Old 29th September 2008, 19:34   #1  |  Link
burro08
burro08's Avatar
xvid options
Hi Guys
Im having a problem with xvid, but before i get into it let me say that i have searched and there are no posts that i found that answer what im looking for, so if someone finds one i apologise in advance.. and i own the dvds being discussed....
I have a load of dvds that i want to convert to avi and store on a fat32 hdd for my ps3 and i wont the file size to be around 700mb to get decent quality but not take up to much space.. Plus i cant carry an ex hdd easier than a load o dvds to a friends house for example
I am wondering is the a general settings range for quantization restrictions setting that produce good quality in general from dvd sources? Im not looking for the best just reasonably good..
I have used these settings on a vob that is 1hr 38mins 12 secs long and am using these quant settings 151515 and mpeg as the quant type.. but the outputted file doesn't look gd at all
any suggestions???
Thanks
burro08 is offline   Reply With Quote
Old 29th September 2008, 19:36   #2  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
"700MB", "Xvid", "DVD rip", and "decent quality" don't really belong in the same sentence.
You shouldn't have to mess with max/min QP or any of that; Xvid's ratecontrol handles it fine by default.
Well no wonder, if you limit the quants to 15 no matter what, its going to look terrible.
Old 29th September 2008, 19:45   #3  |  Link
burro08
burro08's Avatar
whats ur advice then?
Old 29th September 2008, 19:49   #4  |  Link
Dark Shikari
x264 developer
I already answered that question, read my post again.
Just use the defaults.
Old 29th September 2008, 19:56   #5  |  Link
burro08
burro08's Avatar
I already answered that question, read my post again.Just use the defaults.
Sorry about that i swear sometimes i cant read
also before converting in vd mod i null transform the boarders should i then resize it?
Old 30th September 2008, 06:26   #6  |  Link
CWR03
Custom User Title
CWR03's Avatar
Just use AutoGK in Quality-based mode.
CWR03 is offline   Reply With Quote
Old 1st October 2008, 19:58   #7  |  Link
matt163201
Dont you hate when x264 fanboys leave their thread just to come and try to convert others over to their side?
Yes we realize that x264 is better looking and better for compression BUT it is not better supported with standalones, k?
matt163201 is offline   Reply With Quote
Old 1st October 2008, 20:34   #8  |  Link
Dark Shikari
x264 developer
And yet you're so much of a "fanboy" that you make the assumption that everyone using Xvid is using it because they have standalones: there couldn't possibly be any other reason.
1. There's much hardware that supports H.264 and not MPEG-4 ASP.
2. If he's encoding for standalones, he would have to deal with the issues of Qpel, GMC, B-frames, etc (which he didn't mention), so I assumed that...
3. He wasn't encoding for standalones (I think).
But I could be wrong.
(Also, despite apparently being an "x264 fanboy," I answered his question about xvid options and you didn't.)
Old 1st October 2008, 22:05   #9  |  Link
burro08
burro08's Avatar
matt63201, I dont believe thats wat Dark Shikari was trying to do plus all his comments so far have been constructive
Old 1st October 2008, 22:19   #10  |  Link
matt163201
I have made plenty of 700MB Xvid rips where the quality was fantastic
Old 1st October 2008, 22:20   #11  |  Link
burro08
burro08's Avatar
Yes but he is right to a degree
Old 1st October 2008, 23:50   #12  |  Link
matt163201
Yes, if you were encoding DaVinci Code for a 700MB Xvid, then thats the degree that he is right in
Old 3rd October 2008, 03:43   #13  |  Link
henryho_hk
"700MB", "Xvid", "DVD rip", and "decent quality" (such a subjective word) may live together, when the resolution is reduced and perhaps some denoising applied. Fairuse and AutoGK tends to reduce the resolution for this purpose. A soft custom matrix such as Javor's 1CD matrix should also be used. Again, test, test ,test & test. There is no perfect setting for every movies.
If the target is PS3 and your computer (encoder) is fast enough. I agree that x264 is also a good try.
henryho_hk is offline   Reply With Quote
avi, settings, virtualdub, xvid
