Thread Tools Display Modes
Old 5th June 2014, 20:40   #1  |  Link
mandrake99
Blu-Ray authoring help needed. Main movie repeats.
I need some help with my re-authoring of the French "Conan the Barbarian" BluRay.
I exchanged the movie original english DTS-HD-MA with a remastered DTS-HD-MA track (also english) using TS-MuxerGUI.
On the original BluRay the main movie was split into 7 m2ts files. The remastered BluRay has only one m2ts file for the whole movie.
I also used BdEdit to re-edit the playlist.
Everything works (menu, chapters and specials) and I am quite happy with the disc.
I have one problem though:
When the movie has played to the end the BluRay doesn't jump back to the main menu (as the original BD does) but the movie repeats from the start.
I can go to the main menu manually but I would like to fix this.
There was a similiar problem discussed in this thread.
http://forum.doom9.org/showthread.php?t=144844
I think I have to change the MovieObject.bdmv in BDEdit and add or change a command there.
Here are the MovieObject program lists by BDedit
http://www.ganama.de/art/program_000.lst
http://www.ganama.de/art/program_001.lst
http://www.ganama.de/art/program_002.lst
http://www.ganama.de/art/program_003.lst
http://www.ganama.de/art/program_004.lst
But what and where?
Can anyone here help me?
Many thanks.
mandrake99 is offline   Reply With Quote
Old 5th June 2014, 21:13   #2  |  Link
Video Dude
Senior Member
The screenshot you posted is limited. It only shows the top part with only Move and GoTo commands. If you scroll down, you can see the rest.
A Jump command to a Title would restart and loop the movie.
You will need to trace the registers to determine why it is not calling the Main Menu. It may be a simple solution as replacing the Jump to Title with a menu call.
Video Dude is offline   Reply With Quote
Old 5th June 2014, 21:21   #3  |  Link
mandrake99
DVD burning
@VideoDude
Thanks for the fast response.
In the first post I have included the MovieObject program list files 0-4 which include all the commands.
But I am in way over my head here.
Could you have a look Where I might have to change or add a command?
Many thanks.
bd authoring, bdedit, movie repeats
Thread Tools
