Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 31st December 2024, 12:31   #261  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for ffhevc 4.5.17
* Don't error out during runtime if a HDR10 value is not set/available
* Updated the built-in script preset
Old 2nd January 2025, 10:56   #262  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.5.18
* Fixed a bug in the cropping code for batch encoding
ChangeLog for ffx264 4.2.13
Old 2nd February 2025, 14:12   #263  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.5.19
* Turn on HME for the built-in script preset
* Increased default noise value from 4 to 5
* Updated the README file
Old 4th June 2025, 12:59   #264  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.0
* Delete side data when doing tone mapping to SDR
* Updated the AUTHORS, README and man page files
ChangeLog for ffx264 4.3.0
* Fix wrong default option for tonemap algo
* Delete side data when doing HDR -> SDR conversion
* Updated the README and man page file
Old 28th June 2025, 09:45   #265  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.1
* Lower B-frames from 8 to 6 in the script preset
* Disable tskip in the script preset
* Add negative Chroma QP offsets for HDR content
Old 8th September 2025, 15:11   #266  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.2
* Fix: chroma qp offsets for HDR10 weren't added when running in batch mode
* Small fine-tune to the script preset
Old 31st October 2025, 09:36   #267  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.3
* Set qp-adaptation-range to 2.0 for the script preset
* Enable asymmetric partitions for the script preset
* Lower rskip2 threshold to 1 for the script preset
Old 1st November 2025, 08:01   #268  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.4
* Reworked the internal script preset
* Lowered the Cb/Cr qp offsets to -2 for HDR encodings
* Increased the Cb/Cr qp offsets to 1 for SDR encodings
Old 9th November 2025, 12:36   #269  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.5
* Set max-cll to 0,0 in case no values were detected
* Warn user that HDR10 will be disabled in case of unavailable master-display values
Old 12th November 2025, 23:19   #270  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffx264 4.3.1
* Support setting a default zimg scaler in the config file
ChangeLog for ffhevc 4.6.6
* Lower subme from 7 to 5 in the script preset and increase aq-strength to 1.1
Old 13th November 2025, 20:04   #271  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.7
* Lower qg-size to 16 for HDR encodings
* Enable hdr10-opt by default for HDR encodings
* Set default in-script FFmpeg scaler to natural bicubic spline and the default zimg scaler to spline36
* Minor improvements to the scaling code
* Updated the README and man page files
Old 14th November 2025, 09:16   #272  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffx264 4.3.2
ChangeLog for ffhevc 4.6.8
* Fixed a bug in the options parsing that resulted in max-cll and dhdr10 not being added for HDR encodings
* Minor code restructuring in the HDR code
Old 15th November 2025, 07:40   #273  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.9
* For SDR encodings, use blue/red chroma qp offsets of -2
* For HDR encodings, lower blue/red chroma qp offsets to -4
* Some minor optimizations in the HDR code
* Fix comparison for cb/crqpoffs for SDR encodings
Old 16th November 2025, 16:44   #274  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.10
* Increase QP adaptation range for the built-in script preset to 1.3
* Reworked a bit the HDR code
Old 21st November 2025, 21:46   #275  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.11
* Fine-tune the built-in script preset
* Lower default CRF value from 23 to 22
* Add option to change already set CRF value when encoding in HDR
Old 25th November 2025, 09:48   #276  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.12
* Add support for Spline64 zimg zscale filter. Requires latest FFmpeg from git
Old 12th December 2025, 08:48   #277  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.13
* Fix: only ask to lower the CRF value when doing HDR encodings
Old 13th December 2025, 13:36   #278  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.14
* Detect type of content (HDR/SDR) and base default CRF value on it
Old 20th December 2025, 16:21   #279  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.6.15
* Bugfix in the zscale scale filter for Lanczos3/4
Old 20th December 2025, 17:21   #280  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffx264 4.3.3
