Old 28th November 2023, 18:49   #1  |  Link
Mounter81
How/with what to convert HEVC HLG video to HEVC SDR video?
So I have a couple of HLG videos witch didn't play with fine colors (too dark) on my media player (but fine with MPC-BE on Windows). So I want them to be converted to SDR.
What is the best converter program and how to set it up to do this?
Thank you!
Mounter81 is offline   Reply With Quote
Old 28th November 2023, 21:21   #2  |  Link
benwaggoner
I believe zscale in ffmpeg also has a pretty good HLG to 709 conversion mode. Most HLG is close enough to SDR that it doesn't take a whole lot of processing; much simpler than converting from PQ.
Ben Waggoner
My Compression Book
Old 29th November 2023, 09:35   #3  |  Link
Mounter81
Ok, thanks to both, but where can I find some tutorials to do this conversion with the mentioned programs?
Old 29th November 2023, 15:26   #4  |  Link
Mounter81
Originally Posted by eac3to_mod View Post
You're unlikely to find a tutorial covering all those things. Let's start by asking what experience do you have in multimedia? For example, have you ever used Avisynth(+)?
No never I have used Avisynth. I have used Handbrake sometimes for other purposes.
Old 29th November 2023, 16:17   #5  |  Link
Mounter81
Oh and for hardwarewitse I have a 10.th Gen i3 CPU with Intel UHD 630 IGP to do the encoding.
Old 29th November 2023, 17:14   #6  |  Link
Mounter81
Looks like Handbrake can do it:
https://www.reddit.com/r/handbrake/c..._sdr_question/
If you want to get pedal-to-the-metal with this stuff, you're going to have to learn all the steps individually. You can start by researching and learning Avisynth(+) and filtering.
No Handbrake can't do the conversion it just convert it to SDR without the color correction (like HDR video on an SDR display).
I have found this Avisynth script somwhere:
LoadPlugin("path\LSMASHSource.dll")
LWLibavVideoSource("path of the video", format="YUV420P16")
loadplugin("path\dgdecodenv.dll")
loadplugin("path\dghdrtosdr.dll")
DGHDRtoSDR(mode="pq",white=2000)
I have loaded it into Virtualdub, but it doesn't work for me, because the dgdecodenv.dll file is for NVida GPUs only. I need a version that works with my intel IGP. Can someone help me in that?
Old 30th November 2023, 16:19   #7  |  Link
Mounter81
You don't have to load DGDecodeNV.dll if you use LSMASHSource.dll:
LoadPlugin("path\dghdrtosdr.dll")
DGHDRtoSDR(mode="hlg", impl="sw") # kinda slow in sw mode
Read the accompanying DGHDRtoSDR text file for other options.
There are also other filters to do it. I'll let their authors chime in, or do a search.
I want to do it a hardware level mode, if possible. The UHD 630 IGP is capable of HEVC 10 encoding (intel QSV). Any ideas?
Old 1st December 2023, 05:58   #8  |  Link
Mounter81
Ok, I have loaded the script in Virtualdub, but don't know how to start the encoding...
So what option should I select in Vurtualdub next?
Old 1st December 2023, 07:03   #9  |  Link
Mounter81
And one more question, how do I add/enable x265.exe to Virtualdub?
Old 1st December 2023, 13:54   #10  |  Link
StvG
There are libplacebo (Vulkan) implementations for VapourSynth/AviSynth that can do tonemapping.
StvG is offline   Reply With Quote
Old 3rd December 2023, 02:52   #11  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
x265 is generally used via command line, however if you wanna use it through VirtualDub, just make sure you're you using the latest version of VirtualDub, Build 44282 (2020) from here: Link
and you'll find it in "video -> compression":
then hit the "configure" button and you can pick a fraction of parameters like the preset, the crf and the bit depth.
If you want more parameters then I'm afraid you'll have to use the command line. If you were to actually use the command line, it might seem intimidating at frist, but you'll see that it's actually pretty straightforward and many of us here prefer it to any GUI.
About converting HDR HLG to SDR BT709, you can do:
#Indexing
video=LWLibavVideoSource("your_video.m2ts")
audio=LWLibavAudioSource("your_audio.m2ts")
AudioDub(video, audio)
#Bringing everything to 16bit planar
ConvertBits(16)
#From YUV to XYZ
ConvertYUVtoXYZ(Color=0, HDRmode=2)
#HLG HDR to BT709 SDR tonemapping
ConvertXYZ_Reinhard_HDRtoSDR(exposure_X=2.1)
#Bringing everything back to YUV
ConvertXYZtoYUV(pColor=0)
#Dithering
ConvertBits(bits=8, dither=1)
but you'll need to put the DLLs in plugins64+ from here: Link - Link
