12th August 2020, 05:31 | #82 | Link |
R2 released.
changelog: Code:
r2: [2020-08-12] - Disabled mouse scroll to scroll a zommed preview because it doesn't make sense to be only able to scroll one axis - Preview zoom in scroll bar position are remembered for similar clips in a group - Fixed preview zoom raito not having immediate effect when change tabs - Script window can be hidden and restore now - Added close tab action when right click on tab - Added shortcuts to switch tab by number keys, available keys are 1-9 - Fixed all editor shortcut keys - Arrow key navigation from time line and preview area works now - A new preview filters feature leveraging vs script to assist preview - Preview filters can be chained - Per frame properties can be display in frame info dialog now - Added menu options to toggle the Tools widget and its dialogs - Added a copy script to new tab function - Added right click and middle click signal to the tabwidget - Added middle click close tab function - Added the basic editor copy/paste actions to the menu options - A find and replace function for the editor - PreviewArea now uses QPainter for frame drawing instead of QPixmap, which greatly improves performance for zooming - Zoom ratio cap increases to 25x |
12th August 2020, 06:53 | #87 | Link |
Yes R2
Tabs with number key switching works for you? feature suggestion - extension templates. In avspmod when you drag some video , it will fill in the source filter, path, everything, you just need to hit preview. You can fill in a preferential source filter file for extensions e.g. LSmashVideoSource(***) for MP4 . Currently the r'PATH\video.ext' is filled when you drag a video |
12th August 2020, 07:12 | #88 | Link | |
The file drop template feature is already there, go to edit->snippet and templates->file drop templates. That why I didn't go into this area. It's just that nobody know how to use it beside Mystery Keeper lol. I have no clue how it work either. |
12th August 2020, 15:24 | #89 | Link | ||
Number key switching for tabs works on VapourSynthMultiViewer for me (but it's buggy in other ways) Quote:
12th August 2020, 15:29 | #90 | Link |
I was going to make the appropriate changes and push a pull request but this is more than I have time for. It's obvious it needs a major overhaul as the code is completely broken on non-Windows platforms. I'd recommend spinning up a Linux VM to work through fixing things if you care about this being cross platform at all, if not I suppose it's fine as a Windows only tool. Side note, I'd recommend actually adding version tags to the repository so that's its easier to use git to find certain versions to help troubleshoot in the future so that specific commits don't have to be tracked down based on the date you uploaded the executables.
12th August 2020, 16:16 | #92 | Link |
1,2,3 hotkeys do not work for me. I'm on win10 x64
EDIT It seems the old config needs to be deleted, then it works.
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database Last edited by ChaosKing; 12th August 2020 at 16:20. |
12th August 2020, 16:26 | #93 | Link | |
12th August 2020, 16:42 | #96 | Link | |
Can you walk me through how to delete the old config ? I deleted the doubled up 1,2,3 entries in the hotkey mapping for zoom, still does not work for me Thanks @lansing - "new script template" is not active in this version. edit > snippets and templates > new script template . In the original version, CTRL+N opens a new script with the contents of the template pasted ("'import vapoursynth as vs, etc..." Is "time step foward/back" active? The hotkey ctrl+right / ctrl+left moves 1 frame, but I cannot find the field where you adjust the time period (e.g. 1 second or whatever period) EDIT: NM CK, I got it working. I needed to exit and restart , HOTKEY TAB SWITCHING WORKS!! THANKS LANSING! This was my #1 request Last edited by poisondeathray; 12th August 2020 at 16:53. |
12th August 2020, 17:07 | #97 | Link | |
The time step has also been disabled for now. |
12th August 2020, 17:22 | #99 | Link |
It is in C:\Users\USERNAME\AppData\Local\vsedit.config
Most programs have their own folder, vsedit does not have one. Or just type %LOCALAPPDATA% in explorer and scroll to the bottom.
vapoursynth editor |
