#18421 | Link | |
The re-compressed menu backdrop solved the stutter due to excessive bitrate for BD5/9, and the CERTIFICATE folder is back in place. ![]()
#18422 | Link |
![]() Join Date: Oct 2001
Great!
jdobbs.softworks@gmail.com |
#18423 | Link |
vbv maxrate/buffer (TWEAK_ALTERNATE)
Last night BD Rebuilder created two MKV's from the Bd's Trance & After Earth. Set TWEAK_ALTERNATE=--vbv-maxrate 35000 --vbv-bufsize 30000 and it works great.
I just watched the Trance movie and it had a very good picture quality. Nice work Mr. Jdobbs, a donation is coming you're way. LASTCMD (After Earth): "C:\BD_Rebuilder\tools\x264.exe" "D:\BD-RB WORK\WORKFILES\VID_00001.AVS" --preset slow --bluray-compat --ref 4 --b-adapt 1 --b-pyramid none --weightp 1 --qpmin=0 --bitrate 10189 --level 4.1 --qpfile "D:\BD-RB WORK\WORKFILES\VID_00001.CHP" --aud --nal-hrd vbr --pic-struct --vbv-bufsize 15000 --keyint 48 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 15000 --threads auto --slices 4 --thread-input --vbv-maxrate 35000 --vbv-bufsize 30000 --stats "D:\BD-RB WORK\WORKFILES\VID_00001.AVS.264.stats" --pass 2 --output "D:\BD-RB WORK\WORKFILES\VID_00001.AVS.264" MediaInfo (Trance): Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=1 / keyint=48 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=48 / rc=2pass / mbtree=1 / bitrate=10367 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=35000 / vbv_bufsize=30000 / nal_hrd=vbr / filler=0 / ip_ratio=1.10 / aq=1:1.00 |
#18424 | Link |
Good news. That makes me 3 for 3!
My next project is full 3D backup support...
#18425 | Link |
Hi jdobbs
I have problems if I want to import an mkv file wich have subtitles in (vob)Sub format or srt text format. BD-Rebuilder wont Import that subtitles. Only subtitles in pgs format works. would be nice if it was fixable so that the created pseudo BD shows that subtitles too. many thx and kind regards |
#18426 | Link |
I have a problem with the newest beta version,
This is the playlist DISC INFO: Disc Title: Mary.Poppins.1964.COMPLETE.BLURAY-PCH Disc Size: 45.608.432.147 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.8 PLAYLIST REPORT: Name: 00800.MPLS Length: 2:19:06.338 (h:m:s.ms) Size: 0 bytes Total Bitrate: 0,00 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 0 kbps 1080p / 23,976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD High-Res Audio English 2046 kbps 5.1 / 48 kHz / 2046 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio Portuguese 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio French 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio Italian 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio Dutch 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 0,000 kbps Presentation Graphics Portuguese 0,000 kbps Presentation Graphics French 0,000 kbps Presentation Graphics Italian 0,000 kbps Presentation Graphics Dutch 0,000 kbps Presentation Graphics English 0,000 kbps Presentation Graphics Portuguese 0,000 kbps Presentation Graphics French 0,000 kbps Presentation Graphics Italian 0,000 kbps Presentation Graphics Dutch 0,000 kbps Presentation Graphics English 0,000 kbps Presentation Graphics Portuguese 0,000 kbps Presentation Graphics French 0,000 kbps Presentation Graphics Italian 0,000 kbps Presentation Graphics Dutch 0,000 kbps Presentation Graphics Portuguese 0,000 kbps Presentation Graphics French 0,000 kbps Presentation Graphics Italian 0,000 kbps Presentation Graphics Dutch 0,000 kbps settings movie only By the settings audio, All audio are checked but it's taken only Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps The subs is no problem. Last edited by De_Hollander; 21st November 2013 at 20:21. |
#18427 | Link |
When i make a remux and take playlist 800, and takes only DTS-HD High-Res Audio English 2046 kbps 5.1 / 48 kHz / 2046 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
and Dutch DD, then it's no problem with bd rebuilder. |
#18428 | Link |
The checkbox "Use SupTitle for Alternate Forced Subs" is not correctly initialized from the value stored in BDREBUILDER.INI. The checkbox is always unchecked when the setup dialog is opened independently of the value stored in BDREBUILDER.INI.
#18429 | Link | |
#18430 | Link |
Hmm... I just tested it and you are correct. I'll fix it for the next release.
#18431 | Link |
Mr
I have imported mkv files with srt subtitles and have been unable to turn on the subtitles when playing with the Dune media player. I believe it may be because there is no popup menu defined, which is how I normally have to do it.
#18432 | Link |
How the player decides to let you choose subtitles is completely up to the player. The MKV is just a container that packages them with the audio/video. Anyway, that would be something different. The issue reported is the import of SRT subtitles from an MKV into BD-RB.
#18433 | Link | |
Mr
I accept the fact that you're not responsible for how the players work. It's just that the menu created apparently doesn't work like most BD menus as regards subtitles. |
#18435 | Link |
Blank this item
Does anyone know why "blank this item" is permanently
greyed out in the stream list when right-clicking on any video stream? I think the answer will be "This feature is added in preparation for future stream editing options", but hoping some more positive answer from Mr. JDobbs....
#18436 | Link | |
#18437 | Link | |
#18439 | Link |
Unfortunately the nature of the BD structure makes it difficult to implement without some human intervention and a little knowledge. That's why its still undocumented.
#18440 | Link |
interlaced sources
If having interlaced sources on a BD complaint disk as an extra content (for example marked as MPEG-4 (AVC), 480i, 29.97 fps in the streamlist) how to get to know within BD-RB if is hard-telecined, soft-telecined, interlaced, mixed progressive and telecine, mixed progressive and interlaced?
Does BD-RB automatically recognize all these types of content and handle accordingly? I know that it is possible to set up both manually and automatically IVTC on hard and soft telecined sources, but I do not know if it is an entirely automatic process made by BD-RB or I should manually check each extra content outside of BD-RB to know the exact video type and set up BD-RB accordingly? Please help even it is not a bug related issue, it would be much appreciated. I have read a lot from your changes.txt file but these are unfortunately still questions to me and a bit messed up after read some pages in the internet about specifying the video types. Please help. Thank you in advance. |
| Thread Tools | |
| Display Modes | |
