Old 21st May 2006, 22:10   #261  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
fresh beta out!
some eye-candy
dimzon is offline   Reply With Quote
Old 21st May 2006, 22:47   #262  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Hmm very nice Thanks dimzon, new package
shon3i is offline   Reply With Quote
Old 21st May 2006, 22:52   #263  |  Link
dimzon
dimzon's Avatar
shon3i
If You prefer mp4 over m4a you need
  1. open BeHappy.exe.config via notepad
  2. change key="preferMP4overM4A" value="false" to key="preferMP4overM4A" value="true"
You can also use your favorite DirestShow player for preview instead of mplayer2. Just edit key="directShowPlayer" value="mplayer2"
Old 22nd May 2006, 08:59   #264  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
OK, thanks you.
Old 22nd May 2006, 10:38   #265  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Is there chance to integrate FAAD or some different AAC/MP4 decoder.
Old 22nd May 2006, 11:22   #266  |  Link
dimzon
dimzon's Avatar
Later (much more later)
Old 22nd May 2006, 17:32   #267  |  Link
dimzon
dimzon's Avatar
Originally Posted by buzzqw
sorry to bother but i have some problem with enc_AudX_CLI.exe
C:\Programmi\PureBasic\Prove>BePipe.exe  --script "import(^test.avs^)" | enc_AudX_CLI.exe - qqq.mp3
--q 2
 Aud-X multichannel encoder CLI frontend
 this algorithm has been prepared by: [Aud-X Team www.aud-x.com]
 BePipe by dimzon
Script used:
# BEGIN
import("test.avs")
# END
Scanning for Audio Stream...
Found Audio Stream
Channels=6, BitsPerSample=32, SampleRate=48000Hz
Writing Header...
Writing Data...
0%      System.NotSupportedException: Il flusso non supporta la ricerca. ---> "stream doesn't support seek" i can translate
   in System.IO.__Error.SeekNotSupported()
   in System.IO.__ConsoleStream.get_Position()
   in enc_AudX_CLI.WaveFormat.ReadWavHeader(BinaryReader reader)
   in enc_AudX_CLI.Main(String[] args)
Done!
this is my test.avs
loadplugin("C:\Programmi\PureBasic\Prove\exe\filter\nicaudio.dll")
nicac3source("C:\Programmi\PureBasic\Prove\aaa.ac3")
the same script is fine wth oggenc/lame/neroaacenc.exe
any suggestion ?
thanks
BHH
Edit: typos
fixed (maybe) - check new enc_AudX_CLI.exe version
Old 22nd May 2006, 19:08   #268  |  Link
tebasuna51
tebasuna51's Avatar
To encode a wav 5.1 to ogg I need a explicit GetChannels(1,3,2,5,6,4) to obtain a correct mapped ogg.
Isn't added automatically?
Old 22nd May 2006, 19:24   #269  |  Link
buzzqw
HDConvertToX author
downloaded latest version 22/05/2006 of AudX_cli package
avs script
LoadPlugin("NicAudio.dll")
NicAC3Source("C:\Programmi\PureBasic\Prove\aaa.ac3")
EnsureVBRMP3Sync()
ConvertAudioTo16bit() # since aud-x want 16bit sample
batch
BePipe.exe --script "import(^mkvmaudio.avs^)" | enc_AudX_CLI.exe - aaa.mp3 --raw 48000 --q 2
isn't working... mean the job end without warning but audio is corrupted.
i tryed without --raw 48000 and without EnsureVbrMp3Sync, and without convertaudioto16bit
any help ?
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 22nd May 2006, 20:14   #270  |  Link
dimzon
dimzon's Avatar
http://forum.doom9.org/showthread.ph...430#post827430
EnsureVBRMP3Sync()
batch
valid command-line is
BePipe.exe --script "import(^mkvmaudio.avs^)" | enc_AudX_CLI.exe - aaa.mp3 --q 2
what does "corrupted" means?
Can you save audio to WAV using
BePipe.exe --script "import(^mkvmaudio.avs^)" > test.wav
and listen it - maybe something wrong BEFORE encoder
Old 22nd May 2006, 21:28   #271  |  Link
buzzqw
HDConvertToX author
tryed without --raw 48000 (as already posted) and audio get wrong
Sample test is 12 second and aud-x got 14 seconds with rumors and distorted audio play.
bepiping for wav file is correctly played
i packed my files (bat/avs/ac3/audx/bepipe) (800kb) please try yourself
www.64k.it/andres/test_bepipe_audx.rar
thanks !
BHH
EDIT: seems to be the normalize fuction...
Old 23rd May 2006, 00:28   #272  |  Link
dimzon
dimzon's Avatar
fresh beta is out.
including UpMix extension
Old 23rd May 2006, 01:17   #273  |  Link
tebasuna51
tebasuna51's Avatar
From http://forum.doom9.org/showthread.ph...430#post827430
don't forget that latest oggenc2 build support 5.1 channel in correct order
Originally Posted by Dimzon
Oh Shit...
Please, provide me download link for fresh valid oggenc2
Oggenc2.83 using aoTuVb4.51 2006-04-26 in rarewares and oggenc2 in shon3i package still need the GetChannel.
Where is the latest oggenc2 build?
Old 23rd May 2006, 01:45   #274  |  Link
tebasuna51
tebasuna51's Avatar
With your example (with or without Normalize) i get:
ERROR: Can't find audio stream!
System.Exception: Invalid file format
   at enc_AudX_CLI.WaveFormat.ReadWavHeader(BinaryReader reader)
   at enc_AudX_CLI.Main(String[] args)
Old 23rd May 2006, 07:12   #275  |  Link
buzzqw
HDConvertToX author
@tebasuna51
look at nicaudio plugin and correct it to your avisynth path
about ogg: i usually got it at rarewares
quoting from rarewares
oggenc2 A short explanation.
oggenc2.x: is a command line Ogg Vorbis encoder based upon the official oggenc.....Version 2.8 introduces correct channel mapping for encoding of multi-channel (3 to 6 channels) files that conform to the WAVEFORMATEXTENSIBLE standard. The multi-channel mapping conforms to the Vorbis I Specification.
seems that oggenc2.x has correct channel map so i don't know if getchannel has to be passed or not
BHH
Old 23rd May 2006, 07:57   #276  |  Link
tebasuna51
tebasuna51's Avatar
Of course. And two pass encoding:
BePipe.exe --script "import(^mkvmaudio.avs^)" > aaa.wav
enc_AudX_CLI.exe aaa.wav aaa.mp3 --q 3
the mono mp3 equivalent seems work ok (I haven't 5.1 audio attached to pc)
quoting from rarewares:
"Version 2.8 introduces correct channel mapping for encoding of multi-channel (3 to 6 channels) files that conform to the WAVEFORMATEXTENSIBLE standard."
But Bepipe/BeHappy never use WAVEFORMATEXTENSIBLE header.
Edit: BeHappy sends audio to oggenc2 in RAW format.
Oggenc2.83 using aoTuVb4.51 2006-04-26 from rarewares need the getchannel.
Old 23rd May 2006, 08:31   #277  |  Link
dimzon
dimzon's Avatar
Both MeGUI and BeHappy will be fixed soon
Sorry....
Old 23rd May 2006, 08:56   #278  |  Link
dimzon
dimzon's Avatar
fixed
Old 23rd May 2006, 13:01   #279  |  Link
dimzon
dimzon's Avatar
fresh beta is out
fixed improper Lame MP3 ABR command-line
Old 23rd May 2006, 16:39   #280  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Fresh package
behappy
