Thread Tools Display Modes
Old 25th April 2010, 22:08   #621  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by Dark Shikari View Post
TempgaussMC + spline36resize.
Thanks for the info
May I also ask which release of TempGaussMC you used (it seems there are several releases floating around) and which parameters you used?
Old 25th April 2010, 22:12   #622  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Originally Posted by LoRd_MuldeR View Post
Thanks for the info
AssumeFPS(30000/1001)
AssumeTFF()
TempGaussMC_beta2(edimode="eedi2")
Old 26th April 2010, 08:57   #623  |  Link
jpsdr
Where this TempGaussMC can be found ? I've trouble to get it.
Old 26th April 2010, 09:49   #624  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
Here.
Have fun with it :3
Edit: Also, there's the MVT2 version.
[I'm human, no debug]
JEEB is offline   Reply With Quote
Old 26th April 2010, 09:50   #625  |  Link
Audionut
First hit on google leads to this thread.
http://forum.doom9.org/showthread.ph...26#post1378526
http://www.7-zip.org/
Old 26th April 2010, 10:00   #626  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
Oh yes, forgot about that thread as it's where it got officially released IIRC.
So I guess Didée never made a custom topic for it?
Old 26th April 2010, 13:56   #627  |  Link
jpsdr
Thanks for the answers.
However, i thought it was only a de-interlacer, but apparently there is also noise removal, something i don't want...
Old 26th April 2010, 14:03   #628  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
It uses very slight denoising in order to get a better deinterlacing result. I think you can somewhat edit the strength of this given feature as well.
Old 26th April 2010, 14:08   #629  |  Link
nm
You can also bypass noise/grain, as Didée suggests here: http://forum.doom9.org/showthread.ph...44#post1324744
Old 28th April 2010, 20:30   #630  |  Link
LoRd_MuldeR
Software Developer
Just in case somebody is interested, here is the properly deinterlaced/bobbed 720p version of the "Tallship" sequence:
TallShip 720p60 lossless HuffYUV
http://video-test-sequences.hexagon....ssless_HuffYUV
Video: 1280×720 @ 60fps
Format: lossless HuffYUV in AVI
Audio: None
Duration: 5 min 35 s
Size: 13.5 GB (14.588.695.700 bytes)
MD5 sum: 9f17425c3a1322503bfc2a590767c3c5
Author: Ben Waggoner, Copyright 2005 Microsoft Corporation
License: similar to CC Attribution (see end of the credits in video)
Old 28th April 2010, 21:53   #631  |  Link
kieranrk
Explain what you mean by "properly"?
kieranrk is offline   Reply With Quote
Old 28th April 2010, 21:53   #632  |  Link
LoRd_MuldeR
Software Developer
http://forum.doom9.org/showpost.php?...&postcount=622
Old 28th April 2010, 23:30   #633  |  Link
kolak
Audio: None
Cool- will test "my encoder" against DS' x264 encode
update: or maybe not if download speed is so low
Old 28th April 2010, 23:35   #634  |  Link
LoRd_MuldeR
Software Developer
Yes, my upstream is SLOW. And I cannot keep the machine running 24/7. Hopefully somebody with a faster connection can join after the initial seed...
Old 29th April 2010, 01:50   #635  |  Link
mariush
Well I'm joining the fun and I'll try to seed it for a couple of weeks - if only I can get it from you cause i see 2 peers but no download from any of them. Mulder check your YM - maybe we can working something out.
mariush is offline   Reply With Quote
Old 29th April 2010, 07:25   #636  |  Link
VincAlastor
can someone explain following to me, please or show me a good thread with offical information, please?
i am a little bit confused, in many doom9 threads i gather information about x264 blu ray compliant settings, but now i am not sure any more. are the following settings compliant for 1080p/24? or 720p/24:
--pass 2 --bitrate 4000-8000 --stats ".stats" --deblock -1:-1 --b-adapt 2 --weightp 0 --rc-lookahead 48 --aq-strength 0.5 --me umh --direct auto --trellis 2 --psy-rd 1.0:0.25 --no-fast-pskip --profile high --level 4.1 --bframes 3 --ref 4 (6 for 720p/24?) --slices 4 --aud --nal-hrd vbr --b-pyramid strict --keyint 48 --min-keyint 2(i think 1 is better, but everyone set "2") --vbv-bufsize 30000 --vbv-maxrate 15000 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --output "output" "input"
VincAlastor is offline   Reply With Quote
Old 29th April 2010, 09:43   #637  |  Link
mp3dom
You can have max keyint every 2 seconds (48 for 24p) only if you stay below 15 Mbps for maxrate. Since you're setting a maxrate to 40 Mbps, your keyint is out of specs. Lower it to 24 (set 24 also to rc-lookahead or simply doesn't set it). Other settings, while in specs, are quite unbalanced for a BD. There's no way to have only a 4/8 Mbps average bitrate until you have very limited space above all the fact that you have plenty of space.
Old 29th April 2010, 10:58   #638  |  Link
LoRd_MuldeR
Software Developer
Sorry, I'm not at home right now and my machine isn't running. Won't return until late this night...
But I can continue seeding tomorrow morning!
Old 29th April 2010, 12:18   #639  |  Link
Biggiesized
Biggiesized's Avatar
I'm seeding the 1080i YUY2 version, but I only have about 35% done.
Biggiesized is offline   Reply With Quote
Old 30th April 2010, 09:30   #640  |  Link
LoRd_MuldeR
Software Developer
Should be up and running now...
Thread Tools
