Old 19th October 2019, 21:38   #201  |  Link
ChaosKing
Seems like a dns problem on my machine. Or maybe Quad9 DNS 9.9.9.9 is blocking http://www.iol.ie/~schubert/gas/gas.html 🤔
EDIT it is indeed blocked https://www.quad9.net/result/?url=www.iol.ie
Old 21st October 2019, 08:43   #202  |  Link
LigH
LigH's Avatar
Works for me.
Oops, missed a new page.
New German Gleitz board
Old 21st October 2019, 09:26   #203  |  Link
Groucho2004
Originally Posted by ChaosKing View Post
Seems like a dns problem on my machine. Or maybe Quad9 DNS 9.9.9.9 is blocking http://www.iol.ie/~schubert/gas/gas.html ��
Just report it as a false positive to Quad9.
Groucho's Avisynth Stuff
Old 21st November 2019, 20:36   #204  |  Link
Meloware
Can I get Avsr to take a start frame and range?
I thought zorr ask for this, a year ago. You obliged him with a " -frames" feature, which seems to require each desired frame to be listed. How about a real “-range” feature? I would love a starting point and number of frames (a range) to render!
My video script and 32 core Threadripper is processing out about 20, 1440 x 1080 frames per second. The CPU utilization is only about 16% and there are around 16 threads doing most of the work. Now, I'd love to discuss how to light up the other cores, in a different conversation, but I could really use this “range” feature. If I start an instance of AVSPmod (64), while Avsr was also running, I can specify a later range of frames to process. AVSPmod happily jumps to the selected start frame and begins to process. Then, my CPU load climbs to 30%.
I suppose I am greedy, but I'd love to see what my rendered frame rate would be, with a 85% CPU load! Is there an easy way to specify a start frame/range in the avsr command line?
Meloware is offline   Reply With Quote
Old 22nd November 2019, 00:30   #205  |  Link
Groucho2004
I'm not sure about the usefulness of what you're trying to do but for now you can use AVSMeter to achieve this (switch "-range", see documentation). Don't forget to set the parameter "AllowOnlyOneInstance" in avsmeter.ini to 0 if you want to run multiple instances.
Old 22nd November 2019, 00:54   #206  |  Link
Meloware
I have used AVSMeter to check scripts, but wasn't aware you could render as well. Command line rendering is what I have been using AVSr for.
All my script rendering is to frame sequences. This allows me to stop and resume big jobs as my needs for the computer change, over the day. I also have had issues where a script may just stop running. If I were rendering to an avi, everything would break, right? With a frame sequence, I can restart where things left off, with no loss of the work already rendered.
If a script is only running at 20% of my machine's capacity, I can run multiple instances of the script, with each instance rendering different portions of the big job. Unlike rendering to an AVI container, individual numbered frames may be rendered in any order, and make it possible to correct portions of the larger project, without needing to re-render everything from scratch. Each instance might grab it's own 20% of my system resources, but 4 instances combined will give me four times the performance.
When it is all done, I can then review the work and then possibly re-render portions, using different script settings. For these reasons, I feel the ability to suspend and resume script jobs is very powerful and needed.
Thanks, and I will explore doing this with AVSMeter.
Old 22nd November 2019, 01:07   #207  |  Link
Groucho2004
OK, I understand now. Multiple instances of AVSMeter should do exactly what you want.
Old 22nd November 2019, 13:12   #208  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Why don't you just use ripbot264 in distributed encoding mode? With 8 servers (2 per numa) you will get constant 100% CPU load.
Old 22nd November 2019, 17:00   #209  |  Link
Meloware
I just tried AVSMeter64 2.9.7. The first instance works, but I am not allowed to run multiple instances from multiple terminal boxes.
I get the message "One instance of AVSMeter is already running"
Old 22nd November 2019, 17:13   #210  |  Link
poisondeathray
Edit the .ini
See post 206
Old 23rd November 2019, 15:45   #211  |  Link
stax76
stax76's Avatar
I decided to use avsr for learning how to use avisynth and wonder why there is no build or project file? It took me a while to make it compile in VS.
Old 23rd November 2019, 15:58   #212  |  Link
Groucho2004
I build my projects with makefiles from the command line. I can post the makefiles if you want.
Old 23rd November 2019, 16:10   #213  |  Link
stax76
stax76's Avatar
I have it working in Visual Studio 2019 but only x86, with x64 (I've only avs+ x64 installed and I don't have any x86 filters) I get many errors unfortunately.
Severity Code Description Project File Line Suppression State
Error (active) E0167 argument of type "char *" is incompatible with parameter of type "LPWSTR" avsr D:\Projekte\CPP\avsr\common.h 79
Error (active) E0167 argument of type "const char *" is incompatible with parameter of type "LPCWSTR" avsr D:\Projekte\CPP\avsr\avsr.cpp 169
Error (active) E0167 argument of type "const char *" is incompatible with parameter of type "LPCWSTR" avsr D:\Projekte\CPP\avsr\common.h 67
Error (active) E0167 argument of type "char *" is incompatible with parameter of type "LPWSTR" avsr D:\Projekte\CPP\avsr\avsr.cpp 125
Error (active) E0167 argument of type "char *" is incompatible with parameter of type "LPTSTR" avsr D:\Projekte\CPP\avsr\common.h 95
Error (active) E0167 argument of type "char *" is incompatible with parameter of type "LPCWSTR" avsr D:\Projekte\CPP\avsr\avsr.cpp 125
Error C4996 '_vsnprintf': This function or variable may be unsafe. Consider using _vsnprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details. avsr D:\Projekte\CPP\avsr\utility.h 174
Error C4996 '_snprintf': This function or variable may be unsafe. Consider using _snprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details. avsr D:\Projekte\CPP\avsr\exception.h 1465
Error C4996 '_snprintf': This function or variable may be unsafe. Consider using _snprintf_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details. avsr D:\Projekte\CPP\avsr\utility.h 253
Error C2664 'UINT GetWindowsDirectoryW(LPWSTR,UINT)': cannot convert argument 1 from 'char [1026]' to 'LPWSTR' avsr D:\Projekte\CPP\avsr\common.h 79
Error C2664 'UINT (LPTSTR,UINT)': cannot convert argument 1 from 'char [1026]' to 'LPTSTR' avsr D:\Projekte\CPP\avsr\common.h 95
Error C2664 'HMODULE LoadLibraryW(LPCWSTR)': cannot convert argument 1 from 'const char [9]' to 'LPCWSTR' avsr D:\Projekte\CPP\avsr\avsr.cpp 169
Error C2664 'HMODULE GetModuleHandleW(LPCWSTR)': cannot convert argument 1 from 'const char [13]' to 'LPCWSTR' avsr D:\Projekte\CPP\avsr\common.h 67
Error C2664 'DWORD GetModuleFileNameW(HMODULE,LPWSTR,DWORD)': cannot convert argument 2 from '_Ty *' to 'LPWSTR'
with
_Ty=char
] avsr D:\Projekte\CPP\avsr\utility.h 248
Error C2664 'DWORD GetModuleFileNameW(HMODULE,LPWSTR,DWORD)': cannot convert argument 2 from 'char [2048]' to 'LPWSTR' avsr D:\Projekte\CPP\avsr\exception.h 67
Error C2664 'DWORD GetFullPathNameW(LPCWSTR,DWORD,LPWSTR,LPWSTR *)': cannot convert argument 1 from 'char *' to 'LPCWSTR' avsr D:\Projekte\CPP\avsr\avsr.cpp 125
Error C2664 'DWORD GetFileVersionInfoSizeW(LPCWSTR,LPDWORD)': cannot convert argument 1 from '_Ty *' to 'LPCWSTR'
with
_Ty=char
] avsr D:\Projekte\CPP\avsr\utility.h 258
Error C2664 'DWORD GetFileAttributesW(LPCWSTR)': cannot convert argument 1 from 'const _Elem *' to 'LPCWSTR'
with
_Elem=char
] avsr D:\Projekte\CPP\avsr\utility.h 137
Error C2664 'DWORD FormatMessageW(DWORD,LPCVOID,DWORD,DWORD,LPWSTR,DWORD,va_list *)': cannot convert argument 5 from 'char [2048]' to 'LPWSTR' avsr D:\Projekte\CPP\avsr\utility.h 231
Error C2664 'BOOL VerQueryValueW(LPCVOID,LPCWSTR,LPVOID *,PUINT)': cannot convert argument 2 from 'const char [2]' to 'LPCWSTR' avsr D:\Projekte\CPP\avsr\utility.h 272
Error C2664 'BOOL GetFileVersionInfoW(LPCWSTR,DWORD,DWORD,LPVOID)': cannot convert argument 1 from '_Ty *' to 'LPCWSTR'
with
_Ty=char
] avsr D:\Projekte\CPP\avsr\utility.h 264
Old 23rd November 2019, 16:18   #214  |  Link
Groucho2004
No idea (except C4996). Search MSDN for these errors. The code builds fine with the VS2010 compiler, linker and libraries for x86 and x64.
Old 23rd November 2019, 16:32   #215  |  Link
stax76
stax76's Avatar
It's running now in x64 after changing few lines, thanks Groucho2004.
Old 23rd November 2019, 17:30   #216  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
For the benefit of others, what were the few things?
In my experience those kinds of errors about char* conversions are usually solved by changing the project's Character Set property.
wonkey_monkey is offline   Reply With Quote
Old 23rd November 2019, 17:39   #217  |  Link
Groucho2004
That sounds plausible since newer versions of VS have UNICODE defined by default (as far as I recall).
Old 23rd November 2019, 19:02   #218  |  Link
stax76
stax76's Avatar
My changes were not perfect like changing func to funcA or LPWSTR to LPSTR.
Old 23rd November 2019, 19:20   #219  |  Link
Groucho2004
Yeah, not really the way to do it. Just change it in the preprocessor definitions (UNICODE -> MBCS).
Old 23rd November 2019, 19:50   #220  |  Link
stax76
stax76's Avatar
For my purpose it's fine, I'm much of C++ n00b, only piece of C++ code I still own is this:
https://github.com/stax76/OpenWithPl...ShellExtension
It was written 10-15 years ago and meanwhile I have forgotten few things.
When I've finished this project I'm doing for staxrip (involves avisynth, vapoursynth and hw accelerated rendering) my C++ knowledge will be improved 1-2 levels, I'm still in the learning and experimenting phase and don't try to rush it.
