Thread Tools Display Modes
Old 16th February 2025, 09:27   #32141  |  Link
iambryanknowles
For a 1440x800 file with a 4:3 PAR, BD Rebuilder Generates
#Created by BD Rebuilder - v0.62.12
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\DGDecodeNV.dll")
DGSource("D:\BDREBUILDER\WORKFILES\VID_00000.DGI", fieldop=0).AddBorders(0,4,0,6).LanczosResize(1920,1080)
BilinearResize(1440,1080)
ConvertToYV12().AssumeFPS(24000,1001)
I'm working with lossless files and was encoding with Ultrafast from Virtualdub, and hoped that I might save a few GB without the borders - Since a 90GB file requires 270GB during the import process and I have minimal space.
Edit: Apparently the borders help ��*♂️ 1GB smaller with them. Still, I've seen that niche resolution (as well as heights of 804 and 816) in video products such as fanedits before.
iambryanknowles is offline   Reply With Quote
Old 16th February 2025, 15:22   #32142  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Since 800 height is not BD-compliant, but 1080 is, BD-RB will have to pad such source up to 1080 to do justice to its name.
For the cases of reencoding to unconstrained formats I would suggest one of the unconstrained encoder GUIs out there.
clever_ffmpeg_gui, MeGUI64, MeGUI.x64, FFmpeg_Batch_AV_Converter_Portable_x.y.z_x64, Hybrid, StaxRip...
Old 17th February 2025, 00:50   #32143  |  Link
SquallMX
Special SeeD
I found a bug in the latest release 0.62.12, when doing a Full UHD backup, with extras encoded as H264, BD-Rebuilder set subtitle values incorrectly in the mpls files, resulting in missing subtitles when playing on standalone players, BD-Rebuilder is using "12A0, 12A1..." values (reserved for UHD resolution) instead of "1200, 1201..." (for FHD content).
SquallMX is offline   Reply With Quote
Old 17th February 2025, 10:30   #32144  |  Link
MrVideo
MrVideo's Avatar
Originally Posted by Moviewatcher666 View Post
What am I missing? Or is there a bug that does not set the proper flag when rebuilding the file so that the subtitles turn on?
Just press the subtitle button on your player. While that may not be ideal, it should do the trick.
Old 17th February 2025, 10:37   #32145  |  Link
MrVideo
MrVideo's Avatar
The following bugs are still there:
1) Building the 2nd menu can result in it failing when doing the 2nd menu. The first menu files are there, but no hint of the 2nd even being attempted. It took three tries on a current project before it would build the 2nd menu.
2) and because of the above, it means building the disc again. With BDRB ignoring the titles.inf file, it means redoing all of the manual changes to the titles.
Old 17th February 2025, 16:52   #32146  |  Link
Moviewatcher666
Thanks for the suggestion but already tried that.
The subtitle was missing on the blu-ray player.
The problem resides in the reauthoring of the full disc.
Moviewatcher666 is offline   Reply With Quote
Old 18th February 2025, 14:21   #32147  |  Link
MrVideo
MrVideo's Avatar
Your original posting made it read as though the subtitle stream was there but just wasn't turning on. Instead, you are now saying that the subtitle stream was actually missing from the result.
When the original file is imported, BDRB shows which tracks it will keep and which tracks will not be copied. Take a look at that display and report back.
Old 19th February 2025, 13:01   #32148  |  Link
Moviewatcher666
When I play the resulting reauthored disc in the blu-ray player, the subtitle track is not there to select. Therefore, there is no subtitle track to play.
When I look at the M2TS in Media Info on that same disc, the subtitle track shows it is there.
Therefore, in my estimation, a flag that is to make the subtitles available to the blu-ray player is somehow missing.
The logs I uploaded should show exactly what I am discussing. You can see the subtitle track is selected to process with the project. It just is not turned on in the final disc.
Old 19th February 2025, 14:30   #32149  |  Link
MrVideo
MrVideo's Avatar
Aah, gotchya. I'm sorry to say that this is indeed weird. I've not run across this issue. But, I have to say that a majority of the time I do not try to turn on subtitles. I only check them on titles that I create from scratch (home brew) that have subtitles.
Just exactly how are you trying to turn on the subtitles?
Old 19th February 2025, 20:16   #32150  |  Link
Moviewatcher666
Since it is Godzilla 1954, when playing the original disc, the English subtitles are on automatically (I guess for the North American release). You can also turn the subtitles on and off in the main menu.
On the BD Rebuilder processed disc, the subtitles are not on automatically and you cannot control them in the main menu (on or off).
I have all my working files generated by BD Rebuilder. Has anybody got any ideas how to reassemble and get the subtitles to work(a possible workaround)? I am sure it is just a misplaced or incorrect flag that is preventing subtitles to work properly.
Maybe a bug in the program? I'm not sure.
Never had a problem with other discs. Just weird.
Old 19th February 2025, 20:28   #32151  |  Link
MrVideo
MrVideo's Avatar
Based on this statement, you have not tried to turn on the subtitles by pressing the subtitle button on the remote, after starting the movie, as previously suggested?
Please provide the UPC as I might be able to look at it.
Old 20th February 2025, 09:57   #32152  |  Link
lauguru
hello!
What is the process of converting bd to uhd, how does the preset "quality" change to other better quality and less speed?
I get a 30gb bd, 17gb uhd, I have 24000 mb custom target installed
One problem, when I want to convert (Converting to UHD-BD (HEVC) output format), it always uses h264 to encode, having NVENC activated in full backup, How can I enable HEVC in that mode?
other problem in Archive backup/aac , No matter what size you set for custom target, it is always the same output MB size.
[Options]
VERSION=0.62.0.12
ENCODER=1
MODE=4
NEW_CRF_PREDICTION=1
MIN_M2TS_SIZE=0
MIN_PLAYLIST_MINS=0
REENCODE_MENUS=1
ARCHIVE_QUALITY=4
ARCHIVE_265=1
ARCHIVE_ENABLE=1
UHD_CONVERT_ENABLE=1
UHD_V3_MODE=1
ENCODE_QUALITY=4
ONEPASS_ENCODING=2
AUTO_QUALITY=0
NVENC_CAPABLE=1
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=0
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=24000
TARGET_SIZE=24000
[Paths]
WORKING_PATH=L:\TEST BDREBUILDER\
LASTCMD.TXT
BD_Rebuilder\tools\nvenc\nvencc.exe" --avhw  --fps 25 --interlace tff --vpp-deinterlace normal -i "E:\  (BLU-RAY)\BDMV\STREAM\00003.m2ts" --codec hevc --preset quality --qp-min 0 --multipass 2pass-full --vbr 0 --vbr-quality 23 --aq --aq-temporal --sar 1:1 --aud --pic-struct --vbv-bufsize 30000 --max-bitrate 35000 --lookahead 24 --no-b-adapt --gop-len 25 -o "L:\TEST BDREBUILDER\WORKFILES\VID_00003.AVS.hevc"
lauguru is offline   Reply With Quote
Old 21st February 2025, 04:30   #32153  |  Link
Moviewatcher666
Pushed all the buttons on the remote and none of them activated or showed the subtitles.
Thanks for the suggestion.
Old 21st February 2025, 06:32   #32154  |  Link
MrVideo
MrVideo's Avatar
Normally there is a separate button for subtitles.
UPC?
Old 21st February 2025, 16:33   #32155  |  Link
Moviewatcher666
UPC?
Went right into main sub menu and selected subtitles on my LG UP970 since there is no dedicated subtitles button.
Subtitles there but do not display.
Although I appreciate the suggestions, it is clearly not a blu-ray player issue. When I checked the resulting ISO file in PowerDVD, I get the same results. No subtitles displaying.
Been playing with electronics like this for 45 years. Been using BD Rebuilder since it started in 2008.
I am pretty convinced there is a bug specifically on this disc with the re-encodng.
Have you evaluated the logs that I have attached to my original post? Do they reveal anything?
Is there a workaround suggestion to manually activate the subtitles? Is there a way to hardcode the subtitles in the working files before RB Rebuilder reassembles?
Old 21st February 2025, 16:49   #32156  |  Link
MrVideo
MrVideo's Avatar
Attachments not approved, so can't view.
Still waiting for the UPC.
Old 21st February 2025, 17:04   #32157  |  Link
Moviewatcher666
Don't have UPC.
Fixed my post so logs viewable.
Old 21st February 2025, 21:20   #32158  |  Link
Moviewatcher666
Greetings all,
First, I want to commend JDobbs on his commitment to this great program. Well done!
I am playing with a full backup of the new Godzilla Criterion 4K release.
The backup is in ISO format and when I play it in PowerDVD v20, it plays properly with the proper English subtitles. When I play the original disc in my 4K player, it plays fine (of course).
When I process the ISO to fit onto a BD50 in BDRebuilder, everything works except the English subtitles (even when selected in the main menu of the disc).
When I look at the M2TS file, there appears to be the subtitle
Rather frustrating when watching and listening with the Japanese sound track and no English subtitles.
I am attaching my log files to show the work done on the disc.
I appreciate any feedback, assistance or help offered.
Thanks,
Moviewatcher666
[Status]
LABEL=GODZILLA_1954_UHD
VERSION=v0.62.12
SOURCE_SIZE=72166433618
SOURCE_VIDEO_SIZE=71773759488
TARGET_SIZE=49283072000
REDUCTION=.681173707755605
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;jpn;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;jpn;
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=4
DGDECNV=-1
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
UHD_V3_MODE=0
QUICK=1
ENCODE_STEP=0
COMPLETED=3
REBUILD_COMPLETE=1
[00009]
AUDIO=11
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=61948313
NSTART=27000000
NEND=27360360
NSIZE=4141056
FLINK=0
MLINK=0
[00007]
AUDIO=1
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=96417054
NSTART=27000000
NEND=27900900
NSIZE=11464704
FLINK=0
MLINK=0
[00005]
AUDIO=11
PGS=1
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=48874792110
NSTART=27000000
NEND=287720460
NSIZE=38200246272
FLINK=0
MLINK=0
[02/14/25] BD Rebuilder v0.62.12
[09:02:47] Source: GODZILLA_1954_UHD
- Input BD size: 67.21 GB
- Approximate total content: [01:37:41.855]
- Target BD size: 45.90 GB
- Windows Version: 6.2 [9200]
- Quality: High Quality (Default), CQM
- UHD-BD source detected.
- Decoding/Frame serving: NVENCC
[09:02:47] PHASE ONE, Encoding
- [09:02:47] Processing: VID_00009 (1 of 3)
- [09:02:47] Extracting A/V streams [VID_00009]
- [09:02:53] Reencoding video [VID_00009]
- Track 4353 (eng): Keeping original audio
- [09:03:09] Processing: VID_00007 (2 of 3)
- [09:03:09] Extracting A/V streams [VID_00007]
- [09:03:13] Reencoding video [VID_00007]
- Track 4352 (min): Keeping original audio
- [09:03:24] Processing: VID_00005 (3 of 3)
- [09:03:24] Extracting A/V streams [VID_00005]
- [09:09:48] Reencoding video [VID_00005]
- Analyzing 1.00 [1.00]
- Track 4352 (jpn): Keeping original audio
[09:49:05]PHASE ONE complete
[09:49:05]PHASE TWO - Rebuild Started
- [09:49:05] Rebuilding BD file Structure
[09:49:07] - Encode and Rebuild complete
[09:49:07] Writing BD structure to ISO file
- ImgBurn completed successfully
[09:58:06] JOB: GODZILLA_1954_UHD finished.
LASTCMD.txt "C:\Program Files (x86)\BD_Rebuilder\tools\nvenc\nvencc.exe" --avhw --fps 23.976 -i "Q:\BDMV\STREAM\00005.m2ts" --codec hevc --preset default --profile main10 --output-depth 10 --repeat-headers --colorprim bt709 --transfer bt709 --colormatrix bt709 --qp-min 0 --multipass 2pass-full --vbr 0 --vbr-quality 1 --aq --aq-temporal --keyfile "D:\BD REBUILDER WORKING FILES\WORKFILES\VID_00005.CHP" --sar 1:1 --aud --pic-struct --vbv-bufsize 45000 --max-bitrate 48000 --lookahead 24 --no-b-adapt --gop-len 24 -o "D:\BD REBUILDER WORKING FILES\WORKFILES\VID_00005.AVS.hevc"
[Options]
VERSION=0.62.0.12
MIN_M2TS_SIZE=10
;[UHD_IGNORE_HDR=1]
MIN_PLAYLIST_MINS=10
MULTIPROCESS=1
ENABLE_TEST=1
ENCODER=1
MODE=0
ENCODE_QUALITY=2
ONEPASS_ENCODING=1
AUTO_QUALITY=0
TARGET_SIZE=47000
AUTO_BURN=2
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=3
AVCHD=0
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=47000
QUICK_EXTRAS=1
MENU_BACKGROUND=C:\Program Files (x86)\BD_Rebuilder\misc\menuback.jpg
MENU_AUDIO=C:\Program Files (x86)\BD_Rebuilder\tools\blankclip\blank.ac3
IMPORT_THRESHOLD=10
QUICK_PLAY_THRESHOLD=10
MENU_AUTO_BACKGROUND=1
MENU_AUTO_DVDAUDIO=1
MENU_PLAY_SEQUENTIAL=0
MENU_START_WITH_MENU=1
IMPORT_LIMIT_LANG=1
IMPORT_KEEP_PLAYALL=0
IMPORT_PREPARE_MKV=0
ENABLE_BLANKING=1
VERBOSE_STATUS=0
MOVIEONLY_TYPE=0
ALTCRF=23
ALT_TARGET=1024
ALT_CRF_TARGET=1024
ALTMETHOD=0
ALTAUTOCROP=0
PRIORITY_CLASS=0
NVENC_CAPABLE=1
[Paths]
SOURCE_PATH=Q:\
WORKING_PATH=D:\BD REBUILDER WORKING FILES\
DGIndexNV=C:\Program Files\dgdecnv_255\DGIndexNV.exe
DGDecNV=C:\Program Files\dgdecnv_255\DGDecodeNV.dll
DGDecNV=0
SupTitlePath=C:\Program Files (x86)\BD_Rebuilder\Tools\suptitle_v2.0.8_x86\SupTitle.dll
;SupTitlePath=C:\Program Files (x86)\BD_Rebuilder\Tools\suptitle.dll
Well, holy crap! I fixed my subtitle problem with Godzilla 1954 4K Criterion Collection disc.
I got a clue from this post:
https://forum.doom9.org/showthread.p...47#post2014947
So, I decided to compare the MPLS playlist file from the original disc to the MPLS playlist created by BDR.
Under this section:
"number_of_PiP_PG_textST_stream_entries_plus": 0,
there was this entry from the original disc:
"type": 1,
"pid": 4608,
"stream_coding_type": "PGS",
"language_code": "eng",
"reserved01": 0
Under the same section in the BDR created playlist, the entry was this:
"type": 1,
"pid": 4768,
"reserved01": 0
So I inserted the MPLS from the original disc into the disc structure created by BDR and created a new ISO file.
Put it into PowerDVD to play and now the subtitles work exactly like the original disc.
@jdobbs - I don't know if this is a bug but if you need to look at it further, just let me know and I can answer any questions you might have.
Hopefully, this can help somebody else down the line.
Thanks all!
Old 21st February 2025, 22:39   #32159  |  Link
MrVideo
MrVideo's Avatar
Don't have UPC.
How can you not have the UPC if you have the original disc(s) and packaging.
Old 21st February 2025, 22:41   #32160  |  Link
MrVideo
MrVideo's Avatar
I'm surprised that worked. I've sometimes swapped something out and the disc refused to play. You got lucky.
Looking at the info about this release, it has an English soundtrack, so why the worry about subtitles?
Thread Tools
