#16222 | Link | ||
#16223 | Link |
What gives?
x264 wrong version found ?!?! Not possible
---------------------- [12/09/12] BD Rebuilder v0.42.04 (beta) [19:00:10] Source: LOCK_STOCK_00000 - Input BD size: 30.21 GB - Approximate total content: [01:47:23.311] - Windows Version: 6.1 [7601] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - AVS Filtering is enabled - Mode: MKV Container, 1920x1080, 448Kbs DD5.1 - Automatic cropping of borders enabled - Decoding/Frame serving: DirectShow - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=448 [19:00:33] PHASE ONE, Encoding - [19:00:33] Processing: VID_00009 (1 of 1) - [19:00:33] Extracting A/V streams [VID_00009] - [19:08:32] Reencoding video [VID_00009] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 154,485 frames - [19:08:32] Reencoding: VID_00009, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.42.04 (beta) - Windows Version: 6.1 [7601] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - X264: Wrong version found - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [19:08:34] - Failed video encode, aborted - Windows Version: 6.1 [7601] - AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3882], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - BD Rebuilder v0.42.0.4, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok |
#16224 | Link |
![]() Join Date: Oct 2001
It's checking wrong, ignore it.
Look at your filters -- that's the most likely place for issues in encoding.
jdobbs.softworks@gmail.com |
#16225 | Link |
I tried UnDot().Deen() because Lock, Stock and Two Smoking Barrels (1998) looked like the worst dirt/grain and overall poor quality transfer I'd ever seen on blu-ray. Is there a better/compatible filter(s) you'd recommend instead?
#16226 | Link |
I'd recommend trying it without any filters and the automatic cropping off -- just to make sure that it isn't a syntax error with one of them that is causing the encode failure.
#16227 | Link |
In fact, do you think you could post the contents of VID_00009.AVS so I can take a look at it (before you disable filters)?
#16228 | Link |
Will do, later tonight. Would not be surprised if it did work. The several before and after worked fine, did not need filters on them. I like the auto crop feature on the films that are 1.85:1 yet still have very small black bars. Also for removing black bars on the sides of 4:3 stuff. I do however get many bad encodes using this feature, does not always work as intended...
#16229 | Link | |
#16230 | Link |
help me
- Windows Version: 6.1 [7600]
- AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3882], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Not Set correctly - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - BD Rebuilder v0.42.0.4, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok ---------------------- [12/10/12] BD Rebuilder v0.42.04 (beta) [09:26:40] Source: DARK_SHADOWS - Input BD size: 23.82 GB - Approximate total content: [02:18:35.390] - Target BD size: 22.95 GB - Windows Version: 6.1 [7600] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [09:26:42] PHASE ONE, Encoding - [09:26:42] Processing: VID_00015 (1 of 8) - [09:26:42] Extracting A/V streams [VID_00015] - [09:26:53] Reencoding video [VID_00015] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,159 frames - Bitrate: 3,751 Kbs - [09:26:53] Reencoding: VID_00015, Pass 1 of 1 - [09:28:44] Video Encode complete - [09:28:44] Processing audio tracks - [09:28:44] Multiplexing M2TS - [09:28:50] Processing: VID_00031 (2 of 8) - [09:28:50] Extracting A/V streams [VID_00031] - [09:29:00] Reencoding video [VID_00031] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,689 frames - Bitrate: 11,083 Kbs - [09:29:00] Reencoding: VID_00031, Pass 1 of 1 - [09:29:59] Video Encode complete - [09:29:59] Processing audio tracks - Track 4352 (spa): Keeping original audio - [09:29:59] Multiplexing M2TS - [09:30:06] Processing: VID_00036 (3 of 8) - [09:30:06] Extracting A/V streams [VID_00036] - [09:30:15] Reencoding video [VID_00036] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 2,627 frames - Bitrate: 9,259 Kbs - [09:30:15] Reencoding: VID_00036, Pass 1 of 1 - [09:31:13] Video Encode complete - [09:31:13] Processing audio tracks - Track 4352 (eng): Keeping original audio - [09:31:13] Multiplexing M2TS - [09:31:21] Processing: VID_00054 (4 of 8) - [09:31:21] Extracting A/V streams [VID_00054] - [09:31:31] Reencoding video [VID_00054] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,601 frames - Bitrate: 9,203 Kbs - [09:31:31] Reencoding: VID_00054, Pass 1 of 1 - [09:32:47] Video Encode complete - [09:32:47] Processing audio tracks - Track 4352 (eng): Keeping original audio - [09:32:47] Multiplexing M2TS - [09:32:55] Processing: VID_00055 (5 of 8) - [09:32:55] Extracting A/V streams [VID_00055] - [09:33:07] Reencoding video [VID_00055] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,697 frames - Bitrate: 9,254 Kbs - [09:33:08] Reencoding: VID_00055, Pass 1 of 1 - [09:34:29] Video Encode complete - [09:34:29] Processing audio tracks - Track 4352 (eng): Keeping original audio - [09:34:29] Multiplexing M2TS - [09:34:37] Processing: VID_00056 (6 of 8) - [09:34:37] Extracting A/V streams [VID_00056] - [09:34:49] Reencoding video [VID_00056] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,366 frames - Bitrate: 10,986 Kbs - [09:34:49] Reencoding: VID_00056, Pass 1 of 1 - [09:36:04] Video Encode complete - [09:36:04] Processing audio tracks - Track 4352 (eng): Keeping original audio - [09:36:04] Multiplexing M2TS - [09:36:13] Processing: VID_00057 (7 of 8) - [09:36:13] Extracting A/V streams [VID_00057] - [09:36:23] Reencoding video [VID_00057] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 3,409 frames - Bitrate: 8,941 Kbs - [09:36:23] Reencoding: VID_00057, Pass 1 of 1 - [09:37:37] Video Encode complete - [09:37:37] Processing audio tracks - Track 4352 (eng): Keeping original audio - [09:37:37] Multiplexing M2TS - [09:37:45] Processing: VID_00058 (8 of 8) - [09:37:45] Extracting A/V streams [VID_00058] - Error in attempt to extract audio/subs. - [09:51:59] - Failed to retrieve audio, aborted |
#16231 | Link |
help me please
help me please
---------------------- [12/10/12] BD Rebuilder v0.42.04 (beta) [14:07:06] Source: DARK_SHADOWS - Input BD size: 23.82 GB - Approximate total content: [02:18:35.390] - Target BD size: 22.95 GB - Windows Version: 6.1 [7600] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 - Resuming from previously started job. [14:07:08] PHASE ONE, Encoding - [14:07:08] Processing: VID_00058 (8 of 8) - [14:07:08] Extracting A/V streams [VID_00058] - Error in attempt to extract audio/subs. - [14:20:57] - Failed to retrieve audio, aborted ---------------------- [12/10/12] BD Rebuilder v0.42.04 (beta) [14:45:18] Source: DARK_SHADOWS - Input BD size: 23.82 GB - Approximate total content: [02:18:35.390] - Target BD size: 22.95 GB - Windows Version: 6.1 [7600] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 - Resuming from previously started job. [14:45:22] PHASE ONE, Encoding - [14:45:22] Processing: VID_00058 (8 of 8) - [14:45:22] Extracting A/V streams [VID_00058] - Error in attempt to extract audio/subs. - [14:58:51] - Failed to retrieve audio, aborted _______________________________ - Windows Version: 6.1 [7600] - AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3882], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Not Set correctly - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - BD Rebuilder v0.42.0.4, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok |
#16232 | Link | ||
#16233 | Link | |
DirectshowSource("E:\MOVIES\LOCK_STOCK\BDMV\STREAM\00009.m2ts", fps=23.976, framecount=154485, audio=false) UnDot().Deen() LoadPlugin("C:\Other Program Files\BDRB\tools\autocrop.dll") Autocrop(mode=0) ConvertToYV12().AssumeFPS(24000,1001) |
#16234 | Link | |
Does the AVS playback ok if you open it with Media Player Classic?
#16236 | Link |
- AVISYNTH Version: [2.5.8.0], Ok - HAALI Splitter: [1.9.42.1], Ok - FFDSHOW: [3882], Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Not Set correctly - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libmpeg2": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - BD Rebuilder v0.42.0.4, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok ------------------------ [12/11/12] BD Rebuilder v0.42.04 (beta) [09:09:32] Source: DARK_SHADOWS - Input BD size: 23.82 GB - Approximate total content: [02:18:35.390] - Target BD size: 22.95 GB - Windows Version: 6.1 [7600] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 - Resuming from previously started job. [09:09:34] PHASE ONE, Encoding - [09:09:34] Processing: VID_00058 (8 of 8) - [09:09:34] Extracting A/V streams [VID_00058] it just goes to 89% |
#16237 | Link |
Looks like you didn't even read my response to your other post. I suggest you do that first and then try again. Your settings for mpeg2 were not correct then and still aren't on that post
Verstuurd van mijn HTC Sensation XE with Beats Audio Z715e met Tapatalk |
#16238 | Link |
It's supposed to be small. It is an AVS file. It references other material. What error do you get if you try to open it with MPC?
#16239 | Link | |
| Thread Tools | |
| Display Modes | |
