Old 19th August 2025, 10:49   #1  |  Link
buddha9
buddha9's Avatar
How to decode E-AC3 7.1 to 8 wav files (with correct channel name files)
Hi all,
I've a e-ac3 7.1 file.
What is the best/safe way to decode a E-AC3 7.1 file to 8 wavs files?
I have:
  • eac3to v3.47
  • Nero Burning Rom 7.11.10.0c (LICENSED)
  • Nero ShowTime w 3.10.1.0 (LICENSED)
Nero Audio Decoder (Nero 6 or older) doesn't seem to be installed
http://www.nero.com/eng/store-blu-ray.html
CAUTION: You need Nero 7. Nero 8 won't work with eac3to.
ArcSoft DTS Decoder (1.1.0.9) works fine
Sonic Audio Decoder (3.47.0.0) doesn't seem to be installed
Haali Matroska Muxer doesn't seem to be installed
http://haali.net/mkv
Nero AAC Encoder could not be located
http://www.nero.com/eng/nero-aac-codec.html
Copy NeroAacEnc.exe to the eac3to or to the Windows folder.
Surcode DTS Encoder doesn't seem to be installed
http://www.surcode.com
Here https://en.wikibooks.org/wiki/Eac3to/FAQ I read need to register the plugin: ... you can install Nero ShowTime only and of course to register the plug-in. How can I do ?
How can I have 8 wav files from the E-AC3 7.1 ? Need also each file have the correct name of the channel. I need this for video editing later...
Thanks!
PS
Or is better via ffmpeg?
ffmpeg -i '.\input.eac3' `
-filter_complex "channelsplit=channel_layout=7.1[FL][FR][FC][LFE][LS][RS][LB][RB]" `
-map "[FL]" -c:a pcm_s24le "output_audio_L.wav" `
-map "[FR]" -c:a pcm_s24le "output_audio_R.wav" `
-map "[FC]" -c:a pcm_s24le "output_audio_C.wav" `
-map "[LFE]" -c:a pcm_s24le "output_audio_LFE.wav" `
-map "[LS]" -c:a pcm_s24le "output_audio_LSR.wav" `
-map "[RS]" -c:a pcm_s24le "output_audio_RSR.wav" `
-map "[LB]" -c:a pcm_s24le "output_audio_LSS.wav" `
-map "[RB]" -c:a pcm_s24le "output_audio_RSS.wav"
AviSynth+ 3.7.3
buddha9 is offline   Reply With Quote
Old 19th August 2025, 11:17   #2  |  Link
j7n
j7n's Avatar
ffmpeg now works. I don't think there is need to use paid software for decoding anymore. Quality-wise the official decoder in Adobe Audition allows to boost extremely low signal without artifacts, while ffmpeg will impart a buzz. The level of very high frequencies seems slightly attenuated in Audition.
Beware that some decoders might swap the surround and rear-surround channel pairs. Here is a clip identifying each channel: http://j7n.sytes.net/misc/71ch_id.ec3
j7n is offline   Reply With Quote
Old 19th August 2025, 11:32   #3  |  Link
buddha9
buddha9's Avatar
Thanks for quick reply.
I've Adobe Audition 24.0.3.3. It doesn't like the e-ac3 files.
What version I have to use?
AviSynth+ 3.7.3
Old 19th August 2025, 13:06   #4  |  Link
buddha9
buddha9's Avatar
Anyway, I compared 2 e-ac3 files:
- your "http://j7n.sytes.net/misc/71ch_id.ec3"
- the one you can find here https://drive.google.com/drive/folde...roiDOS2vEX7N4b --> "Dolby Digital Plus E-AC-3 7.1.mp4" (demuxed on Dolby Digital Plus E-AC-3 7.1.track_2_und.ec3)
Comparing:
  • audio from your file 71ch_id.ec3:
MEDIAINFO:
Audio
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Commercial name                          : Dolby Digital Plus
Format settings                          : Dolby Surround EX
Duration                                 : 16 s 0 ms
Bit rate mode                            : Constant
Bit rate                                 : 448 kb/s
Channel(s)                               : 8 channels
Channel layout                           : L R C LFE Ls Rs Lb Rb
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Stream size                              : 875 KiB (100%)
Service kind                             : Complete Main
Dialog Normalization                     : -19 dB
compr                                    : -0.28 dB
dialnorm_Average                         : -19 dB
dialnorm_Minimum                         : -19 dB
dialnorm_Maximum                         : -19 dB
PS C:\Users\***\Downloads\e-ac3 channels order\71ch_id_ec3> ffmpeg -hide_banner -i '.\71ch_id.ec3'
[eac3 @ 000001e0da61b540] Estimating duration from bitrate, this may be inaccurate
Input #0, eac3, from '.\71ch_id.ec3':
  Duration: 00:00:16.00, start: 0.000000, bitrate: 448 kb/s
  Stream #0:0: Audio: eac3, 48000 Hz, 7.1, fltp, 448 kb/s
  • audio (helping with video) from "Dolby Digital Plus E-AC-3 7.1.track_2_und.ec3:"
MEDIAINFO:
Audio
Format                                   : E-AC-3
Duration                                 : 1 min 29 s
Bit rate                                 : 384 kb/s
Stream size                              : 4.08 MiB (100%)
Dialog Normalization                     : -16 dB
compr                                    : 0.53 dB
mixlevel                                 : 105 dB
dialnorm_Average                         : -16 dB
dialnorm_Minimum                         : -16 dB
dialnorm_Maximum                         : -16 dB
PS C:\Users\***\Downloads\e-ac3 channels order\e-ac3 from Drive> ffmpeg -hide_banner -i '.\Dolby Digital Plus E-AC-3 7.1.track_2_und.ec3'
[eac3 @ 000001dd97ddd440] Estimating duration from bitrate, this may be inaccurate
Input #0, eac3, from '.\Dolby Digital Plus E-AC-3 7.1.track_2_und.ec3':
  Duration: 00:01:29.12, start: 0.000000, bitrate: 384 kb/s
  Stream #0:0: Audio: eac3, 48000 Hz, 7.1, fltp, 384 kb/s
You can note there are 2 inverted channels. Why ?
Here https://professionalsupport.dolby.co...g000006XdWSAA0 Dolby says "Dolby uses SMPTE channel order (L R C LFE Lss Rss Lrs Rrs, etc). "
Thanks!
AviSynth+ 3.7.3
Old 19th August 2025, 14:08   #5  |  Link
j7n
j7n's Avatar
This sample is from an official disc "Dolby Labs - Functional Testing". EX supposedly contains an extra back channel within the core 5.1 stream, but I have no means of listening to it. With the extension it decodes to full 7 channels + LFE. It confirms the channel IDs as they are. Not saying that you have them wrong, but that it may happen.
Internally the order is the same as Vorbis: Left, Center, Right, Side Left, Side Right, Rear Left, Rear Right, LFE. Tools should automatically convert it to the SMTPE order.
Old 19th August 2025, 15:34   #6  |  Link
buddha9
buddha9's Avatar
Do you have another E-AC3 7.1 file without this ? :
You can verify via MediaInfo.
AviSynth+ 3.7.3
Old 19th August 2025, 22:41   #7  |  Link
tebasuna51
tebasuna51's Avatar
No mather the internally channel order when it is decoded the channels follow the wav order FL,FR,FC,LFE,LB,RB,LS,RS (Back/Rear channels before Side/Surrround channels) for that the order in the image.
I make this channel test
Old 20th August 2025, 10:00   #8  |  Link
buddha9
buddha9's Avatar
Thanks for support e patience
So
1) imported your file on Audacity
2) exported on 8 discrete wav files
3) imported them on DME (v3.7):
4) split the rendered file via ffmpeg:
ffmpeg -hide_banner -i '.\output.eb3' `
-filter_complex "channelsplit=channel_layout=7.1[FL][FR][FC][LFE][LB][RB][LS][RS]" `
-map "[FL]" -c:a pcm_s24le "output_2_audio_L.wav" `
-map "[FR]" -c:a pcm_s24le "output_2_audio_R.wav" `
-map "[FC]" -c:a pcm_s24le "output_2_audio_C.wav" `
-map "[LFE]" -c:a pcm_s24le "output_2_audio_LFE.wav" `
-map "[LB]" -c:a pcm_s24le "output_2_audio_LS-Back.wav" `
-map "[RB]" -c:a pcm_s24le "output_2_audio_RS-Back.wav" `
-map "[LS]" -c:a pcm_s24le "output_2_audio_LS-Side.wav" `
-map "[RS]" -c:a pcm_s24le "output_2_audio_RS-Side.wav"
4) imported them on Audacity to check the channels order:
** Note: if you import the .eb3 file Audacity show you only 6 channels **
Conclusion:
to "demux" a "e-ac3 7.1" file in the correct way you need to use the ffmpeg above. Right?
AviSynth+ 3.7.3
Old 21st August 2025, 07:58   #9  |  Link
tebasuna51
tebasuna51's Avatar
Yes, it is.
Old 12th January 2026, 13:28   #10  |  Link
buddha9
buddha9's Avatar
if you have a mkv (for example) which contains:
- 0:0 --> h.264/h.264 ...
- 0:1 --> e-ac3 7.1
then this command avoid to extract e-ac3 stream:
ffmpeg -hide_banner -i '.\input.mkv' `
>> -filter_complex "[0:1]channelsplit=channel_layout=7.1[FL][FR][FC][LFE][LB][RB][LS][RS]" `
>> -map "[LB]" -c:a pcm_s24le "output_audio_LS-Back.wav" `
>> -map "[RB]" -c:a pcm_s24le "output_audio_RS-Back.wav" `
>> -map "[LS]" -c:a pcm_s24le "output_audio_LS-Side.wav" `
>> -map "[RS]" -c:a pcm_s24le "output_audio_RS-Side.wav"
AviSynth+ 3.7.3
decoding, e-ac3
