Old 9th March 2018, 00:00   #49461  |  Link
nevcairiel
Originally Posted by Asmodian View Post
"calibration disabled" is actually the same as the default already calibrated setting (BT.709, pure power 2.2); there is no change in performance between already calibrated and calibration disabled.
I don't think that is true. In calibration disabled mode I don't think madVR remaps gamuts.
Basically, I don't think anyone should really be using calibration disabled, if you don't have a meter to calibrate, then just set it to "display already calibrated" and typically BT.709, unless you know otherwise from your TVs specs.
Old 9th March 2018, 00:09   #49462  |  Link
i'm pretty sure it was changed to BT 709 for no calibration settings.
this should be very easy to test.
i have no bt 2020 file on the Pc i'm currently at.
Old 9th March 2018, 00:31   #49463  |  Link
mclingo
I think it is BT 709 as my reds are overblown using DRECT3d11 in both calibrated off and calibrated to BT709. If I use DCI-P3 it is better but its still quite red compared to EVR rendering, if I use BT2020 its a bit far the other way but look more natural in a way.
Can anyone tell me what this should be set to and why having DIRECT3D11 ticked is causing my colours to overblow in red?
I have a LG OLED EF9500 HDR TV
Old 9th March 2018, 00:57   #49464  |  Link
mclingo
closest i cant get to EVR is using display calibrated to BT2020 using BT709 transfer function 1.08, no idea if this is correct but it looks pretty good to my ageing peepers
Old 9th March 2018, 09:12   #49465  |  Link
mytbyte
Originally Posted by mclingo View Post
anyone else out there with a 2015 or 2016 LG OLED without a pro calibration, just wondering what you've set your MADVR calibration to, DCI-P3 / power curve 2.20 looks the best to my eyes, with calibration disabled MADVR is overblowing colour, mainly reds for me.
No idea if this is even correct.
Hmmm...I'm assuming you're not using passthrough...if it's overblowing, then your TV is set to some native (full gamut) mode or P3 mode (if you choose DCI P3 in MadVR and it looks the best, then this would prove that the TV is not in Rec709 but in P3 or native mode)...madvr is unaware of the color gamut of your TV, with no conversion it just send color as is, or converted to rec709 if it's HDR video (I assume the latter from my own testing)...
mytbyte is online now   Reply With Quote
Old 9th March 2018, 11:24   #49466  |  Link
mclingo
Hi, PASSTHRU? this is SDR material i'm talking about, havent even looked at HDR yet, that may also be problematic.
After some more fiddling I updated which settings a couple of posts up, I found the most accurate picture was BT2020 using BT709 transfer function 1.08.
I still think its odd that this problem goes away when I deslect DIRECT3D 11 in MADVR, I feel this is where the problem lays,nobody has explained that yet, could be other people have this problem but just havbent noticed yet as its not that obvious in most movies, this particular scene is very noticeable.
If this were an issue with my TV then EVR would also look bad, there must be something wrong with MADVR's calibration off settings, whatever they are they should surely mirror what EVR renderer is doing when off, surely?
Could do with some feedback from @MADSHI on this really
Old 9th March 2018, 13:30   #49467  |  Link
leeperry
Kid for Today
Originally Posted by nussman View Post
This foozoor posted similar posts in other threads. Just ignore it
we got both Dolby Vision dude and and mpv>mVR troll in here, better ignore them indeed.
still super impressed by RCA "Very High" on DVD@1080p, yay
Old 9th March 2018, 14:37   #49468  |  Link
can you provide a sample of the scene?
Old 9th March 2018, 14:57   #49469  |  Link
mclingo
actually, isnt is possible to do this from a screen dump, I cant test this from work, you should be able to open with and choose MPC, it will load this as one frame and process it full screen?
https://www.dropbox.com/s/mvq9zy92uh...33%5D.jpg?dl=0
Yeah that does work - when you turn calibration off / on you have to reload the image though.
Old 9th March 2018, 15:07   #49470  |  Link
mytbyte
@mclingo: sorry, somehow I missed that conversation had progressed quite a bit since the quote...still, I find it odd that, in my case any changes in transfer function/gamma section does nothing for SDR video but indeed does something for HDR, other than that I find no difference regarding color between DX11 and DX9 modes...
Old 9th March 2018, 15:46   #49471  |  Link
mclingo
https://www.dropbox.com/s/py3n63ob6e...%29_1.mp4?dl=0
link to clip, note however I can see the difference on any movie, its just more obvious in skin tones on this clip.
Old 9th March 2018, 15:58   #49472  |  Link
chuchicoupe
lag FSE
i'll update to windows 10 v17618 and madvr FSE lag, don't before
chuchicoupe is offline   Reply With Quote
Old 9th March 2018, 18:23   #49473  |  Link
the file has no flags making it pure guessing work.
just a bad encode.
make sure windows 10 hdr is disabled it may does it "thing".
Old 9th March 2018, 18:54   #49474  |  Link
el Filou
el Filou's Avatar
That's strange, MediaInfo says it's flagged BT.709
Old 9th March 2018, 19:22   #49475  |  Link
so what? is it a container flag or a stream flag?
madVR doesn't get the needed information so most likely not a stream flag.
@chuchicoupe
if you are using an nvidia card check the power settings in the NV control panel make sure it is >not< optimal.
Old 9th March 2018, 19:25   #49476  |  Link
nevcairiel
Makes no difference though, in absence of flags it guesses BT.709 anyway.
The most likely reason for such color differences are bad configuration on the GPU control panel though, and not in madVR.
Old 9th March 2018, 19:48   #49477  |  Link
yes it falls back to bt 709 for this resolution but is this file really bt 709 and not smpte C?
in term of faces colors i don't think bt 709 is correct. with a proper flag there would be nothing to argue about (which would be BT 709 nearly for sure...).
doesn't fix the issue anyway d3d9 or d3d11 are the same for me so this is something todo with the screen settings or GPU driver.
Old 9th March 2018, 20:42   #49478  |  Link
mytbyte
Same here, still no difference with the clip itself, no matter what...
@mclingo: too lazy to back-check if this had been brought up, but does that happen when the GPU is connected to some other display?
Old 9th March 2018, 20:44   #49479  |  Link
mzso
Originally Posted by cremor View Post
Yes, I sometimes have the same problem, but it only happens if you leave the PC long enough so that Windows turns off the display. So one workaround would be to increase that time or disable the function completely.
Still? Ugh I would have hoped this wretch of an OS would have improved in 2,5 somewhat. (But it looks like it'll remain a dump of an OS like Visa was)
Thanks for the info anyway. (I might take a peek at RS4 anyway, well isolated form everything else)
Old 9th March 2018, 21:34   #49480  |  Link
mclingo
well thats interesting, it does the same thing with my 40" samsung MU7000 plugged so that rules out my LG OLED TV, could be my receiver though I guess, I'll bypass that next.
reciever also bypassed same result so it has to be my settings of a problem with the GPU, everyone else is testing this with NVIDIA cards?
Anyone got a similar setup to mine?
AMD RX 550 18.2.2
LG OLED 2015 4K
Win 10 creators up to date
