% [2020-05-04][08:59:29] x264 [info]: i16 v,h,dc,p: 7% 52% 12% 29% [2020-05-04][08:59:29] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 7% 33% 15% 5% 5% 4% 8% 6% 16% [2020-05-04][08:59:29] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 9% 28% 7% 6% 9% 7% 11% 7% 14% [2020-05-04][08:59:29] x264 [info]: i8c dc,h,v,p: 40% 38% 14% 9% [2020-05-04][08:59:29] x264 [info]: Weighted P-Frames: Y:12.1% UV:0.7% [2020-05-04][08:59:29] x264 [info]: ref P L0: 62.4% 14.0% 18.1% 3.4% 1.9% 0.2% 0.0% [2020-05-04][08:59:29] x264 [info]: ref B L0: 86.7% 10.4% 2.5% 0.4% [2020-05-04][08:59:29] x264 [info]: ref B L1: 98.0% 2.0% [2020-05-04][08:59:29] x264 [info]: kb/s:2053.48 [2020-05-04][08:59:29] encoded 8896 frames, 20.66 fps, 2053.50 kb/s 64 + 5 [2020-05-04][08:59:33] y4m [info]: 1280x720p 1:1 @ 30000/1001 fps (cfr) [2020-05-04][08:59:33] x264 [info]: using SAR=1/1 [2020-05-04][08:59:33] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [2020-05-04][08:59:33] x264 [info]: profile High, level 4.0, 4:2:0, 8-bit [2020-05-04][09:06:42] x264 [info]: frame I:33 Avg QP:14.81 size:165277 [2020-05-04][09:06:42] x264 [info]: frame P:1778 Avg QP:18.28 size: 28214 [2020-05-04][09:06:42] x264 [info]: frame B:7085 Avg QP:26.92 size: 2904 [2020-05-04][09:06:42] x264 [info]: consecutive B-frames: 1.4% 1.6% 5.0% 6.4% 18.2% 67.4% [2020-05-04][09:06:42] x264 [info]: mb I I16..4: 3.8% 55.2% 41.0% [2020-05-04][09:06:42] x264 [info]: mb P I16..4: 0.5% 2.9% 2.3% P16..4: 44.2% 16.1% 16.3% 0.9% 0.4% skip:16.3% [2020-05-04][09:06:42] x264 [info]: mb B I16..4: 0.0% 0.1% 0.2% B16..8: 34.9% 2.8% 0.7% direct: 0.7% skip:60.6% L0:46.8% L1:44.2% BI: 9.0% [2020-05-04][09:06:42] x264 [info]: 8x8 transform intra:49.8% inter:31.5% [2020-05-04][09:06:42] x264 [info]: direct mvs spatial:99.9% temporal:0.1% [2020-05-04][09:06:42] x264 [info]: coded y,uvDC,uvAC intra: 87.0% 59.1% 33.8% inter: 7.2% 2.9% 0.3% [2020-05-04][09:06:42] x264 [info]: i16 v,h,dc,p: 7% 52% 12% 29% [2020-05-04][09:06:42] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 7% 33% 15% 5% 5% 4% 8% 6% 16% [2020-05-04][09:06:42] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 9% 28% 7% 6% 9% 7% 11% 7% 14% [2020-05-04][09:06:42] x264 [info]: i8c dc,h,v,p: 40% 38% 14% 9% [2020-05-04][09:06:42] x264 [info]: Weighted P-Frames: Y:12.1% UV:0.7% [2020-05-04][09:06:42] x264 [info]: ref P L0: 62.4% 14.1% 18.1% 3.4% 1.9% 0.2% 0.0% [2020-05-04][09:06:42] x264 [info]: ref B L0: 86.7% 10.4% 2.5% 0.4% [2020-05-04][09:06:42] x264 [info]: ref B L1: 98.0% 2.0% [2020-05-04][09:06:42] x264 [info]: kb/s:2053.46 [2020-05-04][09:06:42] encoded 8896 frames, 20.63 fps, 2053.48 kb/s |
#77 | Link |
結城有紀
Don't just test two tests. Take more tests. Trim the video short.
In my tests they have certain results, and you may happen to hit the identical one in that 2 attempts.
#78 | Link |
Okay, bw=48 with opt=3, with loaded or unloaded or loaded and "deactivated" avstp.dll were all different from each other.
Then I ran the test again for 32, 40, 48, 56, 64, without avstp.dll and without opt=3, for each bw-size 3 times per prefetch (3 or 5). This time trimmed (0-1000 frames). Only bw=32 was consistent. Alle three pf 3 were the same, all three pf 5 and all six of them together. Additionally only bw=56 with pf 5 was consistent. Everything else had different results. This time I ran 3 jobs at a time, parallel. All of the last tests were one job at a time, after another. - edit - If your results are consistent, could it be that my system is the error? Maybe my undervolted cpu or my newly added second ram-kit? My CPU is undervolted since a year. I never had issues. I tested it that time with Intel Processor Diagnostic Tool and some x264 encodings. From that point where IPDT and/or x264 gave error messages I went up with the offset for 0.030 Volt. Since then I never had any issue with the offset of -0.190 V. And with my RAM: I did runs with Memtest86+ 5.01, for my old 2x 4GB Kit and one for the new constellation of 4x 4GB (two 2-RAM-Kits of the same type from the same vendor). Both tests passed without an error. HWiNFO displays the same adjustment results for each configuration (8/16 GB); the only different thing is the RAM command rate (changed from 1T to 2T). I really hope, that my system is not the reason for that x264 results. - edit - I am running the same tests with fft3dfilter right now. Seems that it ends the same way as with neo_fft3d. Till now, all six bw=32 tests gave identical results. All six bw=40 had different results from each other. The rest is running. - edit - So, almost the same with fft3dfilter. All six bw=32 tests gave identical results. All other bws gave different results to each other run. And there is a little difference between neo_fft3d and fft3dfilter (both bw=32). Please do not compare the fps, they are not representative in this case. neo_fft3d [2020-05-05][00:18:50] y4m [info]: 1280x720p 1:1 @ 30000/1001 fps (cfr) [2020-05-05][00:18:50] x264 [info]: using SAR=1/1 [2020-05-05][00:18:50] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [2020-05-05][00:18:50] x264 [info]: profile High, level 4.0, 4:2:0, 8-bit [2020-05-05][00:21:08] x264 [info]: frame I:5 Avg QP:16.06 size:156722 [2020-05-05][00:21:08] x264 [info]: frame P:207 Avg QP:18.58 size: 28493 [2020-05-05][00:21:08] x264 [info]: frame B:789 Avg QP:26.66 size: 3141 [2020-05-05][00:21:08] x264 [info]: consecutive B-frames: 1.6% 1.6% 8.4% 8.0% 17.5% 62.9% [2020-05-05][00:21:08] x264 [info]: mb I I16..4: 5.2% 48.4% 46.5% [2020-05-05][00:21:08] x264 [info]: mb P I16..4: 0.5% 2.8% 2.3% P16..4: 44.0% 15.2% 16.4% 1.1% 0.6% skip:17.1% [2020-05-05][00:21:08] x264 [info]: mb B I16..4: 0.0% 0.1% 0.2% B16..8: 36.4% 3.1% 0.7% direct: 1.0% skip:58.5% L0:44.7% L1:44.3% BI:11.1% [2020-05-05][00:21:08] x264 [info]: 8x8 transform intra:47.7% inter:34.3% [2020-05-05][00:21:08] x264 [info]: direct mvs spatial:99.2% temporal:0.8% [2020-05-05][00:21:08] x264 [info]: coded y,uvDC,uvAC intra: 84.9% 57.5% 31.5% inter: 8.2% 3.2% 0.3% [2020-05-05][00:21:08] x264 [info]: i16 v,h,dc,p: 7% 51% 12% 30% [2020-05-05][00:21:08] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 7% 33% 15% 5% 5% 4% 8% 6% 16% [2020-05-05][00:21:08] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 29% 8% 6% 8% 7% 11% 7% 14% [2020-05-05][00:21:08] x264 [info]: i8c dc,h,v,p: 41% 37% 13% 8% [2020-05-05][00:21:08] x264 [info]: Weighted P-Frames: Y:25.1% UV:1.0% [2020-05-05][00:21:08] x264 [info]: ref P L0: 66.9% 14.3% 14.3% 2.7% 1.6% 0.2% 0.0% [2020-05-05][00:21:08] x264 [info]: ref B L0: 88.4% 9.2% 2.0% 0.3% [2020-05-05][00:21:08] x264 [info]: ref B L1: 98.2% 1.8% [2020-05-05][00:21:08] x264 [info]: kb/s:2194.06 [2020-05-05][00:21:08] encoded 1001 frames, 7.06 fps, 2194.25 kb/s fft3dfilter [2020-05-05][02:18:35] y4m [info]: 1280x720p 1:1 @ 30000/1001 fps (cfr) [2020-05-05][02:18:35] x264 [info]: using SAR=1/1 [2020-05-05][02:18:35] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [2020-05-05][02:18:35] x264 [info]: profile High, level 4.0, 4:2:0, 8-bit [2020-05-05][02:20:59] x264 [info]: frame I:5 Avg QP:16.05 size:156878 [2020-05-05][02:20:59] x264 [info]: frame P:207 Avg QP:18.59 size: 28492 [2020-05-05][02:20:59] x264 [info]: frame B:789 Avg QP:26.72 size: 3146 [2020-05-05][02:20:59] x264 [info]: consecutive B-frames: 1.6% 1.6% 8.4% 8.0% 17.5% 62.9% [2020-05-05][02:20:59] x264 [info]: mb I I16..4: 5.3% 48.2% 46.4% [2020-05-05][02:20:59] x264 [info]: mb P I16..4: 0.5% 2.9% 2.3% P16..4: 44.2% 15.1% 16.3% 1.1% 0.5% skip:17.1% [2020-05-05][02:20:59] x264 [info]: mb B I16..4: 0.1% 0.1% 0.2% B16..8: 36.4% 3.1% 0.7% direct: 1.0% skip:58.5% L0:44.8% L1:44.2% BI:11.0% [2020-05-05][02:20:59] x264 [info]: 8x8 transform intra:47.9% inter:34.6% [2020-05-05][02:20:59] x264 [info]: direct mvs spatial:99.2% temporal:0.8% [2020-05-05][02:20:59] x264 [info]: coded y,uvDC,uvAC intra: 84.9% 57.5% 31.6% inter: 8.2% 3.2% 0.3% [2020-05-05][02:20:59] x264 [info]: i16 v,h,dc,p: 7% 51% 12% 30% [2020-05-05][02:20:59] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 7% 33% 15% 5% 5% 4% 8% 6% 16% [2020-05-05][02:20:59] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 9% 29% 8% 6% 8% 7% 11% 7% 14% [2020-05-05][02:20:59] x264 [info]: i8c dc,h,v,p: 41% 37% 13% 8% [2020-05-05][02:20:59] x264 [info]: Weighted P-Frames: Y:25.1% UV:1.0% [2020-05-05][02:20:59] x264 [info]: ref P L0: 66.8% 14.3% 14.4% 2.7% 1.6% 0.2% 0.0% [2020-05-05][02:20:59] x264 [info]: ref B L0: 88.4% 9.3% 2.0% 0.3% [2020-05-05][02:20:59] x264 [info]: ref B L1: 98.3% 1.7% [2020-05-05][02:20:59] x264 [info]: kb/s:2195.05 [2020-05-05][02:20:59] encoded 1001 frames, 6.72 fps, 2195.24 kb/s Last edited by almosely; 5th May 2020 at 01:52. |
#79 | Link |
結城有紀
A few assumptions / points here:
1) For 1 frame long clip at bw=48 I get 3 possible results after ~10 runs. x264 [info]: kb/s:6861.36 x264 [info]: kb/s:6863.66 x264 [info]: kb/s:6864.24 So I assume there are certain results possible, and are deterministic. I get one of them randomly. Maybe it's memory bound -- different memory position / alignment gives different result? 2) prefetch should not affect results. If it's deterministic, it is no matter prefetch or single threaded. 3) Both filter didn't use avstp, so you shouldn't need to take it into consideration. 4) I don't think your hardware is at fault. 5) Core code (algorithm) remains the same between fft3dfilter and neo_fft3d, hence they behaved the same on bw=32/40/48.
#80 | Link |
Have you also tested with only 1 thread in x264?(idk if multiple threads have any impact on 1 frame, but better be sure)
| Thread Tools | |
| Display Modes | |
