Old 28th December 2015, 10:44   #2441  |  Link
Vyral
Vyral's Avatar
My only problem with the new internal audio renderer is that it doesn't work with madVR (I think it's a problem of synchronization between audio and video).
However, I have no problem with my laptop that use EVR-CP (internal audio renderer stereo - exclusive mode).
iiyama prolite xb2483hsu 1080p60 Gamma=2.25 - Intel Core i3-2100 3.10GHz - AMD Radeon HD 6850, RGB 4:4:4 Full range - MPC-HC + XYSubFilter + madVR
Vyral is offline   Reply With Quote
Old 28th December 2015, 12:43   #2442  |  Link
chros
chros's Avatar
Also, if you ever worked in professional development, you should know that the "ideal" situation never actually happens.
Often you are driven by deadlines or financial demands which in the end will cause you to weigh the enhancements against the known flaws. A "perfect" software product just doesn't exist anywhere.
It's so true
It works for me. What's your problem exactly?
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 28th December 2015, 15:04   #2443  |  Link
Vyral
Vyral's Avatar
I activate the new internal audio renderer by choosing "8: Internal Audio Renderer" in the dropdown in Playback > Output > Audio Renderer, is it correct ? Because this is where the problem start.
Then in Internal Filters > Audio Renderer, in Device, I have System Default, I checked Exclusive mode and unchecked Allow bitstreaming.
Audio Switcher isn't enabled.
Video and Audio are ok during playback and when seeking during playback. However, when I pause, the audio enters a loop. Resuming playback or exiting MPC-HC doesn't break the loop, but playing another file stops the previous audio playback to start the new one (with the same problems).
I've only tested with exclusive mode, I should test it again without.
EDIT : Just tested without exclusive mode and it works. Maybe something is missing in my madVR settings to allow audio playback in exclusive mode.
Old 31st December 2015, 14:27   #2444  |  Link
DMD
DMD's Avatar
Hello and greetings to all the year-end and good start to 2016.
Sorry for the trivial question, I created a lossless MKV files from my copy of Blu-ray 3D Avatar, this is the mediainfo video section.
As you can see from the profile format, you select the 3D files with MakeMKV.
Video
Format: AVC
Format / Info: Advanced Video Codec
profile format: Stereo High@L4.1 / High@L4.1
MultiView_Count: 2
Shape settings, CABAC: Yes
Size Settings, reframes: 3 frame
Shape settings, GOP: M = 3, N = 24
Codec ID: V_MPEG4 / ISO / AVC
Duration: 2h 41min
Bit rate: 31.8 Mbps
Width: 1,920 pixels
Height: 1,080 pixels
Display aspect ratio: 16: 9
Frame rate mode: Constant
Frame rate: 23.976 (24000/1001) fps
Color space: YUV
Chroma sub-sampling: 4: 2: 0
Bit Depth: 8 bits
Scan type: Progressive
Bits / (Pixel * Frame): 0.639
The track size: 35.9 GiB (99%)
English language
Default: No
Forced: No
What I do not understand is that playing with MPCHC, plays it the same way as a 2D files with no difference.
Even with a normal monitor display should not get a "busted"?
Thank you
DMD is offline   Reply With Quote
Old 31st December 2015, 15:00   #2445  |  Link
sneaker_ger
In a 3D BluRay you have two streams: normal AVC for one eye and an MVC addition for the second eye. I assume MPC-HC can only play the AVC stream, at least out-of-the-box. That's why it appears to be a 2D file.
If you want 3D either:
1. re-encode these files to a single side-by-side/top-bottom stream to make it work in 2D players using e.g. BD3D2MK3D or
2. use Stereoscopic Player
Old 31st December 2015, 15:21   #2446  |  Link
DMD
DMD's Avatar
Here you should always have a file containing both video streams, so that you can view it in both 2D and 3D?
Thank you
Old 31st December 2015, 19:26   #2447  |  Link
LigH
LigH's Avatar
MPC-HC usually decodes using LAV FIlters, and they will probably omit the MVC difference, only decoding the AVC base.
New German Gleitz board
Old 1st January 2016, 02:51   #2448  |  Link
tahaa7
What is the difference between selecting "2: Speakers <device name>" and "8: Internal Audio Renderer" in Options, under Playback -> Output? Specifically, are both of those renderers capable of WASAPI Exclusive (bit-perfect) output?
tahaa7 is offline   Reply With Quote
Old 1st January 2016, 03:16   #2449  |  Link
only the internal audio filter can do WASAPI
Old 2nd January 2016, 00:09   #2450  |  Link
Blackfyre
Hi Devs; and everyone;
I wanted to make a request regarding a feature that I hope to see added in a future version. I don't often make requests around here, but sometimes they turn out to be handy
So I was watching a show on my PC (connected to my TV) and a scene popped up in the show that I didn't want my nephew to see (under the age of 15). Video was in 1920x800, so I have the subtitles set up in the bottom black bar. Instead of exiting full-screen exclusive mode (running through Madvr) --> minimizing --> muting --> then going back when the scene was over... and then SVP has to reinitialize itself... I was hoping a shorcut key (user-customized) could be added to heavily blur or darken (overlay) a certain section of the screen as well as mute the player.
So for example for me, the blur-zone (blur strength can be customized) would be the majority of the screen except the area where the subtitles show up (sometimes it's important to read what is being said during such moments). Be it scenes too violent or scenes too sexual for minor audiences.
I think this is a great idea Thanks for a great program, you don't have to do this, but it would be greatly appreciated if you did (boy it would be embarrassing if the feature is already there and I've just typed all of this for nothing).
Blackfyre is offline   Reply With Quote
Old 2nd January 2016, 01:03   #2451  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
Well, you can blur with shaders, shaders don't affect subtitles and you can switch shaders with shortcut keys, so...
Simple 3x3 blur shader (based on sharpen shader): http://pastebin.com/ACqLgtLX (save as Blur.hlsl and put into Shaders dir).
Open Shaders in mpc-hc, save empty preset. Then add lots of new Blur shader (since 3x3 blur is not strong enough) and save it as another shader preset.
Now set "Next Shader Preset" shortcut in Keys and you're done.
vivan is offline   Reply With Quote
Old 2nd January 2016, 09:24   #2452  |  Link
Blackfyre
That's a great idea. Thanks I already set it up. But it's extremely heavy on performance. Running SVP with my custom settings, as well as Madvr with custom higher quality settings and applying 20x blur and darkening results in a massive drop in frames.
Still thank you and I'll be using this method until such feature is added (whenever that may be). Maybe I could edit the code for blur.hlsl to make it stronger.
Old 2nd January 2016, 09:28   #2453  |  Link
madshi
You can use the blur method from LumaSharpen which should be quite a bit faster.
Old 2nd January 2016, 17:03   #2454  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
Here's 2-pass blur shader with much larger radius (16), it should be much faster at the same strength.
BlurX http://pastebin.com/pcbjTm8v
BlurY http://pastebin.com/vgh11XM2
Old 2nd January 2016, 19:16   #2455  |  Link
rodrigo081089
Today i was trying to watch a movie, but when i opened the mpc it says the direct access wasnt there. So i installed it again and i had the same problem.
Now i can see in the malwarebytes the mpc is in quarantine and it says ransom.filelocker.
Anyone else have this problem?
Thanks
rodrigo081089 is offline   Reply With Quote
Old 2nd January 2016, 19:50   #2456  |  Link
kuchikirukia
Looks like Malwarebytes just-released definitions (1-02-2016) are flagging MPC-HC as ransomware. Considering 1.7.10 has been released since November and nobody has had a problem with it encrypting all their files, I'm going to hazard the guess that it's just a false positive.
It flags mine which I got right off the MPC-HC site a couple months ago, so it's not even a problem with any codec pack site (CCCP or K-lite) going rogue. It's flagging the legit MPC-HC as malware.
Just take it out of quarantine and whitelist it for now.
Why are you even running Malwarebytes' real-time checker?
kuchikirukia is offline   Reply With Quote
Old 2nd January 2016, 19:51   #2457  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Thanks
It's a false positive and it's already fixed by MBAM team. Just update to their latest db. More info here.
MPC-HC Links: official nightlies | Trac | GitHub | git log | IRC | Twitter | Facebook
vBm is offline   Reply With Quote
Old 2nd January 2016, 19:57   #2458  |  Link
rodrigo081089
Thanks to both
Old 3rd January 2016, 16:40   #2459  |  Link
Blackfyre
Thanks a lot for this, it helped a lot.
If there's a way to make the subtitles not get affected by the blur/darken/grayscale effect that I've added, that would be great.
Aka subtitles not affected by shaders and are rendered on top of the shaders (not under them).
Old 6th January 2016, 00:38   #2460  |  Link
raymondjpg
Using latest versions of madVR 89.19 and Emby for WMC (Windows 7 Professional). With MPC-HC 1.7.10 after refresh rate switching by madVR (windowed overlay mode) then video hangs and does not play. Video will play after closing then re-starting MPC.
Refresh rate switching when using MPC-HC 1.7.9 works with video playing fine after refresh rate switching.
Has anyone else seen this, better still have a solution for it? I have also posted this in the madVR forum, but I suspect it is more of an issue with the latest version of MPC-HC than madVR
raymondjpg is offline   Reply With Quote
dxva, media player classic, mpc, mpc-hc
