Old 27th July 2014, 14:10   #1061  |  Link
Reino
Reino's Avatar
BassAudio.dll (v2.4 2008) was compiled with Visual C++ Express 2005.
I make a new compile with Visual C++ Express 2010, with a more recent version of AviSynth.h and the last Bass.h (with Bass.dll 2.4.9).
Hi tebasuna, could you release the source codes for this compile, so someone else can have a look to make it work with BASS 2.4.10?
My hobby website
Reino is offline   Reply With Quote
Old 28th July 2014, 09:45   #1062  |  Link
tebasuna51
tebasuna51's Avatar
Of course, here is:
Old 6th November 2014, 21:20   #1063  |  Link
siella
siella's Avatar
all extensions pack
I added new exts., fix some and togethered all.
Behappy
BePack.v3.3BeHappy,BeSweet,BeLight,BeSplit,BeSliced,BdAC) with last plugin, encoder and extensions.
Avisynth Movie Screenshot, thumbnails creator
siella is offline   Reply With Quote
Old 6th November 2014, 23:58   #1064  |  Link
LigH
LigH's Avatar
By the way, a user of the german doom9/Gleitz board recently made a multithreaded fork of BeHappy (one file conversion per thread in a batch). No decision yet if he may also try to enhance the extension interface (e.g. with sliders or comboboxes)...
New German Gleitz board
Old 9th November 2014, 00:38   #1065  |  Link
siella
siella's Avatar
Thanks for this great news. It will be very good if he made. I liked options of drag'n and drop and paralel jobs
Behappy
Old 9th November 2014, 21:35   #1066  |  Link
jones1913
random user
Thanks for mention it, LigH.
Here is the download link: http://www.mediafire.com/folder/qc84j3132cvnp/BeHappy
Sourcecode is included in download archive.
2014-11-09 (jones1913) v0.2.6.34898
+ multiple files/folders can be opened at once
2014-10-19 (jones1913) v0.2.6.18337
+ added parallel job processing
+ some gui modernization/tweaks
jones1913 is offline   Reply With Quote
Old 9th November 2014, 23:06   #1067  |  Link
forclip
Of course, here is:
Not a fix:
Comment out the BASS_Free() call and then ignore BASS_ERROR_ALREADY on BASS_Init(). Not sure what else will be broken after that..
The real fix:
Move everything related to bass (un)initialization from DllMain to other place, as it seems like bass 2.4.9+ doesn't like to be Init'ed or Free'd from that point, it hangs. BASS_Init(0,48000,0,0,0) - works, yes, but BASS_Init(1,48000,0,0,0) - hangs. And nothing hangs after moving it to bassAudioSource(), including BASS_Free().
forclip is offline   Reply With Quote
Old 10th November 2014, 03:03   #1068  |  Link
tebasuna51
tebasuna51's Avatar
@jones1913
Thanks for your job.
Like you can see noboby is active developing this tool in CodePlex, if you are interested I can add you to the BeHappy team like Developer (I need your Codeplex username)
Old 10th November 2014, 03:15   #1069  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by forclip View Post
The real fix:
Sorry, I don't understand the fix needed.
Can you supply a functional new source code?
Old 10th November 2014, 19:44   #1070  |  Link
forclip
Something like this, at least it works for me with bass.dll 2.4.10: http://ge.tt/7t9vkD42/v/0 (src + bassAudio.dll)
Also, this way bassAudio unloads noticeably faster than the original one.
Old 10th November 2014, 21:32   #1071  |  Link
jones1913
random user
Yeah Im not yet registered at codeplex, but I will do it.
I have no experience in code revision control systems. Which system is used by BeHappy project on codeplex? SVN, Git?
Old 12th November 2014, 08:18   #1072  |  Link
tebasuna51
tebasuna51's Avatar
The Project was created by Dimzon using Team Foundation Server / Subversion and I use TortoiseSVN to manage it.
Now recommend Git, but I don't know if can be converted.
Old 12th November 2014, 11:03   #1073  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Sure it does...for example, using this.
Old 12th November 2014, 14:33   #1074  |  Link
tebasuna51
tebasuna51's Avatar
@Kurtnoise
You are Coordinator like me in BeHappy project, the other Cordinator (and creator) Dimzon have 'Last Activity: 5th November 2009' in Doom9.
If you think than is more convenient convert the project to Git you are free to do.
Old 12th November 2014, 16:02   #1075  |  Link
Kurtnoise
Kurtnoise's Avatar
I dont see any benefit for the moment to switch to Git for this project...So, stay with SVN and that should be fine.
Old 12th November 2014, 21:13   #1076  |  Link
jones1913
random user
Git seems to be well suited for projects with many contributing people or teams.
This is obviously not the case for BeHappy. So SVN is good enough .
@tebasuna
Codeplex username is 'jones1913'. When you add me i will check in my changes.
Old 12th November 2014, 23:28   #1077  |  Link
tebasuna51
tebasuna51's Avatar
@jones1913
You are now BeHappy Developer.
Old 13th November 2014, 00:05   #1078  |  Link
tebasuna51
tebasuna51's Avatar
I forget say thank you. Work also for me.
Old 13th November 2014, 02:03   #1079  |  Link
Reino
Reino's Avatar
Doesn't work for me:
Evaluate: System exception - Illegal Instruction
or,
bassAudioSource: Unable to load or init bass.dll!
for numerous audioformats.
That's on my WinXP pc. Tomorrow I'll test on a Win7 laptop.
My hobby website
Old 13th November 2014, 04:24   #1080  |  Link
forclip
No problem
WinXP
Please try this one http://ge.tt/8ngKhP42/v/0 (v110_xp, v110_xp SSE)
behappy
