Old 19th March 2023, 17:13   #41  |  Link
Balling
That is very interesting. How can cancel DRC?
cd to DRP folder and run using ./ (absolute path will not work):
./gst-inspect-1.0.exe --gst-plugin-path gst-plugins dlbac3dec
Compare to EAC3 interface in DRP, the app: drc-cut, drc-boost and drc-mode are the same as there. Set to true drc-suppress.
It also has drop-delay: Drop delay samples added by the decoder at the stream start
Nice.
in ./gst-inspect-1.0.exe --gst-plugin-path gst-plugins dlbtruehddec
it is already disabled, but you can enable it here.
Obviously you can just do it though global dlbaudiodecbin, ac3dec-drop-delay, ac3dec-drc-suppress
I checked, options work
Balling is offline   Reply With Quote
Old 19th March 2023, 20:34   #42  |  Link
Balling
Full command "C:\Program Files\Dolby\Dolby Reference Player\gst-launch-1.0.exe" --gst-plugin-path "C:\Program Files\Dolby\Dolby Reference Player/gst-plugins" filesrc location=C:\\tmp\\atmos\\gapless.eac3 ! dlbac3parse ! dlbaudiodecbin ac3dec-drop-delay=true ac3dec-drc-suppress=true out-ch-config=13 ! audio/x-raw,format=S32LE ! wavenc ! filesink location=Z:\zE.L111.wav
Old 22nd March 2023, 23:46   #43  |  Link
tebasuna51
tebasuna51's Avatar
Ok, and for thd files with drc-suppress by default:
"C:\Program Files\Dolby\Dolby Reference Player\gst-launch-1.0.exe" --gst-plugin-path "C:\Program Files\Dolby\Dolby Reference Player/gst-plugins" filesrc location=C:\\tmp\\atmos\\zT.thd ! dlbtruehdparse align-major-sync=false ! dlbaudiodecbin truehddec-presentation=16 out-ch-config=13 ! audio/x-raw,format=S32LE ! wavenc ! filesink location=C:\\tmp\\atmos\\zT.wav
Y try format=S24LE and report a error like not supported, no problem with the output 32 int.
It is much more fast decode the 8 channels at same time, the problem is the wav filesize >4 GB (only can fit a time of 46:36:12).
Audition (and other soft) can't load that files with standard (and wrong) header, need a w64 or rf64 header. We can use:
eac3to zT.wav zT.w64
With automatic downsample to 24 int, enough for a eac3 encode.
Attached .bat and log
Old 23rd March 2023, 17:15   #44  |  Link
Balling
drc-suppress should be only for EAC3/AC3/AC4, THD has drc off by default. Yes, only int 24 inside int 32 is supported.
Old 17th August 2023, 07:30   #45  |  Link
Eviluess
Hi, have you noticed that the generated result has around 7dB lower volume than the audio converted by ffmpeg -i input.mp4 output.wav?
Nice.
Eviluess is offline   Reply With Quote
Old 17th August 2023, 09:17   #46  |  Link
tebasuna51
tebasuna51's Avatar
Yep, 7dB or other, seems the drc-suppress is ignored by the decoder and the drc is applied always over eac3 Atmos.
I'm using now the eac3to 'normalize' after decode:
set TEM=C:\\tmp\\atmos\\
set DECODER=C:\Program Files\Dolby\Dolby Reference Player
set EAC3TO=C:\Portable\eac3to\eac3to.exe
"%DECODER%\gst-launch-1.0.exe" --gst-plugin-path "%DECODER%/gst-plugins" filesrc location=%TEM%zE.eac3 ! dlbac3parse ! dlbaudiodecbin ac3dec-drop-delay=true ac3dec-drc-suppress=true out-ch-config=13 ! audio/x-raw,format=S32LE ! wavenc ! filesink location=%TEM%zE.wav
rem zE.wav to zE.w64 normalize and 32f to 24int (Audition can't read wav >4GB)
"%EAC3TO%" zE.wav zE.w64 -normalize
Old 19th August 2023, 11:08   #47  |  Link
Eviluess
Thank you for confirming this.
And as far as I know, any post-processing such as re-normalizing will compromise the "lossless" property. E-AC-3 is lossy, while TrueHD is lossless, so I hope TrueHD can do the job properly on respecting to the original.
Additionally, I found the TrueHD options allow us to use DRC modes, and only the value 4 can make the result louder than others. However, this make the end result LOUDER than the original, which introduces lossy in details.
Do you know how to make TrueHD without altering the original loudness?
Any suggestions would be greatly appreciated!
Thanks in advance!
Old 19th August 2023, 11:52   #48  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by Eviluess View Post
And as far as I know, any post-processing such as re-normalizing will compromise the "lossless" property. E-AC-3 is lossy...
You are right, the re-normalize is not the correct way, but is the best I found until we know a way to cancel the DRC applied by the decoder.
... while TrueHD is lossless, so I hope TrueHD can do the job properly on respecting to the original.
The decoder default is not aply the DRC, then I also hope the decode is 'more or less' lossless.
BTW the atmos decode to a specific speaker configuration implies some lossy operations and we can't know how the original sound was recorded.
Old 19th August 2023, 14:48   #49  |  Link
Eviluess
You make a good point. Let me provide some more details on my testing:
I used DaVinci Resolve to generate a test Atmos WAV file, playing simple sounds at each speaker channel like FL, FC, FR and so on. Then I used the Dolby Encoder Suite to generate TrueHD files from this.
When I compared the TrueHD output to the original WAV, I noticed the volume was lowered by about 7dB across all the speaker channels. This indicates a noticeable loss of fidelity to me, beyond what I'd consider "lossless." Boosting the volume with re-amping would also boost any lost details.
However, if having overhead channels is more important than absolute sound quality, this may be the "best" solution available right now, as you said.
In the end, it's a trade-off between full Atmos speaker support and lossless audio quality. I appreciate you helping me think through this - your insights are really valuable as I explore my options.
conclusions here!
Old 20th August 2023, 02:39   #50  |  Link
Balling
TrueHD is not lossless, neither the Dolby Media encoder, nor the Dolby Reference player (hacked using the github script). FFmpeg decoder is lossless (and lossless with FFMpeg encoder), but FFmpeg encoder is slightly nonconformant at least with stereo.
Old 20th August 2023, 03:26   #51  |  Link
Eviluess
Since decoding the TrueHD to standard 7.1 surround PCM wave files doesn't introduce the perceived 7dB volume drop like the Dolby Reference Player does, I'm inclined to believe the Dolby Media Encoder didn't actually suppress the volume during encoding. Even if this process is lossy in some way, the end result seems acceptable to me.
It's still concerning that setting DRC to Off had no effect on fixing this issue. I would have expected that to bring the playback volume up to the proper level.
I tried using the ffmpeg command with the mlp/truehd encoder, and it lists max support up to 5.1 channels. This makes me think I may need to compile a custom version of ffmpeg with Dolby Atmos encoding enabled in order to get true lossless TrueHD output.
ffmpeg -h encoder=mlp
Old 23rd August 2023, 07:49   #52  |  Link
Eviluess
BTW, do you know how to decode AC-4 to 16 channels with this tool?
Old 23rd August 2023, 13:18   #53  |  Link
tebasuna51
tebasuna51's Avatar
Sorry, I don't know how.
Old 23rd August 2023, 15:21   #54  |  Link
Eviluess
That's fine.
I don't know either.
And I tried combination of possible nodes but all failed.
Old 26th August 2023, 03:06   #55  |  Link
Balling
Why mlp?? ffmpeg -h encoder=truehd and ffmpeg -h decoder=truehd and decoder does support 7.1
"custom version of ffmpeg with Dolby Atmos encoding enabled" there is no Atmos support in THD or EAC3. No ac4 whatsover for now.
Old 3rd September 2023, 03:46   #56  |  Link
Eviluess
Thanks replying.
I just mentioned but I don't use ffmpeg to encode TrueHD or E-AC3. I use the Dolby Encoder Suite instead.
Old 13th October 2023, 17:03   #57  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
How can i create a w64 file with GStreamer Plugin? If i use simply the *.w64 extension, the output file is corrupt:
General
Format : Wave
Format settings : WaveFormatExtensible
File size : 8.93 GiB
Duration : 1 h 43 min
Overall bit rate mode : Constant
Overall bit rate : 12.3 Mb/s
FileExtension_Invalid : act at9 wav
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : 00000001-0000-0010-8000-00AA00389B71
Bit rate mode : Constant
Bit rate : 12.3 Mb/s
Channel(s) : 16 channels
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 8.93 GiB (100%)
if i convert this wav with FFMPEG to W64:
General
Format : Wave64
File size : 948 MiB
Duration : 10 min 47 s
Audio
Format : PCM
Channel layout : L R C Lb Rb Cb Ls Rs Tfl Tfc Tfr Tbl Tbc Tbr
Bit depth : 16 bits
Stream size : 948 MiB (100%)
i have only 10 Minutes, lol. I can't play the WAV with any MediaPlayer, if i load the WAV into Audacity, it shows only 10 Minutes, too.
EDIT:
Solution is SOX. Simply convert wav with SOX to w64.
-QfG- is offline   Reply With Quote
Old 15th October 2023, 02:52   #58  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by -QfG- View Post
if i convert this wav with FFMPEG to W64:...
Try with:
ffmpeg -ignore_length true -i your.wav output.w64
Without that parameter the output is truncated to the length in the wav header never greater than 4 GB (a field with only 16 bits)
Old 16th October 2023, 18:26   #59  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
This works great, thanks, but now i have a "new" Problem^^
If i will demux the Multichannel WAV into MONO WAVs, FFMPEG aborted by 10 Channel (5.1.4) and 12 Channel (7.1.4) files. No error Messages or somethings. 16 Channels (9.1.6) and 8 Channels (5.1.2) works fine.
"!FFMPEGpath!" -y -threads auto -vsync drop -i "!AVSFILE!.avs" -strict experimental -loglevel error -stats -filter_complex "[0:a]channelmap=0[FL];[0:a]channelmap=1[FR];[0:a]channelmap=2[FC];[0:a]channelmap=3[LFE];[0:a]channelmap=4[SL];[0:a]channelmap=5[SR];[0:a]channelmap=6[BL];[0:a]channelmap=7[BR];[0:a]channelmap=8[WL];[0:a]channelmap=9[WR];[0:a]channelmap=10[TFL];[0:a]channelmap=11[TFR];[0:a]channelmap=12[TSL];[0:a]channelmap=13[TSR];[0:a]channelmap=14[TBL];[0:a]channelmap=15[TBR]" -map "[FL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.L.wav" -map "[FR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.R.wav" -map "[FC]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.C.wav" -map "[LFE]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.LFE.wav" -map "[SL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.SL.wav" -map "[SR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.SR.wav" -map "[BL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.BL.wav" -map "[BR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.BR.wav" -map "[WL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.WL.wav" -map "[WR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.WR.wav" -map "[TFL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_FL.wav" -map "[TFR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_FR.wav" -map "[TSL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_SL.wav" -map "[TSR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_SR.wav" -map "[TBL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_BL.wav" -map "[TBR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_BR.wav"
"!FFMPEGpath!" -y -threads auto -vsync drop -i "!AVSFILE!.avs" -strict experimental -loglevel error -stats -filter_complex "[0:a]channelmap=0[FL];[0:a]channelmap=1[FR];[0:a]channelmap=2[FC];[0:a]channelmap=3[LFE];[0:a]channelmap=4[SL];[0:a]channelmap=5[SR];[0:a]channelmap=6[BL];[0:a]channelmap=7[BR];[0:a]channelmap=8[TFL];[0:a]channelmap=9[TFR];[0:a]channelmap=10[TBL];[0:a]channelmap=11[TBR]" -map "[FL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.L.wav" -map "[FR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.R.wav" -map "[FC]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.C.wav" -map "[LFE]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.LFE.wav" -map "[SL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.SL.wav" -map "[SR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.SR.wav" -map "[BL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.BL.wav" -map "[BR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.BR.wav" -map "[TFL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_FL.wav" -map "[TFR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_FR.wav" -map "[TBL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_BL.wav" -map "[TBR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_BR.wav"
"!FFMPEGpath!" -y -threads auto -vsync drop -i "%~1" -strict experimental -loglevel error -stats -filter_complex "[0:a]channelmap=0[FL];[0:a]channelmap=1[FR];[0:a]channelmap=2[FC];[0:a]channelmap=3[LFE];[0:a]channelmap=4[SL];[0:a]channelmap=5[SR];[0:a]channelmap=6[TFL];[0:a]channelmap=7[TFR];[0:a]channelmap=8[TBL];[0:a]channelmap=9[TBR]" -map "[FL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.L.wav" -map "[FR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.R.wav" -map "[FC]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.C.wav" -map "[LFE]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.LFE.wav" -map "[SL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.SL.wav" -map "[SR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.SR.wav" -map "[TFL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_FL.wav" -map "[TFR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_FR.wav" -map "[TBL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_BL.wav" -map "[TBR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_BR.wav"
"!FFMPEGpath!" -y -threads auto -vsync drop -i "!AVSFILE!.avs" -strict experimental -loglevel error -stats -filter_complex "[0:a]channelmap=0[FL];[0:a]channelmap=1[FR];[0:a]channelmap=2[FC];[0:a]channelmap=3[LFE];[0:a]channelmap=4[SL];[0:a]channelmap=5[SR];[0:a]channelmap=6[TSL];[0:a]channelmap=7[TSR]" -map "[FL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.L.wav" -map "[FR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.R.wav" -map "[FC]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.C.wav" -map "[LFE]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.LFE.wav" -map "[SL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.SL.wav" -map "[SR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.SR.wav" -map "[TSL]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_SL.wav" -map "[TSR]" -c:a pcm_s%WAVBR%le "!OUTPUTFILE!.T_SR.wav"
SOLVED:
Demuxing works if the W64 files have the correct Channel Layout includet:
if "!C_LAYOUT!"=="9.1.6 [FL][FR][FC][LFE][SL][SR][BL][BR][WL][WR][TFL][TFR][TSL][TSR][TBL][TBR]" set "PAN= -filter_complex "pan^=7.1^+WL^+WR^+TFL^+TFR^+TSL^+TSR^+TBL^+TBR^|FL=c0^|FR=c1^|FC=c2^|LFE=c3^|SL=c4^|SR=c5^|BL=c6^|BR=c7^|WL=c8^|WR=c9^|TFL=c10^|TFR=c11^|TSL=c12^|TSR=c13^|TBL=c14^|TBR=c15^[a^]^" -map ^"^[a^]^""
if "!C_LAYOUT!"=="7.1.4 [FL][FR][FC][LFE][SL][SR][BL][BR][TFL][TFR][TBL][TBR]" set "PAN= -filter_complex "pan^=7.1^+TFL^+TFR^+TBL^+TBR^|FL=c0^|FR=c1^|FC=c2^|LFE=c3^|SL=c4^|SR=c5^|BL=c6^|BR=c7^|TFL=c8^|TFR=c9^|TBL=c10^|TBR=c11^[a^]^" -map ^"^[a^]^""
if "!C_LAYOUT!"=="5.1.4 [FL][FR][FC][LFE][SL][SR][TFL][TFR][TBL][TBR]" set "PAN= -filter_complex "pan^=5.1^(side^)^+TFL^+TFR^+TBL^+TBR^|FL=c0^|FR=c1^|FC=c2^|LFE=c3^|SL=c4^|SR=c5^|TFL=c6^|TFR=c7^|TBL=c8^|TBR=c9^[a^]^" -map ^"^[a^]^""
if "!C_LAYOUT!"=="5.1.2 [FL][FR][FC][LFE][SL][SR][TSL][TSR]" set "PAN= -filter_complex "pan^=5.1^(side^)^+TSL^+TSR^|FL=c0^|FR=c1^|FC=c2^|LFE=c3^|SL=c4^|SR=c5^|TSL=c6^|TSR=c7^[a^]^" -map ^"^[a^]^""
Old 18th October 2023, 20:44   #60  |  Link
-QfG-
QfG Group Germany
-QfG-'s Avatar
Another problem. It looks so, that the Avisynth Timestretch Plugin don't work with Atmos w64 files. Timestretch settings will be ignored :/
# Load Avisynth Filters
AddAutoloadDir("C:\_RIPPING\FS_Audio_Converter\tools\AviSynth\plugins")
# Source Plugin request: lsmashsource.dll
LoadPlugin("C:\_RIPPING\FS_Audio_Converter\tools\LSMASHSource.dll")
# [Source: LWLibavAudioSource - Stream Index -1]
LWLibavAudioSource("D:\TEST_EAC3ATMOS_3min_[9.1.6].w64", drc_scale=0.0, cache=false, stream_index=-1)
# [DSP: TimeStretch - [Slowdown] 25.00 to 23.976]
ConvertAudioToFloat()
TimeStretch(pitch=95.904)
