Old 20th October 2015, 14:39   #21  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by JimmyBarnes View Post
How do you arrive at this scheme?
1) Select 6 output channels
2) Click over conexión 6 -> 6 (to delete)
3) Click over input 6 and output 5 (mix BC-SL to SL)
4) Click over input 7 and output 6 (SL -> SL)
5) Click over input 5 and output 6 (mix BC-SR to SR)
Old 20th October 2015, 14:41   #22  |  Link
JimmyBarnes
the Interrogator
JimmyBarnes's Avatar
Originally Posted by Ghitulescu View Post
Or you can get only the core (5.1) - this can be directly translated into DD 5.1, no channel remapping.
As indicated before, I tried:
eac3to SW3.dtsma SW3.dts -core
but it gave:
DTS Master Audio, 6.1 channels, 24 bits, 48kHz
(core: DTS-ES, 6.1 channels, 1509kbps, 48kHz)
and Audacity confirmed that the DTS was 6.1, not 5.1
JimmyBarnes is offline   Reply With Quote
Old 20th October 2015, 15:54   #23  |  Link
Ghitulescu
Ghitulescu's Avatar
I am not expert in eac3to and curious channel mappings, I assume you should use remapping function of eac3to if the direct extraction does not work. As I said, I keep the original.
Born in the USB (not USA)
Old 20th October 2015, 21:57   #24  |  Link
tebasuna51
tebasuna51's Avatar
but it gave:
Can you upload a sample of this dtsma?, for instance with:
eac3to SW3.dtsma Sample.dts -20mb
Old 21st October 2015, 00:52   #25  |  Link
JimmyBarnes
the Interrogator
Thanks but what I meant was, How do you determine what channels to mix?
What are the rules governing downmixing which make your scheme correct and mine wrong?
TIA
Old 21st October 2015, 04:32   #26  |  Link
JimmyBarnes
the Interrogator
I created sample DTSMA, uploaded to MediaFire:
https://www.mediafire.com/?jtis55sjhxssu3g
Old 21st October 2015, 09:34   #27  |  Link
Ghitulescu
Ghitulescu's Avatar
For the simple reason that there is a rule on how to distribute the sounds amongst channels. If one combines them back (downmixes) then he had to combine the corresponding sounds, not to pick up arbitrary channels, for other reasons.
Old 21st October 2015, 10:47   #28  |  Link
tebasuna51
tebasuna51's Avatar
Here you have all DTSMA channel layouts: http://forum.doom9.org/showthread.ph...33#post1714833
And here a channel test sample for all the layouts: https://www.sendspace.com/file/pd2o0f
Your sample is the I: 6.1-L,R,C,LFE,Ls,Rs,Cs discrete (I61_disc.dtshd file)
When a proper decoder (ArcSoft, dcadec, ffmpeg) convert this dtshd to PCM samples the channels order must be the same than in WAV specs:
Track 1: Front Left (L in dts)
Track 2: Front Right (R in dts)
Track 3: Front Center (C in dts)
Track 4: Low Frequency (LFE in dts)
Track 5: Back Center (Cs in dts)
Track 6: Side Left (Ls in dts)
Track 7: Side Right (Rs in dts)
Like the channel layout for PCM 5.1 is:
Track 1: Front Left (FL)
Track 2: Front Right (FR)
Track 3: Front Center (FC)
Track 4: Low Frequency (LF)
Track 5: Side Left (SL)
Track 6: Side Right (SR)
The 4 first tracks are the same but the last 2 must be:
Track 5: SL + 0.707*BC
Track 6: SR + 0.707*BC
The BC channel contribution is added to Side channels with half acustic power (-3dB in volume) in each.
With your scheme you have:
Track 4: LF + BC
than have no sense.
I can't reproduce your problem (AC3 with more length than DTSHD) with this sample. Sorry I can't help with that.
Old 21st October 2015, 13:15   #29  |  Link
JimmyBarnes
the Interrogator
Thanks, this tells me what I want to know.
cheers
Old 21st October 2015, 15:36   #30  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Well...
I've just dragged and dropped the (dts-hd ma+dts-es) sample file into UsEac3to v1.1.7 (with eac3to v3.29) and it managed to create a 640Kbps 5.1Ch AC3 stream without any issues at all
Old 21st October 2015, 15:51   #31  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
I thought his original log shows that it downmixed to 5.1 without errors.
Just some minor normalization (-0.9dB). or something.
I think it's mostly an Audacity issue after using eac3to.
Audacity can use external libraries for FFMPEG, but won't update internally (because it's too much work for them).
I tried to contact them several times about updating their FFMPEG to current stable releases (if not Zeranoe releases).
Trying to keep the 6.1 discreet is kind of useless.
The previous solutions are best: downmix to 5.1 or upmix to 7.1 (double-back from center-back).
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Old 21st October 2015, 20:54   #32  |  Link
JimmyBarnes
the Interrogator
Originally Posted by SeeMoreDigital View Post
Well...
Length of the DTSMA and AC3 are the same for the sample?
eac3to 3.29 (command-line) did the full conversion, but the AC3 was 14.3 % longer than the DTSMA.
Old 21st October 2015, 21:23   #33  |  Link
tebasuna51
tebasuna51's Avatar
Yes, your dts sample is 40.459 sec. and ac3 40.480 sec. (1265 frames, with 1264 frames is only 40.448).
Do you have the same problem with this sample?
Old 21st October 2015, 23:58   #34  |  Link
JimmyBarnes
the Interrogator
Yes, using eac3to CL, the resultant AC3 is 46.272 s, 14.37 % longer than the source DTSMA.
So, what is it that UsEac3to v1.1.7 does, it's supposed to be just a GUI for eac3to, isn't it?
Old 22nd October 2015, 09:30   #35  |  Link
tebasuna51
tebasuna51's Avatar
I use also UsEac3to but like you say is only a GUI than create a command line like your:
eac3to v3.29
command line: C:\BDrip\EAC3to\eac3to SW3.dtsma SW3_640norm.AC3 -640 -normalize
I tested all variants using -normalize/-down6/-dcadec ... and always work fine.
Maybe is your ArcSoft version, try using -dcadec.
With ArcSoft 1.1.0.0 work fine also.
Old 23rd October 2015, 02:58   #36  |  Link
JimmyBarnes
the Interrogator
Maybe is your ArcSoft version, try using -dcadec. With ArcSoft 1.1.0.0 work fine also.
Worked OK using libDcaDec.
I tried implementing ArcSoft 1.1.0.1 downloaded here:
http://www.dvbsupport.net/download/i...ct=view&id=277
It says: "Just put dtsdecoderdll.dll and the related .CRT folder (otherwise it will not run if the related Visual C++ Redistributable package is not installed on the system) into base folder of the programs."
I did that, however eac3to couldn't get it to work and used libDcaDec instead => AC3 of correct length
Was using tehparadox unspecified ArcSoft DTS decoder version before (which eac3to used but gave bad 6.1> 5.1 AC3), will try this one:
https://www.sendspace.com/file/ief0t0 => ArcSoft DTS decoder 1.1.0.0
YES finally, a good conversion to AC3, so looks like bad ArcSoft DTS decoder was the problem..
Old 23rd October 2015, 10:22   #37  |  Link
tebasuna51
tebasuna51's Avatar
Actually ArcSoft is only necesary to decode DTS-Express, in all my test libDcaDec decode bitidentical outputs than wav sources (ArcSoft 1.1.0.0 seems have, in few cases, a rounding error and the output differ than sources in the last significant bit).
Old 24th October 2015, 04:46   #38  |  Link
JimmyBarnes
the Interrogator
That's interesting, I always thought ArcSoft was supposed to be the best tho I have not done any testing.
Old 9th October 2025, 18:27   #39  |  Link
tormento
Acid fr0g
tormento's Avatar
Your downmix is wrong, you mix the Back Center channel to LFE channel.
Sorry to resurrect a very old thread but what is the correct way to upmix 6.1 to 7.1 with ffmpeg?
@turment on Telegram
Old 10th October 2025, 10:28   #40  |  Link
tebasuna51
tebasuna51's Avatar
If your 6.1 is a dts matrixed (BC analog mixed in SL-SR) the recommended way is let it as 5.1
If your 6.1 is discrete (independent BC channel) the recommended way is downmix to 5.1 to obtain the same 2D surround, with less bitrate needed, using:
ffmpeg -hide_banner -i INPUT_61 -vn -filter_complex^
 "asplit [f][s]; [f] pan=3.1|c0=c0|c1=c1|c2=c2|c3=c3 [r]; [s] pan=stereo|c0=0.35*c4+0.5*c5|c1=0.35*c4+0.5*c6, compand=attacks=0:decays=0:points=-90/-84|-8/-2|-6/-1|-0/-0.1, aformat=channel_layouts=stereo [d]; [r][d] amerge [a]"^
 -map "[a]" OUTPUT_51
Where OUTPUT_51 can be AAC, OPUS or EAC3
If you need 2D surround 7.1 (I don't know for what) you can use:
ffmpeg -hide_banner -i INPUT_61 -vn -af pan=7.1|c0=c0|c1=c1|c2=c2|c3=c3|c4=0.707*c4|c5=0.707*c4|c6=c5|c7=c6 OUTPUT_71.wav
And recode your 7.1 2D
