17th February 2021, 20:49 | #961 | Link | |
2 separate issues are being referred to 1) One is your original 120000/1001 vs. 120.0 fps issue . The input in my little test is clearly 119.88fps Code:
Stream #0:0, 11, 1001/120000: Video: rawvideo (I420 / 0x30323449), yuv420p(progressive), 640x480, 119.88 fps, 120 tbr, 119.88 tbn, 119.88 tbc Code:
Stream #0:0, 0, 1/120: Video: wrapped_avframe, yuv420p(progressive), 640x480, q=2-31, 200 kb/s, 120 fps, 120 tbn Code:
[graph 0 input from stream 0:0 @ 0000000afe895840] Setting 'frame_rate' to value '120/1' 2) Second is the general issue of MKV container default 1/1000s timebase resulting in rounded timestamps. It's fine for playback. Not ok for other workflows with intermediates - potential for propogating errors eg. The same 24000/1001 video is encoded using MP4 container vs. MKV container The resulting timestamps look like this MKV Code:
0 42 83 125 167 . . . Code:
0 41.7083333333333 83.4166666666667 125.125 166.833333333333 . . . Read this for the math https://www.nmm-hd.org/newbbs/viewto...art=290#p10428 |
17th February 2021, 21:17 | #962 | Link | ||
Location: Mansfield, Ohio (formerly San Jose, California)
If, in addition to the PES's 'PES_HEADER_EXTENSION', the MKV container also stores PTS (but truncated to milliseconds), then MKV is seriously flawed. But I find it hard to believe that MKV (or any container TS) does that. I can't say it doesn't because, as I said, I don't know MKV formatting, but I can say that it would be really strange. Edit: I would say, stick with the PTSs as stored in the PES and ignore what MKV has in the TS (if, indeed, it does that). Last edited by markfilipak; 17th February 2021 at 21:20. |
18th February 2021, 00:09 | #964 | Link | |
It's the same thing as 2.vpy without selecteven, or you can comment it out Code:
import vapoursynth as vs core = vs.get_core() clip = core.std.BlankClip(format=vs.YUV420P8, length=240, color=[16, 128, 128]) clip = core.text.FrameNum(clip) clip = core.std.AssumeFPS(clip, fpsnum=120000, fpsden=1001) clip.set_output() |
18th February 2021, 00:40 | #965 | Link |
For the 120fps vs. 120000/1001 - you can encode 1.vpy with other tools like x264cli, x265cli, it results in the proper 120000/1001 output. You can check the encoded framerate and timestamps with other tools, they all agree, even ffprobe/ffmpeg says the x264cli output is 119.88fps not 120fps
The ffmpeg " Setting 'frame_rate' to value '120/1' " I think is not intended behaviour |
18th February 2021, 03:52 | #966 | Link | |
Regarding an MPEG2 PES,
The change is, of course, perfectly okay if the fps change happens at a keyframe. In fact, it can happen solely at keyframes. Currently, I transcode for the main part of the feature or extra, not the opener or splash. I don't care about them. Often, I cut them out. What I infer from what you write is that ffmpeg (and other tools) don't allow for VFR coming out of the decoder. Am I correct? If so, that's too bad and aught to be fixed. Putting framerate in the transport stream is a poor choice from an architectural point of view. Oh, well. I understand what you mean now when you say that MKV is a bad choice. And I agree. I picked it solely because it's popular, everthing seems to play it, Handbrake & MKVToolNix, and people said to avoid MP4. |
18th February 2021, 04:05 | #967 | Link | ||
He is diddling SAR based, not on differential resampling of source pixels at a different sample aspect, but on what makes other things work -- at least, that's what I think (sort of offsetting penalties in various use-cases). |
18th February 2021, 04:41 | #968 | Link | |
I never said "bad choice" ; I said It's perfectly fine for final playback purposes. Don't overlook the other advantages that MKV has over other containers in stream support, A/V format support, sub support, attachments, ordered chapters. There are pros/cons to everything. |
19th February 2021, 05:16 | #970 | Link |
You are so far down the road I'm trudging... May I ask: What if I transcode to MP4 and then remux to MKV? Would that be the best of both worlds? Would that be the best solution in my quest for perfection?
19th February 2021, 23:46 | #972 | Link | |
Is that what you demonstated by writing to NULL? Do I have that right? Oh, dear. I guess 1 kHz TB is baked into the decoder, right? If so, then there is no 'better' tool, or is there? Do all transcoding apps use the same decoders? |
20th February 2021, 01:03 | #973 | Link | |
What you start with doesn't matter in this MKV tbn regard ("tbn" what ffmpeg labels the container timebase), as soon as you put it into MKV, you use the 1K tbn. It doesn't matter what you use to parse the MKV . It does not matter if you non-ffmpeg/libavcodec tools either You would expect (or I expected from prior tests years past) there to be no difference with using MP4 step - and I retested it again today, then read the timestamps in the output MKV file, and it confirms no difference. Those little rounding differences are not a problem for regular end playback situations. You have to be superhuman to perceive some difference. But it can be an issue for intermediates and some types of workflows NUL is partly to help avoid all the other variables. It's part of the "basic scientific method (TM)". Eliminate all the other confounding variables like filters, containers, audio etc.. eg. Maybe adding of subtitles screws up timing; Maybe muxing audio screws something else up, etc... Strip it down to the smallest elements that can reproduce the issue. The issue was the 120000/1001 to 120 fps change. So that's what you test. Don't go testing other stuff or adding extraneous things unless you find out it's contributing to the problem. For debugging nobody want to wait for libx265 to complete. Nobody wants to download a big file to test, unless it's actually part of the problem. If you can simplify everything, each test run observation goes faster. If you can reproduce with blankclip or something like testsrc2 in ffmpeg, all the better. Do some of the legwork - so if there is a real bug - the developer does not have to spend extra time working things out |
26th February 2021, 03:57 | #974 | Link |
Pipe from ffmpeg to vs
Because of excellent help here -- thank you ChaosKing & lansing & poisondeathray -- I succeeded piping vspipe to ffmpeg.
Now, I need to go in the opposite direction. I did a ton of reading and head scratching, then I guessed (and failed twice). What's wrong? Failure #1 Code:
ECHO from vapoursynth import core>Mark's.vpy ECHO video = core.ffms2.Source(source=-)>>Mark's.vpy ECHO import havsfunc as havsfunc>>Mark's.vpy ECHO video = havsfunc.InterFrame(video, Preset="medium", Tuning="smooth", InputType="2D", NewNum=60000, NewDen=1001, GPU=True)>>Mark's.vpy ECHO video.set_output()>>Mark's.vpy ffmpeg -i INPUT.MKV -vf "...works.skipping..." -f rawvideo - | vspipe --y4m Mark's.vpy OUTPUT.MKV ... Output #0, rawvideo, to 'pipe:': Metadata: encoder : Lavf58.65.101 Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p(tv, smpte170m, progressive), 240x236 [SAR 32:27 DAR 640:531], q=2-31, 16296 kb/s, 23.98 fps, 23.98 tbn (default) Metadata: _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES BPS-eng : 642744 DURATION-eng : 00:00:05.739000000 NUMBER_OF_FRAMES-eng: 172 NUMBER_OF_BYTES-eng: 461089 _STATISTICS_WRITING_APP-eng: mkvmerge v51.0.0 ('I Wish') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2020-12-21 04:14:21 DURATION : 00:00:05.739000000 encoder : Lavc58.119.100 rawvideo Script evaluation failed: Python exception: invalid syntax (Mark's.vpy, line 2) Traceback (most recent call last): File "src\cython\vapoursynth.pyx", line 2241, in vapoursynth.vpy_evaluateScript File "Mark's.vpy", line 2 video = core.ffms2.Source(source=-) ^ SyntaxError: invalid syntax av_interleaved_write_frame(): Broken pipe Error writing trailer of pipe:: Broken pipetime=00:00:00.04 bitrate=16296.2kbits/s speed=0.453x frame= 1 fps=0.3 q=-0.0 Lsize= 83kB time=00:00:00.04 bitrate=16296.2kbits/s speed=0.0121x video:83kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000% Conversion failed! Code:
ECHO from vapoursynth import core>Mark's.vpy ECHO video = core.ffms2.Source(source=-)>>Mark's.vpy ECHO import havsfunc as havsfunc>>Mark's.vpy ECHO video = havsfunc.InterFrame(video, Preset="medium", Tuning="smooth", InputType="2D", NewNum=60000, NewDen=1001, GPU=True)>>Mark's.vpy ECHO video.output(OUTPUT.MKV)>>Mark's.vpy ffmpeg -i INPUT.MKV -vf "...works.skipping..." -f rawvideo - | vspipe --y4m Mark's.vpy ... Output #0, rawvideo, to 'pipe:': Metadata: encoder : Lavf58.65.101 Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p(tv, smpte170m, progressive), 240x236 [SAR 32:27 DAR 640:531], q=2-31, 16296 kb/s, 23.98 fps, 23.98 tbn (default) Metadata: _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES BPS-eng : 642744 DURATION-eng : 00:00:05.739000000 NUMBER_OF_FRAMES-eng: 172 NUMBER_OF_BYTES-eng: 461089 _STATISTICS_WRITING_APP-eng: mkvmerge v51.0.0 ('I Wish') 64-bit _STATISTICS_WRITING_DATE_UTC-eng: 2020-12-21 04:14:21 DURATION : 00:00:05.739000000 encoder : Lavc58.119.100 rawvideo av_interleaved_write_frame(): Invalid argument Error writing trailer of pipe:: Invalid argument00:00:00.04 bitrate=16296.2kbits/s speed= 0.4x frame= 1 fps=0.0 q=-0.0 Lsize= 83kB time=00:00:00.04 bitrate=16296.2kbits/s speed=0.18x video:83kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000% Conversion failed! Last edited by markfilipak; 26th February 2021 at 04:28. |
26th February 2021, 04:40 | #975 | Link | |
ffmpeg raw pipe to vpy can be done with vsrawsource https://github.com/HolyWu/vsrawsource/releases/ But vapoursynth usually is not used to write an output file directly without other libraries, typically you'd pipe to something else to write the final file (such has ffmpeg or similar) It would look like this Code:
ffmpeg -i "input.mkv" -vf..... -f rawvideo - | vspipe --y4m script.vpy - | ffmpeg -f yuv4mpegpipe -i - ..... "output.mkv" Where the source filter in the vpy would look something like this. A rawvideo pipe require you to enter dimensions, pixel format, and framerate. yuv4mpegpipe does not. Since you're sending rawvideo from ffmpeg into the vpy script, you have to enter those parameters Code:
video = core.raws.Source("-", width=1920, height=1080, src_fmt="YUV420P8", fpsnum=24000, fpsden=1001) It would usually make more sense to do the filtering in vapoursynth since you're already using it for interframe, then to ffmpeg to write the final file . Piping back and forth adds overhead (slower, more memory consumption). A simplified workflow, fewer steps is generally preferred, unless there are some ffmpeg operations that you cannot emulate in vapoursynth And if your desired output is in MKV container , it's still going to have a timebase of 1/1000s |
26th February 2021, 06:12 | #976 | Link | |
Thanks for the push. Maybe I can get the rest of the way out of the ditch on my own. I'll try. I'm doing a lot of processing because the source was telecined, then a frame dropped back to 24fps, then a frame repeated back to 30fps... not by me, but I assume by a video engineer who did not have the intermediates -- originals had probably been discarded -- and the engineer needed to integrate the result in with a mix of other telecined material and NTSC video and 30fps progressive. It's a mess, but I can get the original 24fps with just a single frame that's field repeated at 60fps. Whew! I'll need to review the VS functions to see whether there's coverage of all the gymnastics I'm doing in ffmpeg. I doubt I'll be able to do it as, in the ffmpeg filter chain, I have to do a lot of intermediate 'setpts's and 'fps's to get the whole process to work out without mixing up the frame order.
I've noticed that, with all the processing I do (the gymnastics), the ffmpeg TB winds up being '23.98 tbn' in the stage just prior to interpolating to 60fps. |
26th February 2021, 06:49 | #977 | Link | |||
It suspect it would be easier to do in vapoursynth or avisynth without all the pts gymnastics. Quote:
26th February 2021, 07:12 | #978 | Link | |
Well, I've been using MKV sources just for development. My eventual sources will all be VOBs and M2TSs. BTW, ChaosKing included vsrawsource in his distro (which I jumped on), so I can use it 'out of the box' so to speak. You guys have saved my life. I would have committed 'sewercide' by now if it wasn't for y'all. Last edited by markfilipak; 26th February 2021 at 07:16. |
26th March 2024, 16:21 | #979 | Link | |
Is this bit correct in InterFrame2.avsi?
# Create SuperString Preset == "Fastest" ? Eval(""" SuperString = "{pel:2," """) : Preset == "Fast" || Preset == "Faster" ? Eval(""" SuperString = "{pel:1," """) : Eval(""" SuperString = "{" """) Quote:
By the way to anyone reading this who might be wondering how to get InterFrame working in 64-bit Avisynth+ without requiring SVPManager to be running just use the v4.2.0.142 dlls from the link above. InterFrame is basically just presets for SVPFlow - not that this diminishes its usefulness. Then you can go something like... Code:
InterFrame(GPU=true, tuning="film", preset="medium", Cores=8).Prefetch(8) edit: okay increasing cores & prefetch to 8 makes 1080p possible now but still quite CPU heavy - I thought this was going to be mostly done on the GPU. Oh well it's still very cool, makes 576p25 streaming service Top Gear episodes look more like broadcast version. Last edited by flossy_cake; 26th March 2024 at 16:42. |
26th March 2024, 20:06 | #980 | Link |
"It sounds like 4 is highest quality, 1 is lowest. I'm assuming by "quarter pixel" they mean subpixel precision?"
Yes. Also performance greatly depends on pel value so fastest is pel=1 and slowest is pel=4 (quater size of MV length in the inter-samples virtual distance). |
48fps, 60fps, framedoubling, interframe, smooth motion |
