Old 28th November 2017, 03:19   #4881  |  Link
ryrynz
ryrynz's Avatar
Thanks for the timely update guys.
Old 30th November 2017, 05:08   #4882  |  Link
giosa
I've got no sound when saving as YouTube videos in mp4.
Webm has the sound but quality 360p.
giosa is offline   Reply With Quote
Old 30th November 2017, 05:24   #4883  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Youtube for many resolution split video/audio streams in different url - DASH format. When save - saving only first url.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 30th November 2017, 05:51   #4884  |  Link
nsnhd
Try 3D YouTube Downloader (x64)
nsnhd is offline   Reply With Quote
Old 30th November 2017, 18:53   #4885  |  Link
beter
Adjustments to the translation of Traditional Chinese, Simplified Chinese and Dutch
https://www.sendspace.com/file/yyshtv
beter is offline   Reply With Quote
Old 30th November 2017, 21:12   #4886  |  Link
Klaus1189
updated german translation based on r3155: some tweaks
Old 30th November 2017, 23:47   #4887  |  Link
P.J
Δ
This video is progressive but plays in interlaced mode:
https://www.sendspace.com/file/8jnas7
Wish MPC-BE could always respect to the container's metadata...
P.J is offline   Reply With Quote
Old 1st December 2017, 01:42   #4888  |  Link
Aleksoid1978
Thanks - fixed.
Old 1st December 2017, 04:38   #4889  |  Link
v0lt
@beter, @Klaus1189
Thank you. Updated in r3157.
v0lt is offline   Reply With Quote
Old 2nd December 2017, 10:26   #4890  |  Link
Klaus1189
Missed an old mistake in translation, but I fixed it here
Old 5th December 2017, 01:38   #4891  |  Link
Mtz
Mtz's Avatar
I have a dual camera which is recording two separate videos at the same time. Is possible to play both videos as picture in picture? Normally these videos have almost the same name, except latest 3 characters.
Mtz is offline   Reply With Quote
Old 5th December 2017, 01:56   #4892  |  Link
Aleksoid1978
Not possible.
Old 5th December 2017, 04:23   #4893  |  Link
v0lt
@Mtz
You can use AviSynth and open the script (.avs) in many players.
Old 9th December 2017, 10:15   #4894  |  Link
Mercury_22
@ Aleksoid & V0lt any chance you can move Nightly builds to other site cause yandex seems to have some problems...?
please see
https://forums.informaction.com/viewtopic.php?t=23655
and
https://freedom-to-tinker.com/2017/1...eplay-scripts/
Thanks
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline   Reply With Quote
Old 9th December 2017, 18:20   #4895  |  Link
v0lt
I do not see any problems. Files are available for download. No one forces you to leave personal information on Yandex sites.
Old 10th December 2017, 14:54   #4896  |  Link
ontherocks
A particular mkv file doesn't play in newer versions. Last version it played was in MPC-BE.1.5.0.2235
It is a file from youtube, muxed to mkv. To get the mkv do the following:
1. Download youtube-dl.exe from here
2. Download ffmpeg from here
3. Extract the ffmpeg zip somewhere
4. Put the youtube-dl.exe in the bin folder of ffmpeg
5. Open a windows command prompt and navigate (i.e. change directory) to the bin folder of ffmpeg
6. Run the command "youtube-dl -f bestvideo+bestaudio https://www.youtube.com/watch?v=GCraGHx6gso"
At the end you will get a file named "Decorator Pattern – Design Patterns (ep 3)-GCraGHx6gso.mkv"
ontherocks is offline   Reply With Quote
Old 11th December 2017, 12:20   #4897  |  Link
wanezhiling
Works fine with latest 3181
https://s2.postimg.org/5vv4pdw6x/2017-12-11_191518.png
File: C:\Decorator Pattern – Design Patterns (ep 3)-GCraGHx6gso.mkv
MD5: 822655CCE78D176BCE6E978E340651D8
SHA1: BF28A2877DF85023A787F39F301872F26F7215D5
CRC32: 448A93F4
Old 11th December 2017, 12:31   #4898  |  Link
Aleksoid1978
Latest SVN version - perfect playback. All internal filters.
SVN build can take here - https://yadi.sk/d/hlf1lfC8mKU58/!_last
Old 11th December 2017, 17:54   #4899  |  Link
ontherocks
Somehow it doesn't play for me. I am left with a blank screen that says "Playing" at the bottom. I have tried resetting all settings, a complete uninstall and reinstall.
Old 11th December 2017, 18:54   #4900  |  Link
v0lt
ontherocks
Upload your file with a problem.
