Old 25th July 2024, 14:14   #521  |  Link
Kuler087
Kuler087's Avatar
So just for my information, I am currently watching Pirates Of The Caribbean Curse of the Black Pearl, and there is a LOT of different "colour grading" through out, some scenes are quite "natural" looking, and other's are dark and "reddish", is this the grading process that you speak of that takes hours in Resolve ???
yes, movies are graded shot by shot.
DoVi_Scripts
Kuler087 is offline   Reply With Quote
Old 26th July 2024, 01:49   #522  |  Link
TDS
Formally known as .......
TDS's Avatar
So is "shot by shot" the same as "frame by frame" ?
That IS a hell of a lot of frames or shots to be manually graded,
surely Resolve has some way of copying the graded shot/frame, from one adjusted frame to another or group of others ??
I watched a few YT clips on Colour Grading, and most of them are using nodes, to keep track of their changes.
Seems like way too much work for a one off.
Long term RipBot264 user.
RipBot264 modded builds..
*new* x264 & x265 addon packs..
TDS is offline   Reply With Quote
Old 26th July 2024, 03:20   #523  |  Link
Kuler087
Kuler087's Avatar
no
yes, the colorist can spend weeks/months grading big-budget movies.
of course and this is exactly what I do in the SDR to HDR video when I select multiple shots. You can copy the grade of one shot to another by pressing your mouse's wheel over a shot.
Same story for the Dolby Vision trim pass(es). It doesn't work with the mouse wheel but you can map a key to copy trim or level 1 metadata to any shot.
DoVi_Scripts
Old 28th July 2024, 01:04   #524  |  Link
CineManiac
CineManiac's Avatar
Quick question. I see the FEL RPUs you are now uploading with cmv 4.0 added. Is it okay to bake FEL and then copy the L8 levels to the P8 RPU?
CineManiac is offline   Reply With Quote
Old 28th July 2024, 02:18   #525  |  Link
Kuler087
Kuler087's Avatar
yes it's ok
PS:
The latest beta now supports FEL baking/encoding(8-2) without a Nvidia GPU.
DoVi_Scripts
Old 28th July 2024, 04:29   #526  |  Link
CineManiac
CineManiac's Avatar
Nice! Thanks
Old 28th July 2024, 16:17   #527  |  Link
CineManiac
CineManiac's Avatar
Loving the ability to create heatmaps/gamuts with folders of PNGs with 3.0.0! Would it be possible to create a folder within the output folder like with video screenshots?
Old 28th July 2024, 17:11   #528  |  Link
Kuler087
Kuler087's Avatar
yes sure
DoVi_Scripts
Old 29th July 2024, 03:48   #529  |  Link
TDS
TDS's Avatar
Just a quick question...have you ever considered buying an AMD Threadripper ??
Old 29th July 2024, 04:35   #530  |  Link
Kuler087
Kuler087's Avatar
never. I'm an intel/nvidia guy.
DoVi_Scripts
Old 29th July 2024, 06:43   #531  |  Link
TDS
TDS's Avatar
First use of DS 3.0.0 :(
So I thought I'd run a DV conversion with the new 3.0.0.
I chose WF 3-1, and after it doing all it's process, just over an hour later, I get some error msg's, and that was it
Here's some info:-
https://www.mediafire.com/file/9xtl6...rrors.txt/file
https://www.mediafire.com/file/576l1...aInfo.txt/file
I'm running 3-2 on the same movie, as we speak, will comment when completed (or not)
3-2 completed, but the audio is way out of sync...
I must be missing something needed for 3-1 to complete properly.
Old 29th July 2024, 06:46   #532  |  Link
TDS
TDS's Avatar
So Blue & Green team.
I have a majority of AMD's CPU's, but nearly always go for nVidia GPU's.
Old 29th July 2024, 10:22   #533  |  Link
Kuler087
Kuler087's Avatar
Here's some info:-
nothing changed in 3-1 / 3-2...
looks like you added space or special characters in your script path
DoVi_Scripts
Old 29th July 2024, 10:29   #534  |  Link
TDS
TDS's Avatar
Damn it...I keep forgetting about
Thanks, I'll try again tomorrow.
Old 29th July 2024, 12:00   #535  |  Link
DMD
DMD's Avatar
Finished now procedure 3-1 with Script 3.0.0
All OK, I did not detect any audio sync problems.
my PC with Ryzen 7950X
DMD is offline   Reply With Quote
Old 31st July 2024, 15:46   #536  |  Link
Kuler087
Kuler087's Avatar
I did a stupid redirection bug/typo in workflow 1 when the input doesn't have lossless audio (DTS or THD). Get the latest beta or turn off EAC3 encoding in the settings: https://drive.google.com/file/d/128g...usp=drive_link
I did not notice because my own script EAC3 conversion settings is set to OFF. sorry
DoVi_Scripts
Old 31st July 2024, 18:03   #537  |  Link
hgny
Hi
I'm new to the script, amazing job!
I'm trying to do workflow 8-2-4 for converting DV file to SDR. I'm getting some errors and warnings.
I took some pictures, will upload it. Does this is a regular behavior?
https://imgur.com/a/mQbL7X2
hgny is offline   Reply With Quote
Old 31st July 2024, 18:40   #538  |  Link
Kuler087
Kuler087's Avatar
this looks like a Dolby cm_offline.exe error on an AMD GPU and I dont think there's anything I can do about it since it's working fine with an Nvidia gpu.
You might have to contact Dolby or do it in Resolve, it will be faster anyway.
DoVi_Scripts
Old 31st July 2024, 19:30   #539  |  Link
hgny
Yes i tried with resolve. Problem is, my computer doesn't support dolby vision so profile 5 has some pink color and it seems resolve is tone mapping it wrongly.
Old 31st July 2024, 19:36   #540  |  Link
Kuler087
Kuler087's Avatar
Just tonemap P5 to PQ HDR10 with workflow 8-2-3 which is exactly what the script does in 8-2-4
DoVi_Scripts
batch scripts, dolby vision processing, dovi_scripts
