#661 | Link | |
tebasuna51, hello
Today I downloaded Hawaii Five-0 - Brian Tyler 2023 OST in flac files. Only a few out of 41 flac files could not be converted to ac3. I am using UsEac3to v.1.3.5, eac3to v.3.57. I am using Windows 10 22H2 (19045.2728) education. I am attaching a picture so you can see the error. "I DonТt Ride Shotgun.flac" not found. <ERROR>" Specifically this file (flac) is not recognized, and most of the 41 files are successfully recognized by UsEac3to v.1.3.5. I am also attaching only one of the several (5) problematic flac files for you to test and/or determine why there is a problem. If you need it - I will also upload a flac file that was successfully recognized by UsEac3to v.1.3.5 and I converted it to AC3 without any problems. ![]() 39 I Don’t Ride Shotgun.flac Quote:
Addendum: Oh my god. I figured out why this problem was occurring. The problem was due to the apostrophe in the name: "Don’t". Can’t this be corrected somehow in the software so that it recognizes correctly?! Last edited by seagate; 30th December 2025 at 20:20. |
#663 | Link |
![]() Join Date: Feb 2005
The apostrophe (') character ascii code 39 is legal without problem, but in your name "39 I DonÆt Ride Shotgun.flac" there are the ascii char 149 show in my codepage like other than ('), in your image is showed like T.
Edit the name and replace that character with the (') in your keyboard (ascii code 39). |
#664 | Link |
Life's clearer in 4K UHD
There is a world of difference between don’t and don't...
#665 | Link | |
And remember rule:
#666 | Link | |
In the help you have the answer, use .rf64 like extension. In my next new GUI version 1.3.6 I offer that output and other new parameters. |
#669 | Link |
Thank you @tebasuna51
I’m changing the FPS of AAC audio files. When decoding AAC, eac3to uses the Nero Audio Decoder. Would it make more sense to use FFmpeg instead of Nero, or is it sufficient to rely only on eac3to? Currently, I decode AAC with FFmpeg using pcm_s32le and -rf64 always, then I change the FPS of the resulting RF64 audio file and finally convert it to AC-3 or E-AC3 using Dolby Encode Engine (DEE). I’m using this workflow for AC-3 as well, since I don’t want to use libaften for AC-3 encoding and therefore prefer encoding AC-3 via DEE. Last edited by sadpunk; 3rd January 2026 at 09:53. |
#670 | Link |
eac3to decode aac with the old Nero7 decoder if it is installed.
I use always ffmpeg, also like ac3/eac3 encoder, then eac3to is not used at all. If you want use DEE like encoder can do the first part with UsEac3to (select the fps change in the atempo parameter) like I show in the image: |
#672 | Link |
The audio data is the same, but the w64 header (also the rf64 format) have fields to support filesize greater than 4 GB (multichannel audio movie tracks needs that sizes).
It is safe convert w64 to wav if < 4 GB. Some software can support also wavs > 4 GB with fake header but it is not recommended. |
| Display Modes | |
