10th April 2018, 05:50 | #22 | Link | |
Angel of Night
The bigger problem is that with oddball resolutions it'll turn into an infinite loop, and zero bounds checking means you can get memory corruption if you have an overly factorizable resolution -- though even 8k resolutions would probably be safe. |
27th November 2019, 01:29 | #23 | Link | |
interlace this!
no matter how i poke that g++ line, i'm still getting crash with "undefined symbol: fftwf_init_threads". running python 3.6, ubuntu 18.04
sucking the life out of your videos since 2004 |
27th November 2019, 01:53 | #24 | Link |
With this line too?:
g++ -Wall -shared -fPIC -I. $(pkg-config --cflags vapoursynth) $(pkg-config --libs fftw3f_threads) -o libvcfreq.so vcfreq.cpp |
28th November 2019, 03:00 | #25 | Link |
interlace this!
i have fftw3f installed (pkg-config shows ver 3.3.7), but that line fails saying fftw3f_threads is not around. is this a custom package?
[edit] also i wasn't aware of vapoursynth having pkg-config abilities. i've just been copying the files... i'm not a developer, just a tinkerer unfortunately
28th November 2019, 04:25 | #26 | Link |
I don't know much about Ubuntu, but make sure you have libfftw3-dev installed, if that still doesn't work try this line instead:
g++ -Wall -shared -fPIC -I. $(pkg-config --cflags vapoursynth) -lfftw3f_threads -lfftw3f -o libvcfreq.so vcfreq.cpp |
28th November 2019, 10:00 | #27 | Link |
interlace this!
thanks, but so far still no fun:
vsedit: symbol lookup error: /usr/lib/x86_64-linux-gnu/vapoursynth/libvcfreq.so: undefined symbol: fftwf_init_threads Code:
$ ldd libvcfreq.so linux-vdso.so.1 (0x00007ffd582ad000) libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f21a6676000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f21a62d8000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f21a5ee7000) /lib64/ld-linux-x86-64.so.2 (0x00007f21a6c16000) libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f21a5ccf000) it seems like maybe libfftw3f_threads is a separate package that ubuntu doesn't include in it's repos. i've googled a bit but my google game must be off because i haven't found anything relevant [edit] ok i have all the libfftw files with the _threads variants. what's the dealio? should a properly functioning libvcfreq.so show a link to fftw in the ldd results?
sucking the life out of your videos since 2004 Last edited by Mug Funky; 28th November 2019 at 10:34. |
28th November 2019, 15:20 | #28 | Link |
The library is supposed to be installed by libfftw3-dev, but the package seems to be missing the pkg-conf part, thats why I suggested you to not use it.
It should show with ldd: Code:
$ ldd /usr/lib64/vapoursynth/libvcfreq.so linux-vdso.so.1 (0x00007ffe1373e000) libfftw3f_threads.so.3 => /usr/lib64/libfftw3f_threads.so.3 (0x00007fc3564ed000) libfftw3f.so.3 => /usr/lib64/libfftw3f.so.3 (0x00007fc3561e4000) libc.so.6 => /lib64/libc.so.6 (0x00007fc356012000) libm.so.6 => /lib64/libm.so.6 (0x00007fc355ed4000) libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fc355eb1000) /lib64/ld-linux-x86-64.so.2 (0x00007fc356560000) Code:
g++ -Wall -shared -fPIC -I. $(pkg-config --cflags vapoursynth) -L/usr/lib/x86_64-linux-gnu -lfftw3f_threads -lfftw3f -o libvcfreq.so vcfreq.cpp Last edited by Are_; 28th November 2019 at 15:22. |
28th November 2019, 18:21 | #29 | Link |
interlace this!
i'm now wondering whether libpthread isn't the problem, but that's just weird as most apps are multithreaded and i regularly build ffmpeg and darktable from git without them spitting chips at me (and they use all cores).
the only pthreaddy package ubuntu seems to use is libpthread-stubs because apparently linux just sort of supports all the pthread functions as standard in glibc? i hate dependency hell. i'm tempted to just ask for your libvcfreq.so and just see if it runs here...
28th November 2019, 22:42 | #30 | Link |
interlace this!
this line has got ldd showing pthreads, but still no sign of fftw3f_threads:
g++ -shared -fPIC -I. $(pkg-config --cflags gthread-2.0) -I/usr/include -o libvcfreq.so vcfreq.cpp
28th November 2019, 22:58 | #31 | Link |
Here you have, vcfreq compiled with GCC 9.2.0 with "g++ -march=x86-64 -msse2 -O2 -Wall -shared -fPIC -I. $(pkg-config --cflags vapoursynth) $(pkg-config --libs fftw3f_threads) -o libvcfreq.so vcfreq.cpp" command line. Good luck.
29th November 2019, 02:10 | #32 | Link |
interlace this!
sadly this did not work as is.
i'm trying to build fftw3 now to a safe prefix and linking to that, but still it's not cooperating. when i set it to -static the errors are telling - all of them complain about fftw3
29th November 2019, 03:23 | #33 | Link |
I knew it was going to be something silly, try this out because I'm pretty sure it's going to work:
g++ -msse2 -O2 -Wall -shared -fPIC -I. $(pkg-config --cflags vapoursynth) -o libvcfreq.so vcfreq.cpp -lfftw3f_threads -lfftw3f And this vcfreq library should work on your system too. Last edited by Are_; 29th November 2019 at 03:56. |
29th November 2019, 13:00 | #34 | Link |
interlace this!
ok that line worked and the plugin seems to be working too.
did i really just need to link both libfftw3f and libfftw3f_threads to make it work? what a wild ride that was.
12th May 2020, 10:12 | #37 | Link |
I managed to compile vcfreq with
gcc -c -fPIC ${CFLAGS} ${CPPFLAGS} -I. $(pkg-config --cflags vapoursynth) -o main.o vcfreq.cpp g++ -dynamiclib -undefined suppress -flat_namespace *.o -o libvcfreq.dylib and the files linked in post #18. vcfreq loads fine, but crashes VapourSynth immediately when I try to preview anything, no matter if I try to use F1Quiver, Sharp etc. It's similar to the problems described in post #5, but I think that Issue was fixed in the Dropbox files? Where any of you able to successfully run it on OSX or am I missing something here? Any help appreciated! |
12th May 2020, 10:17 | #38 | Link | |
Professional Code Monkey
I certainly never tested the code outside windows.
12th May 2020, 14:16 | #39 | Link |
It works fine on Linux.
I think this is a miss-compilation issue. These are my flags for reference: Code:
gcc -c -fPIC -shared -std=c++11 -O3 -march=native -pipe -Wl,-O1 -Wl,--as-needed -I. -I/usr/include/vapoursynth -o vcfreq.o vcfreq.cpp gcc -shared -fPIC -lfftw3f_threads -lfftw3f -Wl,-O1 -Wl,--as-needed -O3 -march=native -pipe -o libvcfreq.so vcfreq.o |
